Apple Ipod Video  , Black Digital Media Player
Problem for Apple Ipod Video (80GB) , Black Digital Media Player
My 80gb ipod apple logo want turn off
By frederick305 on Apr 24, 2009
my 80gb ipod apple logo want turn off
Best Solution
posted on Apr 24, 2009
Very Helpful)
mneilsen2084
Rank: Guru  Apple Expert
Rating: 91%, 171 votes
It is most likely frozen I have the steps below on how to reset the ipod. This should resolve your issue completely.
Last Modified: January 28, 2009 Article: HT1320 Old Article: 61705 Summary Learn how to reset or restart iPod following a freeze.
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.
When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time are preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
If this does not resolve your issue please let me know. CHEERS :)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Oct 20, 2009
Not Rated)
bhaskartrip
Rank: Apprentice
Rating: 0%, 0 votes
Whew !!!
It worked for me.
My iPod 80GB was hanged and was displaying a message "Do not disconnect".
The following worked for me :
My friend Atul Rustagi pressed the center wheel with his index finger and MENU button with this thumb for 6-7 seconds.
He was able to reset my iPod 80GB.
-bhaskar
Was this helpful?
Yes
No
Popular Solutions for Apple Ipod Video , Black
Questions and Unsolved Problems for Apple Ipod Video , Black
Do you recommend Apple Ipod Video (80GB) , Black Digital Media Player?
Answer
Answer
my i pod will go dead(blank screen , no response to reset by toggling hold with menu/select switch)... (More)
Answer
hi!,my son's ipod 80gb is locked and dont know the combanation to unlock the ipod
Answer
only getting sound through one earphone tried other headphones same problem
Answer
my ipod will not show up on my pc and i cant get any tunes on it i think the short cut was removed... (More)
Describe your MP3 and Digital Media... problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top MP3 and Digital... Experts
Top Audio & Video Equipment Repairmen
in , CA
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
(785) 842-6626
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
