Question about Zodiac Pacer Pool Cleaner
At the end of summer our Zodiac ran for about 5 minutes and then stopped.We got the pool-guys out and they said the underground pipes had a leak,they dug it all up and replaced.The Zodiac did the same.Then they said it was because of the muck on the bottom.We vacuumed that all out.(Including all the stones they dropped in the pool)replaced the diaphram and all the pipes.If I start the pump there is a lot of suction that then seems to peter out,and everything stops.Obviously the guys who diagnosed and replaced the pipes now is less than willing to help.Any suggestions?We are at a complete loss as what to do next.
    Scholar:
  • 80 Answers
Sad ??.
Home water pressure runs 60-80#, which a sound plumbing system should handle. Can you get into your plumbing where there is a straight shot to the pool, rig an adapter and try to back flush into the pool?
I presume your filter is clear (low pressure drop on gauge).
Posted on Apr 14, 2017
2 Suggested Answers
jharwell668
  • 640 Answers
SOURCE: zodiac pool cleaner stops and starts and sometimes
With these pool cleaners, there are several things that can cause a lack of suction and movement. Make sure that the main drain and all suction lines are closed except the line you are using. Make sure there is no debris in the flapper or filter that could be clogging suction. Check the hose are ensure that there are no leaks. Check the pump basket for looseness, cracks, and worn or missing o-rings.
Posted on Oct 28, 2010
Pool pump problem: Cavitation sound in spite of no blockages in suction lines. Replaced many parts and replumbed with no success.
me id make a temporary suction line that could be dropped right in the pool (half union,suction hose with brick tied on end) this would easy test the underground pipes/valves for any spider cracks (air inlets) observe the output using the ole pump if no improvement then sorry that ole pumps gotta go
frequently on old installs I find that winter weather wasn't so kind to the plastic pipes and they develop spider cracks(tiny ) this provides a path to suck air into line
Oct 20, 2015 | Pool & Spa
Zodiac G3 stopped traveling even though there is good suction.
There are several things that you can check on these pool cleaners if you are sure that the suction is not a problem. Normally, I would start by suggesting you check for blockages and obstructions in the cleaner, filter, and skimmer. However, if you are getting the correct suction, this shouldn't be a problem. I would also check the diaphragm for damage. To adjust a worn diaphragm, loosen the cassette swivel, gently push down on the the inner pipe, and retighten the cassette swivel. Check all hose sections for leaks by lifting each section above water.
Mar 06, 2011 | Zodiac Baracuda G3 Automatic In Ground...
When I turn on the pool, the pacer works for about 5 minutes then just gets stuck on the wall. If I turn off the pool and reset, it starts again then stops. How can I decrease the suction or adjust the...
You need to use the Pool Pulse feature to control the flow of water through the cleaner. Here is a brief overview, but if you need more details, consult page 6 of the users manual for this pool cleaner (below if you don't have it).
"Remove the cleaner head. Attach the Pool Pulse to the end of the hose and keep it under water. Turn on the filtration system.
• For pools with one skimmer, flow is automatically regulated by the Flowkeeper Valve. Insure the blue indicator of the Pool Pulse is in the ideal range (when viewed from the side).
• For pools with two or more skimmers, leave the selected skimmer open and slowly close the other skimmer(s) until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
• For pools with a wall vacuum fitting, leave the wall vacuum fitting fully open and slowly close the skimmer valve until the blue indicator of the Pool Pulse moves into the ideal range (when viewed from the side).
Keeping the hose under water, remove the Pool Pulse. Submerge the cleaner head, and when the bubbles stop coming from the extension pipe, attach the hose end. Your installation is now complete."
http://www.baracuda.com/resources/manuals/PacerW83410.pdf
Dec 05, 2010 | Zodiac Pacer Pool Cleaner
Our barracuda stops functioning after only working for a couple of minutes. I have noticed that there are air bubbles coming from the return outlet. I have checked the barracuda for blockages and cleared...
Before you go anywhere I would check each piece of hose for leaks. If they are all OK then you need to plug off one end of the suction line and pressure it up at the other end. If the pressure drops then you have a leak in the line. I would check the fitting at the front of the pump first. Short of a cracked pipe that is where most suction leaks occur. This being a vinyl liner pool it could also be just behind the wall also.
If the hoses are Ok and it's not at the front of the pump you may want to get a leak detection service in to help find it. Good luck.
Oct 29, 2010 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac pool cleaner stops and starts and sometimes just stops working completely. Checked diaphram. replaced it with a new one. pool is forever getting green ... at my wits end... bout to pull my hair...
Aug 21, 2010 | Zodiac Pacer Pool Cleaner
My Baracuda Zodiac works for a few minutes and
check the diaphragm for debris, damage, or deformity. unthread the collar above the handle and push the tube downward. Inspect the rubber diaphragm, any damage or deformity will cause erratic behavior.
Apr 07, 2010 | Zodiac Baracuda G3 Automatic In Ground...
I have a Sta-Rite Max-E-Glas II (1.5hp) Pool pump and a Hayward Navigator sweep. The sweep was working then stopped. Pulled it apart found bad bearings replaced them. Ran sweep again worked at first...
Is the pump leaking water? If you lost the prime or are having trouble priming then there would be an air leak somewhere on the suction side of the pump. Poor suction would interfere with the sweep. One way to ell if the pump or suction line(s) are leaking is to examine the inlet basket once the pump is primed. Any air left in there after a few minutes of operation once primed would indicate a leak in the suction/pump.
Jan 04, 2010 | Zodiac BARRACUDA G3 IN-GRND CLEANER
The zodiac works for seveal minutes, then the pool pressure goes down and the zodiac stops. when i remove the vac hose from the vac intake the pool pressure returns. i hav cleared the zodiac and ck each...
sounds like you may have an air leak somewhere. If not from your zodiac hose, it may be in the plumbing itself. Check the threaded fitting on the suction side of the pump, check the pump lid o-ring, and depending on the pump, check the gasket between the hair/lint pot and the volute or seal plate (especially if it's a sta-rite).
Nov 21, 2009 | Zodiac BARRACUDA G3 IN-GRND CLEANER
Zodiac baracuda wont go to shallow end of pool
If you can, adjust your intake valves so more of the suction is coming from your vacuum and less from your skimmers. This will allow the the vacuum to climb out of the deep end.
Mar 22, 2009 | Zodiac Baracuda G3 Automatic In Ground...
Zodiac Pacer Pool Cleaner Logo
29 people viewed this question
Top Zodiac Pool & Spa Experts
Colin Stickland
Colin Stickland
john h
Jay Finke
Jay Finke
Are you a Zodiac Pool and Spa Expert? Answer questions, earn points and help others
