Question about Mantis Tiller
Cord is frozen and tiller won't start
The string that starts my Mantis tiller is "frozen". What can I do to "unfreeze" the line and start the machine?
  • Larry Edwards
    Larry Edwards Jun 07, 2017
    I called Mantis. They said to remove the spark plug and then try. It worked.
Take pull rope cover off and oil the clutch that screws on the crank shaft
Posted on Apr 24, 2009
Mantis tiller won t start
-Clogged fuel line.
Good luck
Aug 09, 2014 | Mantis Garden
Starting manual for mantis
all of the mantis tiller manuals can be found here:
just pick out the appropriate one and away you go.
as far as starting it goes, make sure the switch is set to "I" and not "O" (top handle.) be sure you have gas in it, pull out the choke knob (front of the tiller) and depress the bubble once. pull the engine cord until the machine tries to start, then push in the choke and pull again - the engine should start within a couple of pulls. let it warm up before you try to do any tilling, and you're good to go!
Sep 12, 2012 | Mantis Gas Mini Tillercultivator 2cycle...
MANTIS tiller 7225-00-02 starter cord won't retract
take the crank rope cover off and in between rope reel and cover there is a wind up spring either its broke or has come out of its slots.
Aug 16, 2012 | Mantis Garden
Starter rope hard to pull on mantis tiller
Sounds like your engine may be seized up. Mine did the same thing and I had to replace the block. If any dirt gets past the air cleaner or if your fuel mixture isn't right it won't take long to lock it up. If you need info on where to find parts, let me know. Good luck.
Jun 20, 2012 | Mantis 2-Cycle Tiller
Mantis tiller will not start. Cannot get primer bulb to draw fuel.I replaced all of the lines,primer bulb still won't work. Tiller will start by priming cylinder by removing spark plug. Help?
Make sure there are no leaks in the bulb. Did you reattach the fuel lijnes correctly? You should feel resistance after pushing 3 or 4 times to ensure fuel is getting to the carb. If necessary replace the bulb. Otherwise check with Mantis at or give them a call for troubleshooting assistance.
May 22, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
We have a Mantis electric cultivator that won't start. it's only a couple of years old
Electric tiller, and it will not run ?
I would check the cord that you plug into.
You must remove the plastic housing, by removing the screws.
Next look at the plug, is it in good shape, has anything been pulled out of it ?
The motor brushes should also be inspected.
Please let us know, we repair all Mantis equipment.
Jan 27, 2010 | Mantis Electric Mini Tiller/Cultivator
did it also run out of oil, because it seized like it did you might of burnt the engine
May 31, 2009 | Mantis Tiller
Spring replacement
Replacing the spring on this tiller can be tough. You have to get the tension spring set into the stop and partially wind the tension (by turning the cord pulley) and THEN attach the cord before completing winding the tension spring. It took me about an hour to figure out how much preset of tension was needed before I was able to get it to work. You have to partially preset tension because starting from zero will not fully rewind the cord.
May 23, 2009 | Mantis Little Wonder Tiller/Cultivator...
Motor run but blades don't
mine is doing the same thing
May 14, 2009 | Mantis Tiller
Mantis Tiller Logo
612 people viewed this question
Top Mantis Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
