Question about Dremel 300-N/55 300 Series Tool Kit
Stopped working dremel 3000 stopped working
You can change to any bit, but have to change the compression collar inside the end of the shaft. For example if the tool shaft size is 1/8" you need to use the 1/8" collar etc. Make sure you use the corresponding bit with the corresponding compression shaft size or the bit will not lock in position when you tighten the collar.
Aug 10, 2014 | Dremel Tools & Hardware - Others
Why has my dremel 6000 just stopped working could it be the brushes
Although Supergrit Abrasives in Gettysburg, PA sells the sleeves and the Hook & Loop diamonds for use with the Dremel 6000, we do not repair tools. The 6000 is discontinued, but you can probably buy a used one that works on Ebay.
Jun 14, 2014 | Dremel 6000 Contour Sander
Dremel 3000 just quit while using. it seemed as if it were unplugged from wall plug
try installing a new set of brushes in it i have fixed mine lots of times by doing just this !!! new brushes are sold where ever real dremel tools and bits are sold ck package back for your model number
Apr 19, 2014 | Dremel Tools & Hardware - Others
Dremel 3000 stopped
My Dremel 3000 suddenly stopped working also. No idea where the receipt was so i decided to investigate. I found one of the two stator windings had blown. I'd Barely used the thing, so that's the last dremel I'll be wasting my money on.
Feb 01, 2014 | Dremel Tools & Hardware - Others
Dremel MultiMax 6300 has stoped working Will not turn on.
Mine died also. It's the on off switch. Where can I get parts?
Oct 27, 2011 | Tools & Hardware - Others
Will useing an extention cord afect the dremel mutimax i had one quit on me orderd a new one and that one did same thing on the same day and the cord i am using is lager than the one on the dremel and is...
Sounds like you have a voltage prob at the wall recepticle. Use a VOM.and check the voltage at the wall at diferent recepticles as you may have loose srrews. Loose screw on the recepticle can raise the ampraga and kill your unit.....
Jan 21, 2011 | Dremel Multi Max Kit
I own a Dremel model 395 type 5 variable speed and it suddenly stopped working. I was wondering if it was common for the switches to go bad or if it's known for other parts to cause it not to turn on.
I would recommend going to Dremel.com and asking their tech section about this. I have one also and mine works fine other than a small amount of heat at the spindle area.
Jun 17, 2009 | Dremel 395 Variable Speed Multipro Rotary...
New Dremel 300 stopped working. What's wrong?
Something amazing just happened! On my monitor screen, window popped up that said, "ASK A QUESTION - LET OUR EXPERTS SOLVE YOUR PROBLEM FOR FREE".
I couldn't resist getting expert advice for free, so I clicked on the window. I was immediately taken to a magical world where I can pay for expert advice. I opted not to pay for expert advice. The next day, I was asked if the help I received was helpful. So here I am posting this response. I haven't received any expert advice yet, but when I do....!
Jun 14, 2009 | Dremel 395 Variable Speed Multipro Rotary...
Dremel 400 xpr stopped working. checked brushes looked ok but replaced with new ones. still not working. tool is still fairly new with only light to medium use.
It could be the fuse between the brush and variable speed control switch. I have the same problem and found the fuse blown. I am hoping that I can replace the fuse without having to buy the complete speed control unit which is about $17.00 from Dremel. If yours is still under warranty you could send it back. If I can find a fuse for mine I will let you know where to get them. joatmontag
Mar 31, 2009 | Dremel 400 Xpr Rotary Tool
Dremel 300-N/55  300 Series Tool Kit Logo
44 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
