Question about Teac Hi-Fi Radio w/ iPod Dock BLACK (TEAC-SR-L200I-B) Docking Station
I pod dock on teac sr80i is broken - Teac Hi-Fi Radio w/ iPod Dock BLACK (TEAC-SR-L200I-B) Docking Station
I pod dock not connecting properly
it sounds like you have a faulty connection piece on your docking station u mite want to take it back to the shop
Sep 02, 2012 | Audio Players & Recorders
I have a Sonic Integrity Tube Pod (Tube Pod) and need to know how to make it work with iphone 4. I can play the iphone 4 only through the earphone jack at this point. The iphone 4 however can sit on the...
It is normal to get incompatible devie message when you attach your iphone to dock because you don't use apple dock. I have 5 different brand portable speakers, charging docks. And all of them give same message when i attach my iphone 4 to dock. When you press "ok" on your iphone screen, it should start to play your songs. You don't need to use your iphone at airplane mode.
You may have problem with your iphone dock conncector cable pins. If audio related pins are damaged, you can not use any external iphone speakers with your iphone4. In order to test your sonic integrity tube pod; try another ipod or iphone on its dock. If it gives same result, you may need to change dock connector unit on sonic integrity tube pod due to damaged pins. If it works; iphone 4 dock connetor cable of your iphone 4 needs to be replaced.
Nov 29, 2010 | Sonic Integrity MP5-DS iPod Tube Docking...
I just bought a I Pod dock ASD 11R and would like
Get a 3.5 plug with two RCA plugs and connect it to an aux imput via the headphone out of the dock.
Jan 24, 2010 | Denon AVR-3803 Receiver
Have bought ipod nano 5th generation and find the sound is distorted when using my teac cx-225idab docking system. older version of ipod is fine. any clues.I thought it was the ipod and had it exchanged...
Usually, that will happen if the ipod is not compatible w/ the docking station. Try to connect the ipod to a different docking station to check if it will gonna do the same thing...
Oct 26, 2009 | Teac CD-X10i Docking Station for Apple...
Will not charge, Ipod nano says that this accessory is not supported and shows that it wont charge the battery. also the Teac will not turn off the Ipod or turn it on or it just keeps running . Use to work...
Apple does this so that only Certified accessories have to software to make the hardware circuits charge an i pod, thats especially a problem with some sound docks, my i pod 2 gen works with only 1 of the 3 sound docks that i have tried, but i have a bluetooth i home so i play my music wirelessly
Oct 18, 2009 | Computers & Internet
I pods doesn't work after i remove it from radio dock.
I had that same problem too and i had to take my i-pod back because my machine messed it up so thats probably what your going to have to do to the repair shop said that there was nothin they could do and I was better off taking it back and my docking station messed it upso I had to get another i-pod and a docking station-I hope you get the problem fixed
Oct 09, 2009 | Starlite Nextplay Fashion iPod Docking...
My Bose system does not want to play any of our different sized I pods as it does not recognise that there is an I pod there. It used to work perfectly. Cant believe that the docking bit is bent as it is...
different ipod generations have different shapes for their chargers i mean the angle of the ipod is different when u buy an ipod it comes with a white piece that has an eccentric hole in the middle put this down b4 putting the ipod in it may work now but u may have broken the usb access port for the bose
Oct 04, 2009 | Bose SoundDock digital music system...
I cannot set the clock on my Teac MC-DX50i
put the system in standby then use your forward and revese buttons to set the time.
May 31, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
Teac sr-l200i, the ipod dock just started malfunctioning in the last hour. When I dock the ipod there is barely any sound. This is the case for all my ipods on this unit. The ipods are working on all my...
I had the same problem but with a different TEAC docking product.
My TEAC would not recognize my ipod therefore I was unable to control my ipod via the docking station remote control.
Plug your ipod into the docking station and power down (reboot) your ipod. Once the ipod powers down (in the dock) restart the ipod (yes, while in the dock).
Mar 09, 2009 | Teac SR-L200i-W Docking Station for Apple...
Teac GR-10i table radio
The iPod touch for some reoson is not compatible for some reason. I have an iPod touch 2nd gen and it doesn't work. However it does work with other types of iPod.
Jan 15, 2009 | Teac Hi-Fi Radio w/ iPod Dock BLACK...
Teac Hi-Fi Radio w/ iPod Dock BLACK (TEAC-SR-L200I-B) Docking Station Logo
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
