Question about Watches
Popochos watches set up instructions
What battery do you use
Where can i get a replacement battery for a Ohsen wr30m Watch?
In order to help people set the ohsen sport watches easlier in the right way, our company (www.360sportwatches.com) write the ohsen watch manual instruction in English for all the ohsen watch users, hope this page is useful for you to set your ohsen watch, this ohsen watch manual operation is suitable for almost all the Ohsen digital electornic watch, also it is suitable for the ohsen analogue quartz digital electronic sport watches, for details ohsen watches models, please have a look at the following content!
Ohsen watch manuales instruction description:
A Key = Light
B Key = Mode
C Key = Start
D Key = Reset
In normal time to show, press the button to enter B mode, click Settings when choosing D Key respectively, minutes and seconds, C key to adjust.
Hours, minutes, seconds, month, day, week;
12/24 hour clock selection
* Daily Alarm Clock
Daily alarm only " Hours" and " Minutes" to choose
The whole point timekeeping
* Running Seconds
From 0.04 seconds start running time;
The Longest 23 hours 59 minutes 59 seconds
* EL black light
Any mode, press the A light EL backlight for 3 seconds
* Use 3V batteries
Running Second Mode:
Press B button click into the race second mode, press the C key to start timing, the timing of the state, press the D key to pause time;
At the time of state, then C key, stop the clock, press the D key to this state would be zero time.
Press B button to return to normal time mode;
Alarm setting mode:
Regular time mode, press the B button 2 times into the alarm set;
Press C key to the "alarm" whole point of time" to set " open" and "off";
Press D key to adjust the hours, minutes;
Press C button to adjust the number of selected;
Press B tutton to return to normal time statues.
At the same time in any state, this button will issue a Bi Bi sound;
Time, date setting mode:
In normal working mode, press the B button 3 times to see the second in the flashing, then press the C key, " seconds" will be zero;
Press D key to select each "Hour" " Minute" " Day" " Week" set;
Press C key, you can adjust the number;
Press B button to return to normal time status;
12/24 hours;
Under normal travel time; Press B button 3 times to enter time setting mode, then second in the flashing, second place in the transferred into " H" when the table show has been converted to 24 hours system; when the position becomes"O" on the afternoon of adjustments; seconds into "R" for morning; "P" for PM.
Apr 01, 2015 | Watches
Where can i get my casio wave cepter repaired
Yes, it is likely battery is weak.
Take it to a watch repair shop to be replaced, and do not forget to instruct them to reset the watch after battery exchange. Otherwise it will not work properly.
Regards.
TicTacArea.com Casio Official
Casio Watches
Aug 19, 2014 | Watches
Alarm and chime does't work after installing a new battery?
There is sometimes a need to re-set the watch after installing a new battery and there may be an instruction to "short battery to case" inside the watch.
Was the battery changed by a technician or yourself? If the latter, the seek the advice of a friendly local watch repairer, who may be able to sort it out for you.
I have read the instructions for a watch that looks like your (in the Amitron range) but there was no useful information given.
Sep 14, 2010 | Armitron Two Tone Sports Watch
Looking for an instruction manual for a diesel
Hi, I just picked up this same watch from Ebay and it came with a standard diesel operating instruction book. I haven't read it yet, but if you want me to look anything up for you, please ask. As it turned out my watch need new batteries when it arrived, so the jeweller who fitted the batteries set all the functions for me.
Thanks,
Paul
Jun 07, 2010 | Diesel DZ4108 Pocket Watch
Lost my instructions, l'm trying to figure out how to set my Armitron All-Sport WR165 watch
You can get instructions from the Amitron web site.
Copy "www.armitron.com/watch_instructions.asp" into your search engine and you will see a list of illustrations of watches and associated
instructions.
Choose the one that looks like yours and download the PDF file.
Jun 01, 2010 | Bulova Watch
Hi I have a citizen red devils navihawk world time watch. when i change the battery and everything is change and i can not set it. I also lost my manual book and I would lik to have the imformation set my...
You can get instructions from the Citizen web site.
Go to "citizen.com" and on the upper right there is a menu. Click on "technical support" and then on "setting instructions"
Fill in the information required from the back of your watch and then click on "get setting instructions"
or
Go to "citizen.com" and click on "watch finder".
Put your watch model into the search box on the left and click on
"search".
Click on the watch to view details.
On the right is a small menu, click on "get technical info"
On the right you you will see a list of instructions you can download.
Mar 19, 2010 | Citizen Blue Angels Skyhawk Watch
Noblia 12 meter watch setting time? I have no
Noblia are made by Citizen watches and you should go to their web site for instructions.
Feb 23, 2010 | Watches
SET AFTER BATTERY CHANGE
You need to follow the instruction manual after changing the battery.
You can get instructions from the Casio web site.
Go to the casio web site "casio.com".
Select "support" and the "manuals", watches;
Accept terms
Select "watch manual archive"
Read the number of the back of your watch and enter it into the search box
Click on "search" and the download your instructions.
Feb 07, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Setting the time
Dear Sir,
It appears that the watch was malfunctioning which I thought was due to a change of battery being required.
(It was running slow and giving the wrong time - so my mother told me)
I subsequently found instructions for the watch on an internet site, changed the battery and the watch is still failing to set to the U.K. time zone therefore, I deduce that it is a failure in the watch rather than the need for a new battery or ranything I have or have not done.
Please delete my question from your system
Thank you.
Regards
Jan 17, 2009 | Bulova Watch
Klik radio controlled watch
Why would he need the manual to do that ???
The time is self setting !
and to chage the battery just take out the back cover and slide the pin holding the battery in place, and replace it with the with similar battery...
I will try to find the manual for you..
post back in a second
Jan 09, 2008 | Watches
Watches Logo
22 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
