Question about Kodak APEX Workstation
My Kodak 7000 printer shows mecha 3 error ,pinch
My Kodak 7000 printer shows mecha 3 error ,pinch roller motor is OK I was suggested to replace the control board from another printer and it worked, but I can not find another control board to replace it .Could you help me to buy one?
4 Suggested Answers
SOURCE: kodak printer 6800 mecha error 11
this is error created at ur printers cuter unit , so open the frot cover and clean the all 3 sensors
Posted on Dec 31, 2009
  • 3 Answers
SOURCE: Mecha Error 12 on Kodak Photo 6800 printer
I had a 6850 with the Mecha error 12. No listing in the service guide for this error. I took the front of the printer off and observed that the cut head was not moving far enough to the left to trigger the sensor. I realized that a screw of unkown origin had fallen down behind the cut head and was preventing it from triggering the left sensor. It took a curved pick tool and a pair of tweezers to get it out. I don't recommend taking the cut assembly apart as the alignment is pretty crucial.
Hope this helps some poor sole from the hours of fustration that it gave me.
Randy
Posted on Nov 19, 2010
SOURCE: I am getting a mecha
there are problem in main pinch motor replace it
Posted on Feb 18, 2011
Please help meeeeee i need a solution for error 03 in kodak printer 6800 pleaaaaaaaase help meeeeee
(this is all i can find out about your fault)........the problem is the DC motor at the left side of display.It not does work connecting it to a DC power.......... Mecha error 03
mecha error 03 cant pass that stage you need to replace the pinch motor assembly part number:3F4820RH..
Dec 11, 2016 | Kodak Office Equipment & Supplies
Mecha error 03
Mar 26, 2016 | Kodak 6800 Thermal Photo Printer
Mecha error 03
Hello Rajeev, I am assuming you have a kodak picture printer 6850? if you do the mecha error 03 is the Main Pinch Roll Up error. This could be due to the pinch roller motor failing for some reason. From what I can see it is a common problem with this model. Can you hear the motor running before the error code kicks in? If so the belt or sprocket the turns the roller may have become dislodged or misaligned. If you aren't hearing anything suspicious then the motor itself may have failed and is no longer functioning. If this is the case contact kodak and look for a service agent in your area you may take the unit too.
www.kodak.com
Oct 15, 2015 | Office Equipment & Supplies
What is main pinch motor
Change this part. Main pinch motor on the left hand side the Centre motor.
Jul 15, 2014 | Kodak 6800 Thermal Photo Printer
Kodak mecha error 003
"Mechanical error 3"
The pinch roller motor is faulty.
Apr 19, 2014 | Kodak Photo Printer 6850 Thermal
MECHA ERROR 003
i need best solution for mecha error 03 kodak printer 6800
Mar 15, 2010 | Kodak 6800 Thermal Photo Printer
Mecha error o3
Mecha error 03 is a malfunction of the main pinch motor. Ninety-Five percent of the time the problem is that the motor has failed. The machine will more than likely have to be sent in for maintenance.
Nov 27, 2008 | Kodak 6800 Thermal Photo Printer
Mecha error 07
Mecha error 07 and 08 are malfunctions of the paper feed pinch motor located in the right side of the paper compartment. The paper feed pinch is the first roller to grab the paper when it feeds into the machine. This error is tricky. I will walk you through a few fixes.
The first fix is to just power cycle the printer and try to reload the paper. Occasionally the pinch arm will end up in the wrong position due to the printer stopping because the ribbon was empty.
The second fix is to check and make sure that the sensor arm is reaching both sensors on the motor. Sometimes the arm binds on the metal plate inside the paper compartment causing it to not reach the sensor.
The third fix is to start replacing parts. The two things to start with would be the sensors and, although rare, the motor itself. After those are ruled out the only other options are the wiring harness running from the sensors to the junction board, the junction board itself, the power cable running from the junction board to the controller board, and then finally the controller board itself.
Sep 29, 2008 | Kodak 6800 Thermal Photo Printer
Kodak APEX Workstation Logo
98 people viewed this question
Top Kodak Computers & Internet Experts
Andrew Taylor
Andrew Taylor
gaucherre
Are you a Kodak Computer and Internet Expert? Answer questions, earn points and help others
