Question about Seca 876 Flat Scale With Integrated Display
My Seca 876 bathroom scale is showing an "Er 12" on the display. How do I fix this?
3 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: Hi i have a Seca
Hi pethkars,
You may do the following to helps you solve the issue with the Error that you are getting:
1. Switch off the scale with the Start key and start the scale again. The scale will then
work normally again.
2. If this is not the case, disconnect the power supply by briefly removing the batteries.
If this measure is equally unsuccessful, the last option you have is to inform the Service department. This will require advance troubleshooting that only people from Seca can provide. You may reach them through this.
Hope this helps.
Thank you for using FixYa.
Posted on Sep 19, 2011
SOURCE: I have a Seca 703
This could be a power issue. Make sure your battery pack wire connections are good. If they are loose, I suggest purchasing the Seca 400 power adapter, which works with this model.
Posted on Jun 14, 2012
Seca 769 error code e.10.11
showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
I have a Seca 703 digital scales, When I turn on it says Er:1:40 Can you help me?
Sep 18, 2011 | Seca 769 Digital Scale 400 Lb with Bmi and...
Er: 1: 11 appears anytime anyone tries to weigh themselves.
I do not know this particular scale, but you might try this solution that works with many electronic scales. To activate the scale, lightly tap the scale, placing enough weight on the scale to initiate the electronic process. (A foot tap will do.) Wait for the display to show 0000 (or whatever the ready state display of your unit is), and THEN step on the scale.
Mar 03, 2011 | Seca 780 Robust Digital Column Scale /...
HealthSmart bathroom scale displays "Err"
Put scale in round file can. Buy another cheap scale.
Oct 03, 2009 | Dmm Elscale Healthsmart Glass Electronic...
Weight Watchers bathroom scale, Model WW60X
I got it! Press "set". You should see "start goal" in the bottom right. Press the user # you want to save as and press "set" again. The display will blink then display "0.0". Step on the scale to get your current weight. Once it's read you current weight, press "set". A goal weight will display. Press "User 1" to make your goal weight go up and "User 2" to make it go down. Press "set" when the display shows your goal weight. That's it. Now all you have to do is press your user # and wait for "0.0" to display before stepping on the scale.
Apr 24, 2009 | Conair WW60 Weightwatchers Scale
I have lost my instructions for my Salter glass bathroom scales 9103. I have a EE on the digital mode what does this mean and what can I do to fix it so the correct weight shows
The scales display EE as they are reading a negative weight.
With the scales switched OFF place 2 glass plates on the scales and press ON.
The scales should now display 0g.
If this doesn't work add more weight and try again.
There is also 4 screws on the underside of the scales which hold the weighing bar in place, if you loosen the 2 smaller screws this should relieve some of the stress so less weight is needed to zero the scales.
Jan 26, 2009 | Salter Stainless Steel Electronic Bathroom...
Err 12 and Err 16
Dear FixYA
Was advised to send to Scales to another company to be fixed. Therefore no longer need your assistance.
Thank you
Julia
Jan 22, 2009 | Seca 354 Digital Baby Scale Pediatric...
Seca 876 Flat Scale With Integrated Display Logo
275 people viewed this question
Top Seca Health & Beauty Experts
pawnpower
Jaye t rock
Tom Chichester
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
