Question about Intel Motherboard
Need front panel pinout for Compaq Presario motherboard 5000a5bw31350000tr5bw5000xx
wayneard
  • 1901 Answers
SOURCE: I need the front panel pinout for an Emachine T2984 motherboard
Here is the pinout for several Intel MB's with 845GV Chipset.
Posted on Mar 18, 2009
SOURCE: I need the settings for the front panel connectors.
just visit the following link which has the manual to your motherboard. download and look for front panel settings in the pdf file.
hope this helps
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&ProductID=1065&DwnldID=15210&strOSs=109&OSFullName=Windows*%20XP%20Professional%20x64%20Edition&lang=eng
Posted on Apr 21, 2009
sgtsnake
  • 23 Answers
SOURCE: d845dpi motherboard manual needed
See if this helps. It's for the D845EPI, and I know it's not the DPI, but that's closer than the D845gvsr.
Posted on Sep 12, 2009
asnowman
  • 788 Answers
SOURCE: pinout for front panel
Haveing the Model number of the Intel board would help. We need this information to help you.
Please reply to this post, and I will get you the information that you need. I think that Intel boards are the best.
asnowman
Posted on Apr 12, 2010
Fans come on 4a second and shut off wont boot
Thank You For Posting
The "fan twitch" you're seeing is a nearly certain proof there is a short circuit somewhere. It could be the PSU, it could the the motherboard, or anything directly connected to either or both of them.
You need to reduce your machine to PSU + motherboard (out of the case/on the table) + CPU (with heatsink of course) + one stick of RAM + video card (if there is no integrated graphics). Reset CMOS, re-seat your CPU, cleaning the old and applying a new coat of thermal paste as needed, re-seat RAM and a video card if needed, then try turning the machine on. You can use a screwdriver head to short the power-on pins on the front panel pinout of the motherboard, if it doesn't have a dedicated power-on button on it.
If it still just twitches the CPU heatsink fan, remove graphics card (if you used one), connect a speaker to the front panel pinout (if the board doesn't have an integrated speaker/buzzer on it) and listen for an error code. If you didn't need a video card (have onboard/integrated), then remove the RAM stick and listen for an error code, if the machine even starts.
Reducing this to PSU + motherboard + CPU problem, means you should try a different PSU. If the machine still doesn't spin the fan, your motherboard is shorted somewhere, probably the VRM.
Thank You For Using Flixya and expected to see again
Jun 03, 2014 | HP Compaq Presario SR5050NX PC Desktop
Hp e93839
~Somewhere, over the rainbow~
My understanding by a search on the internet, is that the HP XW4600, uses a version of an Intel X38 motherboard, and has the ID numbers - model fmb-0702 - on it, as well as - e93839 -
http://h30499.www3.hp.com/t5/Workstations-z-series-xw-series/XW4600-Motherboard-Control-Panel-Schematic/td-p/1007169
7th post down, - jondvd - 09-28-2008
http://www.ebay.com/itm/HP-XW4600-Motherboard-441449-001-441418-001-/360653087990?pt=Motherboards&hash=item53f89964f6
If this holds to be true, the BLUE header, below the CMOS battery, and close to the outside edge of the motherboard, is ONE USB header.
Indicates Internal.
The Yellow header to the right of it, is the Front Panel USB header.
EACH USB header has contact pins on it, for TWO USB ports.
Does not matter which USB header we are talking about here, on that motherboard.
To identify the pinout, look for the missing pin in the header.
This is the KEY pin.
http://www.motherboardpoint.com/front-usb-pinout-compaq-evo-d310-t153627.html
http://pinouts.ws/usb-pinout.html
Regards,
joecoolvette
May 14, 2013 | Computers & Internet
Compaq system board 686,0MB (320756) board manual
That's an old mainboard (Motherboard), used in a Compaq Presario 5716 desktop computer. (And perhaps a few other Compaq Presario's)
1) Uses a Slot 1 (Intel) processor slot.
http://en.wikipedia.org/wiki/Slot_1
2) Maximum Intel Slot 1 processor that can be used, is an Intel Pentium III, with a 100MegaHertz Front Side Bus. (100MHz FSB)
Maximum frequency rate for the processor is 700MHz.
('Speed')
http://www.cpu-world.com/CPUs/Pentium-III/TYPE-Pentium%20III%20%28Katmai%29.html
(Scroll the page down)
3) Ram memory is SDR Sdram at 100MHz. Or also known as PC-100. (168 pin. 82 on each side. Two Locating Notches on bottom. Commonly just known as Sdram, but that is a misnomer)
http://en.wikipedia.org/wiki/PC100
Maximum TOTAL Amount of ram memory is 384MegaByte.
Maximum Amount for each ram memory slot is 128MB.
There are 3 ram memory slots.
4) Do not know what the jumper settings on the motherboard are.
5) Do not know what the Front Panel header pinout is.
6) Can run Windows XP Home Edition, but do not expect a world of performance.
Regards,
joecoolvette
Jun 10, 2012 | Compaq Computers & Internet
Asus P5LP-LE Motherboard Front Panel Pinouts
N/C Reset Gnd HDLED- HDLED+
GND PWR PWLED- PWLED+
Mar 11, 2010 | ASUS P5LP-LE Motherboard
Bad front USB ports on a Compaq Presario 5000
please re-insert the cable of the usb to the motherboard. i believe that there are 4 pins on usb1. now if this usb1 doesn't work, try the usb2. be careful when inserting the cable.
Mar 05, 2010 | Compaq Presario 5000 PC Desktop
I need a diagram that shows the pinout for front panel audio.
Could you be less specific as to what motherboard and front-panel, and why you couldn't download the manual from the maker if you pitched it out?
Then, to be sure, get a DVM with small probes, set it on continuity, and confirm the pinout.
Aug 24, 2009 | Computers & Internet
I need the pinout for the Panel 2 connector Shuttle MV43V v7.3
Hi mrdcoe,
Here's the pinout you needed.
If you need more information about your motherboard, you can always download the manual from this link,
http://eu.shuttle.com/download/Archive/Manuals/en/mv43p_n/mv43pen.zip
Good luck,
Don't forget to rate my solution, thanks!!!
Jan 15, 2009 | Shuttle MV43VN Motherboard
Intel Motherboard Logo
50 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
