Question about Cooper Wiring Devices Electrical Supplies
Seeking a Cooper combination decorator 7728W-BOX two single pole swithch wiring diagram.
  • 83 Answers
5 Suggested Answers
  • 63 Answers
SOURCE: Wiring to a 3 single pole combination switch
run 14-2 wire to power switches, then run one 14-3 wire and one 14-2 up to fixture..you will have an extra neutral but its okay... just tie all nuetrals together....this gives you the needed 3 hot wires!
Posted on Apr 05, 2009
  • 76 Answers
SOURCE: need to know wiring diagram for cooper single pole lighted switch
well lets see on one side you should have two brass screws that would be to interupt your lead to the fixture then you either have a brass and silver screws on the other side or you have black and white wires the black or brass is always hot the silver or white is neutral does that answer your question if not hit me back with a description of what your switch looks like
Posted on Jun 27, 2009
SOURCE: how to wire a cooper industries 6107 3-way motion detector switch
I opened the box and traced the lines to see which are connected
when the switch is turned on and I left the red wire disconnected.
Posted on Jan 29, 2010
SOURCE: I need the wiring diagram
I have 120Volt cooper 277 pilot light switch here in my office.
Dang instruction sheet shows wiring for all kinds of cooper devices.
EXCEPT pilot light switch.
So I tested with multimeter and came up with following:
Key to any wiring device is color of screws.
Hot from breaker box always goes to dark-colored screws.
Neutral always goes to silver-colored screws.
Brass screws are for Hot wires from breaker or Hot going to Load
Green screw - ground
Posted on Dec 03, 2010
Testimonial: "This diagram is, truly, helpful. Thank You! "
How to jump a four way switch to a single pole?
You cannot do that and still have the 4-way switch operate.
With 4-way... On the Hot side of 4-way switch (not load side), one screw is hot, or the other screw is hot... but both are not hot at same time.
To draw continuous power from the 4-way, you have to connect wires to both the hot side screws and run to your single-pole switch....however this is the same as jumpering a wire between both hot side screws on 4-way... which will stop 4-way from functioning.
http://waterheatertimer.org/images/4-way-circuit-420.jpg
Gene
Aug 17, 2014 | Cooper Wiring Devices 274V-BOX DECORATOR...
Cooper tr274v wiring diagram
Are you installing a combination switch-outlet?
What are you replacing? A switch? Is switch single pole or 3-way?
Or are you replacing outlet.
Do you have the Cooper TR274V?
Which device do you have?
http://waterheatertimer.org/How-to-Replace-outlet-with-combo-switch.html
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
http://waterheatertimer.org/How-to-wire-switches.html#5245
Gene
hh
Oct 02, 2013 | Electrical Supplies
Replacing a triple single pole (1980's) with a
DISCLAIMER:Attempting to work on house electrical systems without proper training is DANGEROUS and you stand the risk of dying.
The Cooper 7729w is a three pole single throw switch with a common (connected) hot wire that supplies it. What you had before was two separate single pole single throw switches and one single pole double throw switch that is used as a three way. The short answer is NO that replacement will not work UNLESS you don't want the other switch on the other side of the room to work.
Personally, I think that if you really need to ask this question you need to seek the advice of a professional electrician.
Dec 18, 2012 | Electrical Supplies
TR274 & TR 291 Wiring Diagrams
Copy following link for specific wiring diagrams for combo switches:
http://waterheatertimer.org/How-to-wire-switches.html#combo2
Combo switches require Neutral wire in the box.
Neutral wires are usually the white wires twisted together, covered with wire nut, and pushed to back of box.
Nov 09, 2012 | Cooper Wiring Devices Triple Deco Single...
Need a diagram for cooper #277w
I made following diagram based on Cooper pilot light instruction sheet:
Neutral wires are usually the white wires that are twisted together in back of box and covered with wire nut.
If your box does not have neutrals, you can also connect bare ground wire to silver screw until you have time to run neutral wire to box >> ground to anything but ground screw is not code and not recommended.
http://waterheatertimer.org/See-inside-main-breaker-box.html
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 18, 2011 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
I need the wiring diagram for a Cooper 277W single pole switch with pilot light. The light is to be on when the switch is on. Thanks!
Dec 03, 2010 | Cooper Wiring Devices 277W-BOX SINGLE POLE...
Hi i have a 9501ws c aspire single pole switch i am not sure about the connection of the whites do i run both blacks to the switch and tie the whites together this is a ceiling light thanks steve
Here is a site with a simple wiring diagram for a single light switch...
http://www.ask-the-electrician.com/Pics_Diagrams/singlepoleswitchdiagram1.JPG
Nov 28, 2010 | Cooper Wiring Devices "COOPER WIRING"...
Need to know wiring diagram for cooper single pole lighted switch
Jun 14, 2009 | Cooper Lighting Lighted Switch
Open Questions:
Electrical Supplies Logo
129 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
