Question about Hardware & Accessories
TDC power DA-150-12w-1 will not turn off - Hardware & Accessories
IVE GOT TDC on #1 now do I put the distributer rotor pointing toward #1?
It depends which tdc ... Remember that the piston will be at TDC on both the compression and exhaust stroke.
If you turn a distributor to point the rotor rotor arm at no 1 terminal on the exhaust stroke, your timing is 180 degrees out.
Other wise yes, point the rotor arm at No1 terminal.
To check which TDC it is.. place your finger over the no 1 spark plug hole and get somebody to turn the engine for you. You'll feel the compression build up.
Mar 11, 2016 | Cars & Trucks
How do you program a da-150-12w-1?
150 Watt Transformer TDC Power DA-150-12W-1 - eBay
www.ebay.com > ... > Outdoor Lighting > Walkway & Path Lights
eBay150 Watt Transformer TDC Power DA-150-12W-1 in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting, Walkway & Path Lights ' eBay.
New Free SHIP TDC Power Da 150 12W 1 Low ... - eBay
www.ebay.com > ... > Outdoor Lighting > Other Outdoor Lighting
eBayNew, Free Ship, TDC Power DA-150-12W-1 Low Voltage Transformer, 12v 150watt Max in Home & Garden, Yard, Garden & Outdoor Living, Outdoor Lighting ...
[PDF]SECTION H - Etlin
www.etlin.com/pdfs/Outdoor_Transformers.pdf
1-800-661-9610 (Canada) 1-888-762-5384 (USA). OUTDOOR LOW ... DA-XX-12WSeries - 60 to 150VA Small Case Low Voltage Outdoor Transformers.
Da-150-12w-1 Manual ' downloadthingsfast.com
Dec 09, 2015 | Malibu Hardware & Accessories
Does anyone know97 Honda Odyssey with code P1361 Tdc?
P-Power Train
1-Manufacturer Specified Code (Honda)
3-Ignition System, Misfire
6-Component or Sub-System Section
1-Component or Sub-System Section
P1361 is: Intermittent Interruption In TDC 1 Sensor Circuit.
Check out the TDC sensor, connector 124 (grey and on the distributor) check power and grounds. It's missing a signal from the TDC sensor in the distributor and causing a misfire.
Oct 24, 2014 | 1997 Honda Odyssey
TDC low voltage transformer model DA 150 12 W reset button trips
There is a short circuit.
Copy following link to identify possible problem and download manual
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
May 02, 2012 | Hardware & Accessories
Where does distributor rotor point for tdc
You can't use a distributor to find TDC. To find it you have to turn the engine over until the timing mark on the harmonic balancer ( bottom pulley) lines up with the 0 on the metal tab on the timing cover. When these 2 marks are lined up that is TDC.
HOWEVER, the crank makes 2 turns to every 1 turn of the camshaft so you hit TDC twice. To make sure that you are right you must remove the valve cover and watch the valves as you turn the engine. The proper thing to see is the intake valve ( farthest from the exhaust manifold) open and starting to close as you come up on TDC. As you go past TDC the exhaust valve (closest to the manifold) will start to open. If this is not what you see turn the engine over 1 complete turn to line up the timing marks again. At this point, where the rotor button points is #1 spark plug.
#1 piston, on a GM is always at the front of the motor. If you have a V6 or V8 then #1 will be at the front on the driver's side of the engine. On a 4 cylinder it will the first cylinder. Hope this helps.
Aug 29, 2011 | 1996 Chevrolet S-10 Pickup
I had to replace a cam and rockers on my 97 3.0 dodge caravan. its in time. we are on top dead center and the distributer in all lined up. still wont start! What could the problem be?
Is it cranking over fast enough? If you are trying to start an engine that also was drained of all fluids, it usually needs a little more power to crank over fast enough the first time. Try "jumping" it with another vehicle to make sure it is cranking over fast enough. What exactly is happening when you try to start it?
Benjamin
Nov 04, 2010 | 1997 Dodge Grand Caravan
Need to know how to time honda harmony tiller
well
heres your 4 strokes
1 intake down
2 compress up
3 power stroke down
4 exhaust up
if you start with you start with the piston just a couple of degrees past TDC (top dead center) so that it has started its return down
now set the valves so they are closed:
if you have an adjustable valve clearance's then your clearances should be noticeable like 10 thousands ( you should be able to move the lifter ( rocker arm ) and it will be loose up and down
with the spark plug still out; so you can see the piston coming to TDC and passing it to come down
turn the flywheel and watch the strokes and the condition of the valves
1 just past tdc, the intake valve opens and the piston goes down for the intake stroke
2. jst as the piston comes around BDC the intake valve should close and return to tdc with all valves closed ( the compression stroke )
3 just past TDC the ignition will fire and the piston will return down with both valves closed( the power stroke)
4 just past BDC the exhaust valve opend , the piston travels up and completes the exgaust stroke.
and after completing the exhause stroke and arriving at tdc the intake valve opens and you start over again 1,2,3,4
Apr 14, 2009 | Honda Garden
Put new piston rings in but dont know the timming marks for it does anyone know
Here is the manual which should give you all you need regarding your bike so rate me if it helps you thanks....
http://www.husqvarnaracingclub.cz/images/home/ohqv/manualy/2003/Workshop/2003%20TE610E-SM610S.pdf
TDC spark 0 deg
exhaust opens: 91deg [89 deg before BDC]
BDC 180 deg [1/2 turn]
intake opens: 310 deg [50 deg before TDC]
TDC lost spark: 360 deg [1 turn]
exhaust closes: 400 deg [40 deg after TDC]
BDC 540 deg [1 1/2 turns]
intake closes: 617 deg [77 deg before TDC]
TDC spark 720 deg = 0 deg [2 turns]
here are some important couple of links...
http://www.advrider.com/forums/showthread.php?t=141762&highlight=Husky+Husqvarna
more on proper nut and bolt securing.....
http://www.advrider.com/forums/showthread.php?t=156429&page=244
Apr 02, 2009 | 2000 Husqvarna TE 610
Power transformer broke
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Jan 05, 2009 | Tech Solution TS-4500 Shredder
Hardware & Accessories Logo
81 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
