Question about Coby Audio Players & Recorders
What do the marks mean on the front - Coby Audio Players & Recorders
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Coby Master
  • 102,366 Answers
What model Coby player?
Posted on Oct 15, 2013
What does it mean when you see an exclamation mark in a 2008 Chevy impala
thats your tire pressure indicator warning light that means one or more of your tires needs air -and looking from photo looks like left front is low it will reset when pressure is met -
Aug 25, 2015 | Cars & Trucks
Need timing marks for 1993 1.6 Toyota Corola camshafts
If its the 1.6litre 4afe. Turn the crankshaft to TDC, ie. Tiny slit on the crank pulley should be straight underneath the 0deg mark. The cams, intake cam is driven off the exhaust cam by means of two gears. Installation marks. They have 4 holes in front of the gears. Front being closest to timing belt. Upon installation one hole in each gear should face upwards and the other holes should face each other between the gears. On the exhaust cam pulley there is a hole drilled through it, ie. timing mark. It should face up. Directly inline with the grove in the first cam cap. If you have 1.6litre 4age engine. Between cam gears and cylinder head there should be a plate. groves in cam gears should face the groves in the the plate.
Oct 19, 2014 | 1993 Toyota Corolla
I need a timing diagram for a 1995 1.9 Ford Escort wagon. thank-you so very much.
you dont,make sure you have the proper replacemend belt at hand. get a very clean cloth and clean the front off gears and look for timing marks look very carefuly they are there, move the crank into position and line the marks on all gears with the marks on the back markings [clean both front and back of plates you will see both markings],reliese the tentioner and remove old belt,replace with new belt and after making sure everything is lined and i mean lined no room for a tooth out reliese tentioner,job done re check until happy replace everything and hope you are ok.adrian,,,ps water pump does not have a marking but should be replaced.
Dec 04, 2010 | 1995 Ford Escort
How do you fix the timing on a 1997 subaru legacy 2.5 gt
IF YOU MEAN TIMING THE BELT , IT HAS MARKS ON THE SPROCKETS - BACK COVER , THE CRANK HAS TWO MARKS ONE UP - ONE THREE A CLOCK . THE FOUR CAMSHAFT SPROCKET HAS MARKS - FROM FRONTimp_up297dohc_dba_uk_8.gif VIEV UPER LEFTimp_up297dohc_dba_uk_6.gif
Oct 12, 2010 | 1997 Subaru Legacy
When connecting the front speakers do the letters L & R mean left & right as I would view them whilst looking at the front panels of the system (eg the display panel)? Or does L & R mean the...
L&R just there to indicate where to put the speaker cables into the speakers and also into your reciever the reciever should have inputs marked with these details
Jul 19, 2010 | Audio Players & Recorders
The light next to the exclamation mark on the front cover is on -- What does this mean?
This means there is a problem with one of your ink cartridges or one is missing. Change the cartridges and it should stop blinking. Hope this helps. Cheers.
Oct 02, 2009 | Lexmark E250dn Laser Printer
What does a symbol mean. it has two kind of perentace marks one on each side with an exclamation mark in the middle and a line across the bottom
its a brake waring light , either your pads or fluid are getting low , get it checked out !! i may be in front of you when you try to stop
Aug 20, 2009 | 2008 Volkswagen New Beetle
My washer is marking LE.What does that mean?
This is a motor overload. Could be too many items in the barrel. I have had this code in the past and took some items out and it went away. I still think there is an underlying issue with the hall sensor or the motor altogether.
Jun 23, 2009 | LG WM-2277HW Front Load Washer
Lightbulb with exclamation mark inside????
This means you have a light buld not working some where in the front or rear lights.When you fix the problem the light will automaticy go out hope this helps.
Jun 03, 2009 | 2001 Volkswagen Jetta TDI
Cant get my printer to the final stages of installation
on mine it means feed paper. what is your printer's brand name? what does the computer say?
Dec 15, 2008 | Computers & Internet
14 people viewed this question
Top Coby Audio Players & Recorders Experts
Gyula Lacz
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
