Question about Cooktops
I have a Wolf stovetop. When I turn the gas on for one burner, the other three start a clicking noise like they are trying to ignite too. How do I solve this?
  • cranork Apr 24, 2009
    Okay, surely I am not going to pay $10. for you to tell me to call someone else. I called them and they told me to call an appliance company to come and look at it and fix it. Please refund my cc or don't charge me. Thanks
  • 15,935 Answers
On a gas stovetop - ALL igniters spark - and the only one that actually lights is the one you have selected by turning the knob.
If they all are sparking, your oven is working normally.
Thanks for using FixYa - if you require further clarification about your question - please use the "Continue with this expert" option.
Thank You:D
Posted on Apr 24, 2009
  • 483 Answers
Wolf has very good maintainance support over the phone, i would suggest you calling them up as this has something to do with the security of you & your kitchen.
Call them up on : 800.332.9513
http://www.wolfappliance.com/constantcare/contactus.aspx
Thanks
Fame !
Even after the burners are lit they keep on trying to ignite, sometimes all four will be clicking.
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Aug 31, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
We can't turn off the igniter on our gas cook top
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
heatman101
Mar 27, 2011 | Wolf Range RHP-6-36 12 in. Gas Cooktop
I have a Wolf gourmet 30" stove. it's about 10
Interesting, I'm looking for a solution to a similar issue. Our new (7 month old) 30'' Wolf Range has this issue. When both front burners are light, the back burner's electronic starter begins to click, but only when you put a pan on the front left burner. I believe the iron/steel in the pan is causing a magnetic field thats starting the rear burner to go off.. just don't know.. will report back after the repair person comes.
Jan 22, 2011 | Wolf Range 18 in. SPR-100 Gas Cooktop
Igniters click constantly when the gas is selected off
heatman101
Sep 26, 2010 | Wolf Range 18 in. SPR-100 Gas Cooktop
Starter clicks but doesn't light burner
either the gas valve for that particular burner isnt opening,or if all burners are like this then the dual valve that feeds the broiler and stovetop has a bad stove top side of valve portion its underneath the oven cavity behind the lower pan drawer
Jul 31, 2010 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Creda stovetop tries to light without gas on.
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 28, 2010 | Creda Colonial 42352 23 in. Electric...
When you turn the burner on, it makes a popping noise and will not stop.
You're gas burner has an electronic ignition that you're hearing. Sometimes they can get gunked up and become sticky. If you have been using the stovetop regularly and this problem suddenly appeared, we can assume that the power grounding and polarity are correct. If this is all true, then an igniter or igniters are either wet or dirty. Unplug the electricity and thoroughly clean the burner pieces and specifically the igniters (little separate cylinder next to each burner) with a sponge or other non-abrasive dishrag and hot soapy water. Make sure all the burners and igniters are completley dry, plug unit back into electric outlet. If problem persists,call an authorized repair person as you may need 1 or more igniters replaced.
Good luck
Jan 11, 2010 | Viking Pro Series VGRT3626B (Gas)...
Gas stovetop burner - continuous clicking
WHEN CLEANING YOUR BURNERS YOU HAVE PROBABLY MOVED THE IRON TOPS-READJUST AND YOU WILL FIND THE CLICKING WILL STOP.
Sep 18, 2008 | Cooktops
Gas cooktop BOOM
Gas is taking too long to ignite. Make sure the burner rings are installed properly. They have grooves that need to line up. Also make sure all the holes are clean.
Apr 03, 2008 | Cooktops
Wolf range cooktop
I just installed a Wolf gas cooktop and had the same problem in that all 4 burners would light just fine but the electronic igniters would not stop clicking on all four. What I found was that the electrical outlet that my gas cooktop was plugged into had the polarity reversed. I tested the outlet with a polarity testing module (you can get one at Home Depot and it checks polarity, grounding, GFI and is handy to have around, small and inexpensive). I plugged it in and the lights told me that the polarity was reversed. I reversed the wires in the outlet (exchanged the white and black wires) put the cover back on, plugged in the cook top and now it works like a champ! no more constant clicking. By the way, we had a cooktop before this one with electronic ignition and never had a problem, apparently it didn't care about the polarity.
Nov 10, 2007 | Wolf Range 18 in. SPR-100 Gas Cooktop
Cooktops Logo
79 people viewed this question
Top Cooktops Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
