Question about Princeton Digital LCD17 17" Flat Panel LCD Monitor
Replaced HV CB and still a problem
I have replaced the defective HV CB and now I get a normal display for about 5 seconds and it goes off with solid green power lite lit. Power holds good at 12 volts. Any suggestions? Gary
  • 944 Answers
SOURCE: LCD17 Flat panel
Check this link; They sell it for $69.99 and also list other alternative part numbers / manufacturers. Hope this helps, please ask again if you need more options :)
Posted on Sep 17, 2007
0 characters
1 Points
Milk white screen.
Try updating the display drivers ... Hope it turns goos after the update ...
Jan 03, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Samsung Monitor Backlight/Power Issue
hi, these mosfets are obsolete now, do you know a good equivalent for them?
Aug 16, 2012 | Samsung SyncMaster 931B 19" LCD Monitor
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Samsung SyncMaster 174v will display image for 2 seconds then go black. When I turn monitor off and then on again, it displays image with normal brightness for 2 seconds and then goes black. When I plug...
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Your monitor power supply has several capacitors going bad. You’ll need to have these replaced by a reputable repair person or check my website Thanks
Mar 10, 2010 | Computer Monitors
Screen goes blank after being on several seconds
Is the green light on (still indicationg power? Ist put your ear to it and switch on - hear any buzzing? Most like the HV Fluro Inverter for the lamps has an issue. For some the 2SC5707 may have gone - common.
May 29, 2009 | Mag Innovision LT776s 17" LCD Monitor
Display goes black after 5 minutes
Repairing the DELL E171Fpc LCD Monitor with the complaint of display shutdown after few seconds (power LED still on) was not difficult. Normally when this type of problem happens, we would first suspect the inverter board, then the filter capacitors and lastly the main board. A defective in one of the lamps and a faulty TL1451AC PWM IC or inverter ic may caused the display to shutdown as well. If the lamp is defective, it will send a feedback to pin 3 or 14 of TL1451AC IC and caused it to stop producing output signal thus the display just shut off once you switch it on.
Dec 09, 2006 | Dell E171FPb 17" Flat Panel LCD Monitor
Princeton Digital LCD17 17" Flat Panel LCD Monitor Logo
19 people viewed this question
Top Princeton Digital Computer Monitors Experts
Josh Whitehead
Josh Whitehead
Sr. Pelo
Sr. Pelo
Are you a Princeton Digital Computer Monitor Expert? Answer questions, earn points and help others
