Question about Fujitsu fi-4120C Path-Through Scanner
I have a fujitsu 4120 scanner that will not pull the paper even after i changed the roller and pad.
    Novelist:
  • 104 Answers
Does the scanner displays any error message on the scanner panel? Is there any TWAIN error message?
If paper jam occurs, U1 error will be displayed on the scanner panel and TWAIN driver will display " Paper jam the ADF (Code DS32002)" error message.
This error is detected when one of the followings occurs:
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner
performs retry operation.)
2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Scan condition Transported length.
In order to assist you with your scanner issue, Please provide the issue details with error message.
If nothing is being displayed, then the issue could be due to failure in Pick Motor function or Pick Sensor malfunction.
Hope the above information is helpful.
Thank you for contacting FixYa.
Regards,
TechSatya
Posted on Aug 01, 2010
    Problem Solver:
  • 10 Answers
First paper sensor.
Any errors posted on led display??
Posted on Jul 06, 2009
Fujitsu fi-5650C Error U1
Hello Ismail,
Error U1 referes to Frequent paper jam in Fujitsu fi-5650c scanner. In order to troubleshoot your scanner issue, you are advised to follow the steps provided below:
1. Do the documents satisfy the paper specification?
2. Have the documents been prepared properly?
- Align the edge of documents for stable paper feeding.
- Remove documents with creases or dog-ear corners.
- Scanning different widths documents may cause skew and result in paper jam.
3. Is the imprinter EXT cable connected to the scanner properly? (only when the imprinter is installed)
4. Clean the Pick roller, the Separation roller, the Brake roller and the Chute roller and see if the error is resolved.
5. Clean the Feed rollers and the Plastic rollers and see if the error is resolved.
6. Replace the Pick roller, the Brake roller and the Chute roller, and see if the error is resolved.
- Check the consumable counter in the software operation panel. When the counter exceeds the values, replace the Pick roller or the Brake roller.
If the above steps do not help, then yuo are recommended to contact the nearest Fujitsu service center for assistance.
Thanks & regads,
ScanCare
Dec 16, 2013 | Fujitsu fi-5750C Flatbed Scanner
We are a medical office that is currently using the fujitsu fi-6110. When scanning documents the feeder is pulling through 2-3 pages at a time and we are not getting all of the documents scanned due to...
Hello Jenny,
Please clean the followings using a cloth/ cleaning paper moistened with iso-propyl alcohol:(Pls refer to page-95 of your scanner getting started guide)
1.Pad Assy 2. Ultrasonic sensor 3. Idler roller 4. Pick roller 5. feed roller 6. Eject roller and 7. Glass surface
If the above doesn't help, then check the Pad Assy & Pick Roller count. If the counts exceeds the suggested replacement cycles, then you you may have to replace the same. Pls refer to page-99 of the getting started guide supplied with your scanner.
Thanks & regards,
ScanCare
Sep 12, 2013 | Fujitsu fi Office Equipment & Supplies
Code DS42003 PAD ASY IN PAPER FEEDER
After you've been scanning for a while with your Fujitsu 6110 or 6130 scanner, you will get a message from the scanner recommending that you replace some of the scanner's consumable parts, such as the pick roller and pad assembly. Although you can ignore these messages, they will keep showing up, even after you have replaced the parts, until you also clear the scanner's page counters in the Software Operation Panel.
http://www.scan123.com/blog/index.cfm/2013/3/15/How-To-Reset-Page-Counters-for-Fujitsu-6110--6130-Scanners
Sep 30, 2010 | Fujitsu fi-5120C
I have a Fujitsu 4220c2 scanner and when scanning multiple documents it'll take one half half/quarter way through and get stuck. The pick roller and pad assembly have been replaced. What could be causing...
Thank you for contacting Fixya.
This error is detected when one of the followings occurs: (TWAIN Error-Paper jammed in the ADF - Code DS32002), Scanner panel error-U1
1) A document does not reach the TOP sensor while the scanner has transported the document about 250 mm to pick. (The scanner performs retry operation.) 2) The trailing edge of a document does not reach the TOP sensor after the scanner transports the document by the length (L) below. (The document may have slipped on the rollers) Check the followings: 1.Scan condition - Transported length (L) before jam 2.ADF fixed size - scanning Approximately 450 mm 3.Long paper scanning -1.2 times of the specified value
If the imprinter is installed, paper jam can occur in the following case. If the scanner starts scanning when the imprinter cable (EXT cable) is not connected to the scanner, it does not rotate the imprinter, since it recognizes the imprinter not installed, which results in paper jam in the imprinter section.
