Question about Fellowes Powershred PS-60 Shredder
Overload overheat - Fellowes Powershred PS-60 Shredder
    Problem Solver:
  • Fellowes Expert
  • 53 Answers
Here is a link to the manual for a Fellowes PS60 Shredder.
Maybe it will help you in resolving some of your problems.
https://app.box.com/s/q3r8jlatlfskvgyh5ne6
Fellowes Shredder PS60
Posted on Dec 13, 2014
My aqua drive 1100 auto reset pool pump runs warm and stops after a few seconds after i switch it on then goes on after a few minutes And this continues. Why
Thermal Overload Switch: Something is creating an overload on the pump. Once it is overworked, the motor will overheat. This will be sensed by the T.O. switch. Once the switch senses that the motor has cooled, it will start again.
Reasons for overload:
  • Bearings no longer spinning freely & without restriction
  • Foreign debris in the volute, jamming against the impeller
  • Failing T.O. switch
Good Luck
Mar 11, 2015 | Aqua Pool & Spa
My compressor comes on for a few seconds, makes a slight humming sound, then quits altogether; any suggestions?
The only thing I can think of is that something is DRAGGING or binding, which "overloads" the motor, and thus causes the thermal overload safety switch [inside the motor] to "open" thus PROTECTING the motor from overheat damage.
The only fix for this is to find, AND ELIMINATE, the drag or bind!!!!!
Jan 16, 2015 | Campbell Hausfeld Extreme Contractor...
Motor runs. Warms up over 10 mins and overloads trip.
feel motor when running if real hot replace pump motor dont forget to replace seals also
Apr 05, 2014 | Pool & Spa
Hayward RS2000 suddenly stops. Motor housing is extremely hot and has a burnt smell. Thermal overload going bad?
it sounds like there may be a short in the pump. this will cause it to overheat and trip the thermal overload. it may be time for a new pump as this is usually cheaper than fixing it
Sep 13, 2013 | Hayward Sp1580x15 Power Flo Lx 1.5hp...
Reciever message in dislay says overload.
Disconnect and reconnect all speaker connections, usually you get and overload when something isn't wired properly. Also make sure your unit well ventilated so that it doesn't overheat. If you still have problems then there could possibly be internal damage that may require electronic repair.
Apr 17, 2011 | Technics Audio Players & Recorders
Door stopped working when I was trying to adjust the door. Blinking yellow light on the overhead unit
The motor has a thermal overload that will turn it off it if starts to overheat. Normally a 15 or 20 minute rest and it will automatically reset. The blinking yellow light may be sending a code. If it blinks 5 times and then pauses and then repeats it is the overload.
Feb 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
Freezer and refrigerator are not working Awoke to defrosted food in freezer and food no longer cold in refriferator
replace the rtc contactor overload on the compressors side body,it supplies current to start and operate the compressor,if the relay on the overload goes bad the compressor will try to run on the start windings and overheat and will not operate to cool the unit properly even if it sounds like its running,it just unplugs from the compressor
Jan 31, 2010 | Refrigerators
Motor will not start
I had the same problem and the solution was to manually press the thermal overload button. The button is located under the tool box next the motor head. I do not believe I tripped the thermal overload during use, but I suppose anything is possible. I’ve been using the compressor in sub 40 deg F. temperatures. I found the following in the Owner’s Manual, but had to look at the part manual to locate the switch.
MOTOR THERMAL OVERLOAD
PROTECTOR: The electric motor
has a manual thermal overload
protector. If the motor overheats
for any reason, the thermal
overload protector will shut off
the motor. Turn pressure switch
to the “off” position and wait for
unit to cool before pushing the
reset button and restarting the
compressor.
Good Luck!
Dec 14, 2008 | Makita MAC5200 Electric Powered Air...
Ativa DQ120D
The mechanism is overloaded. No doubt from debris inside. need to to tak it apart, clean it all up, relube, and reassemble.
Dec 31, 2007 | Universal Office UNV-38961 Shredder
Fellowes Powershred PS-60 Shredder Logo
106 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Jim Keysor
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
