Question about Coby MID7065-8 7" Android 4.0 Tablet; 1.2GHz Dual Core Processor, 1GB RAM, 8GB Internal Storage, microSD Card Slot, 1024x600 Resolution, Capacitive Touchscreen, 0.3MP Webcam, HDMI Port, Google Play Support & USB OTG Compatible
OK, The problem is that I can't switch ON the Tablet at all?even when i connect the Charger (The Display is Black) there is no sign of any power goes to the LCD. I opened the Cover, and test all the Check-Points / Test-points (TP's) and found that all the written Voltages are displayed on the Multimeter. accept the LCD connector where it suppose to get a 3.3V input but i'm getting a 1.2V!!! Does the LCD needs 3.3V or it's working with a 1.2V?? also is there any particular Test Point (TP) for the LCD? I'm getting 0.3V on the LCD-HI & LCD-LO test points?? checked almost all SMD Capacitors but can't see any faulty one. I think the that one of the IC's is faulty which result on not supplying the LCD the needed voltage to turn it ON. was trying hard to Google the Internet for the Schematic-Diagram or Service Manual for the Coby-MID7065 but with no luck. The PCB made on 12-2012 which means its almost NEW PRODUCT, and Bought it one month ago from USA on my holiday. I know, I had to check it while I was their but AHHHH Any help would be appreciated..
    Genius:
  • 1,406 Answers
If you link it to a PC using a USB cable, can the PC see the tablet when you think it should be able to? If you can't get the PC to see the tablet at all via USB, AND the screen never shows any sign of life, then the tablet may be DOA.
You DID charge the battery, right? You're not working with a battery that's on its last legs?
Posted on May 10, 2014
How can I restart my tablet it has just gone black not even showing signs of charging
plug in usb cable an power up /down til it asks to recover it, maybe
be sure charger is working touch to tongue :P
Oct 19, 2014 | Tablets & eReaders
Powering unit up & charging issues.
You need to use the correct charger for your tablet. No fix necessary.
The screen going black is the screen saver, saving you power. No fix required.
Any other issues , take this up with the manufacturers website here Company Contact us
Apr 01, 2014 | Kocaso M752B Dual Camera Android 4.0 OS 7"...
Trying to open a powerpoint presentation that is password protected. How do I open it in a 'read only' status?
Aug 08, 2013 | Coby MID7065-8 7" Android 4.0 Tablet;...
Coby Kryos Android Tablet is not charging. It is connected to a charger but its not charging.
Leave the tablet connected to the charger for 5-10 minutes even if doesn\'t work. Then take out the battery and try with master charger and (switch on the tablet) after that, check whether the previous charger is working again or not again. If it doesn\'t show charging sign, then you have to take it to service center to change the charger connector.
May 21, 2013 | Tablets & eReaders
Turn tablet on, then it says powering off right away.
That would be the charger or the usb port that charger goes into. the red ! battery is saying the battery is dead
Apr 06, 2013 | Google Nexus 7
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
How do i connect a battery charger
I suppose this is what you want to know
The battery charger has 2 leads coming off it as well as the power lead to the external power source .THE TWO LEADS WITH CLAMPS ON GO TO THE BATTERY THE RED GOES TO THE POSITIVE TERMINAL PLUS SIGN AND THE BLACK GOES TO THE NEGATIVE TERMINAL.MINUS SIGN, THE POWER LEAD PLUGS INTO THE POWER. AND THAT IS ALL THERE IS TO IT..
Sep 10, 2009 | 2002 Mitsubishi Lancer
Black out screen dell inspiron 6400
Try to turn on the system with the charger plugged in and also how old is the system.if the system less than a year then try to get the battery changed and may be the motherboard.
Sep 07, 2008 | Dell Inspiron 6400 Notebook
Screen goes black when power cord is plugged in.
Start by checking the power supply with an ohm meter for the proper output. Anything higher or low than one volt means the supply is faulty and will need replaced. This could also be a battery issue, if a fail safe in the battery has engaged. Try removing the battery and see if it works properly on the supply only, if so, then the battery will need replaced. If these two check good, then I'm afraid the problem is with the power management system on the motherboard, and unfortunately the motherboard Will have to be replaced.
Aug 20, 2008 | Dell Inspiron E1505 Notebook
Coby MID7065-8 7" Android 4.0 Tablet; 1.2GHz Dual Core Processor, 1GB RAM, 8GB Internal Storage, microSD Card Slot, 1024x600 Resolution, Capacitive Touchscreen, 0.3MP Webcam, HDMI Port, Google Play Support & USB OTG Compatible Logo
140 people viewed this question
Top Coby Computers & Internet Experts
shadowchb
rey francis basa
rey francis basa
Are you a Coby Computer and Internet Expert? Answer questions, earn points and help others
