Question about Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504
Small leaks in the seam of sloan flushmate. replace the entire unit?
3 Suggested Answers
  • 62 Answers
SOURCE: I have a Sloan Flushmate, Model #M-101526-F3. The
Absolutely not! Because these tanks have air pressure inside them, a leaking tank could explode with such force that the toilet can be destroyed and someone could get hurt. It does happen. Replace the flushmate tank is the only safe solution
Posted on Jul 11, 2009
kjlhbwretvgr
Absolutely not! Because these tanks have air pressure inside them, and you can hurt yourself or somebody else. You need to get new one... take a look here Amazon com Sloan Flushmate tank. I hope this was helpful. cheers
Posted on Nov 29, 2014
I have a sloan toilet model M-101526/ it leaks out of top of tank when i flush it
Depending on the nature and source of the leak, it may be a maintenance issue or you may need to replace a component or the complete system.
You can find troubleshooting procedures, owner's manuals, etc., at www.flushmate.com.
For best results, jot down the serial number and toll-free phone number located on the Flushmate label and call Flushmate between 8:00 AM and 4:30 PM ET (Mon - Fri) for assistance.
Mar 18, 2013 | Sloan M-101526-F Flushmate?® Complete...
Sloan flushmate is spraying water up in tank
Best chance of solving your specific problem would be to jot down the serial number and call Flushmate Tech Support at 800-533-3460 (M-F, 8 - 4:30 ET).
Best of luck!
Jun 13, 2012 | Sloan M-101526-F31 Flushmate?® Complete...
We have sloan flushmate. Can`t remove the tank to fix leak.
Not sure exactly what you mean. Are you saying you can't get the tank-to-bowl nuts off due to corrosion or that you can't loosen the two plastic locknuts that hold the Flushmate in the porcelain tank?
If the tank-to-bowl nuts are corroded and you can't turn them, you may have to use a hacksaw or reciprocating saw to cut them off and replace them with a new set when you remount the porcelain tanks.
Unless they were cross-threaded at installation, the Flushmate locknuts are pretty easy to remove.
If the Flushmate tank is leaking it will need to be replaced as they can't be patched. If a component is leaking, replacing it is viable.
For more information view the videos at http://howto.flushmate.com
Hope this helps.
Sep 04, 2011 | Eljer Home
Flushmate Ser. 503 has a leak. how do I change it???
please explain: do you mean leaking into the tank or running into the bowl?
Jul 27, 2011 | Sloan M-101526-F42 Flushmate?® Complete...
Sloan Flushmate M-101526-F3-Constant Filling
There is a lifetime warranty on the tank and a ten year warranty on parts. Call flushmate and ask. they will not tell you otherwise.
If you use any chemicals in the tank it will void the warranty.
Sep 25, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Jul 10, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
My sloan flushmate toil I think is backiing up. When I take the lid off and flush the toilet water shoots out the front side of the flushmate. What could the problem be or is it broken.
You may have a leak in the discharge extension, lower supply, or drain valve. I suggest you call Flushmate's tech support line (on the Flushmate label) and see if they can help you out.
Good luck
Apr 14, 2009 | Sloan M-101526-F42 Flushmate?® Complete...
Sloan M-101526-F42 Flushmate?® Complete Replacement System for FM IV 504 Logo
41 people viewed this question
Top Sloan Home Experts
richochet
ray gallant
Ted Maxwell
Are you a Sloan Home Expert? Answer questions, earn points and help others