Solution:
Remove the jammed document and close the ADF. When the error frequently occurs, refer to the followings:
1. Do the documents satisfy paper specification? Please read the operator guide for paper specification. 2. Have the documents been jogged? • Align the edge of documents for stable paper feeding. • Remove documents with crease or dog-ear. • Scanning different width of documents may cause skew and result in paper jam. 3. Is the Imprinter EXT cable correctly connected to the scanner? Check the cables. (only when the Imprinter is installed) 4. Clean rollers in ADF and Imprinter and see if the error is removed. (only when the Imprinter is installed) 5. Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the values shown, replace Pick roller or Pad ASY.
If the above do not help, then the issue could be caused by the followings:
6. Malfunction of TOP sensor. 7. Malfunction of Cover open sensor. 8. Faulty Scanner Control PCA.
If Imprinter is installed, then the issue could be caused by the followings:
1. Malfunction of Sensor OPB5 lever (only when the Imprinter is installed). 2. Malfunction of Motor LF if the imprinter roller does not rotate.(only when the Imprinter is installed). 3. Faulty Imprinter Control PCA. (only when the Imprinter is installed).
Hope the above information is helpful.Please revert if you have any doubt.
Regards,
TechSatya
Aug 10, 2010 | Fujitsu ScanPartner fi-4120C2 Path-Through...
The feeder takes several sheets at a time. How do
When ever you face such type of issue, the Scanner will display U-2 error with the Red led blinking and the TWAIN display will be "The multi feed is detected.(Code DS32006)".
To resolve the issue, please follow the steps provided below:
#Check if the documents satisfy paper specification? Please refer to the Operator’s Guide for paper specification, paying
attention to the following points:
• Is there any print within 10mm x 10 mm square in the center of documents on the top?
• Is multi feed error detected by paper length when scanning documents with different length?
• Is there perforation in the center of documents?
#Check ADF and clean pick roller, Pad ASY and around DF sensor with care.
#Replace Pick roller and Pad ASY and see if the error is removed. Check the consumable counter from the TWAIN driver screen. When the counter exceeds the permitted values, replace Pick roller or Pad ASY. If the error still occurs, confirm that the cable is correctly connected then replace the sensor.
Hope the above information will be helpful.
Please revert if you have further queries.
Thanks & regards,
TechSatya
May 06, 2010 | Fujitsu fi-5120C
Fujitsu FI-4220C only scans one page at a time.
The problem is not just to roll over, be changed and separation pad. These two components change very easily and boxes that are delivered and indications for replacement.
These are the codes for parts:
Pad Assembly - Part Number: PA03289-0111
Pick Roller - Part Number: PA03289-0001
After replacement counters to be reset for each Pieces. Open the scanner properties.
Usually have to display a maintenance message on the computer display, such as: separation pad should be replaced.
If there is to scan any messages like that, you have to clean the sensors around the separation pad. They are round and are getting a little inside. Click on the blue button at the top of the ADF and open the lid.
I hope you was helpful.
Aug 10, 2009 | Fujitsu fi-4220C Flatbed Scanner
How to remove Assembly pad message after replacement
you can reset this message in the scanner controll panel.
Please call windows <start>
<settings>
<system control>
<scanner and cameras>
open <scanner and cameras>
inside you will find your fujitsu scanner fi-5120C
now call <attributes>
-- in WIN2000 there is a button, in XP use the right mouse button--
in <device settings> you see the ADF counter, an the consumable counters for pad and pick roller.
Reset the changed parts, confirm the EEPROM writing
and the message will be cleared.
Jun 24, 2008 | Fujitsu fi-5120C
Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
May 29, 2008 | Fujitsu fi-5120C
ADF problem
Thanlk you for contacting Fixya.
#Check if the documents satisfy paper specification? Please refer to the Operator’s Guide for paper specification, paying attention to the following points:
• Is there any print within 10mm x 10 mm square in the center of documents on the top? • Is multi feed error detected by paper length when scanning documents with different length? • Is there perforation in the center of documents?
Thanks & regards,
TechSatya
May 28, 2008 | Fujitsu M3093GX Flatbed Scanner
Paper only feeds midway.
your printer roller r not working properly to service your roller and your printer is working properly
Mar 17, 2008 | Fujitsu ScanSnap S500 Pass-Through...
Fujitsu fi-4120C Path-Through Scanner Logo
1,025 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
