Question about Garden
Clean the filter on a ryobi cv 720 vacuum cleaner
2 Suggested Answers
SOURCE: RYOBI weed eater.hard to start. starts then stops
I have a ryobi doule line bought in 1997..Had same problem put new gas cap on and problem solved..could not get air in....
Posted on Aug 02, 2009
Bissel carpet cleaner not sucking up dirty water why ?
Sounds like a clogged filter. Try cleaning the Flow Indicator Filter (turn Flow Indicator cap counter-clockwise to remove it, lift out rotor and filter under it. Clean filter and reinstall in reverse order); Check and Lint filter on the Heater tank Cap. All filters are recommended to be cleaned after each use. Bissell Consumer Care number is 1-800-237-7691
Nov 24, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water wont spray from cleaner how to fix
Try cleaning the Flow Indicator Filter. Turn the Flow Indicator Cap counter-clockwise to remove, lift rotor and filter. Clean filter and replace in reverse order. Bissell's Consumer Care # 1-800-237-7691
Sep 16, 2015 | Bissell 9500 ProHeat 2X CleanShot Upright...
Looking for dust collector Hitachi Vacuum Cleaner CV-BL16
Go to their website, look for your model and see if they have replacement parts.
Feb 18, 2015 | Vacuums
Why is the solution coming out of both lower sides of my Bissell carpet cleaner
First try cleaning the filters. One under the water tank cap (looks like a screen) remove it, clean and replace it. The other is a Flow Indicator Filter = unscrew the Flow Indicator remove the rotor and pull out the filter. Clean it and reinstall in reverse order. If that doesn't work the call the Consumer Care at 1-800-237-7691, Hope that helped.
Oct 08, 2014 | Bissell Carpet Cleaner Powerbrush Deep...
My Miele S3141 canister began acting strange this morning. No suction...so I took off the hose and checked for blockage, (nothing). Now I can't get the hose back on the canister. It just slips ar
see this causes and fix it. God bless you
Air filter:
If the vacuum cleaner won't pick up dirt and has no suction the air filter might be clogged. Remove the filter and either clean or replace it as needed.
Exhaust Filter If the vacuum cleaner won't pick up and has no suction the exhaust filter might be clogged. Remove and clean the filter, replace it if its torn or damaged.
Vacuum Hose If the vacuum cleaner won't pick up and has no suction the vacuum hose might be clogged. Remove the hose from the vacuum cleaner, stretch it out straight, shine a bright flashlight in one end and try to see light through it. If no light can be seen, use something to run through the hose and free up the obstruction.
Vacuum Bag If the vacuum cleaner won't pick up and has no suction the vacuum bag might be full. Clean or replace the bag as recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup assembly might not be installed tightly, or it might be cracked or broken. The dust cup must seal tightly in order to produce the right amount of suction. If it is cracked or broken, replace it. Most glues and adhesives will not successfully seal the crack.
Blower Wheel If the vacuum cleaner won't pick up and there is no suction, the blower wheel might be jammed or broken. Check the blower wheel to be certain it turns freely. If it doesn't, check to see if there is anything rubbing against it. If not, but it's hard to turn, the motor is most likely the problem.
Sep 27, 2012 | Vacuums
Ryobi trimmer stalls when we move from full choke to Half choke or Run. Tried cleaning the air filter, changed the spark plug.
Try cleaning any carbon build-up at the screen on the exhaust port. I use carburator cleaner, a small wire brush, and a small screwdriver. Carbon buildup at that area can cause this type problem. I would clean the carburator as well. Hope this helped and best wishes.
Aug 31, 2009 | Ryobi Garden
Aug 01, 2009 | Ryobi Garden
I have no suction.
just look up vacuum cleaners in the yellow pages of your phone book. almost all vacuum cleaner stores repair all models.
Dec 27, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
