The tempature doesn't register
Have A Hayward heat pro pool pump. The problem is the unit runs but constantly displays the tempature around 73 degrees and the pool is much hotter. I'm thinking the thermostat is shot. Any way to test the leads. THis is a digital display model and no other codes are coming up
  • 113 Answers
There should be a reset somewhere you might try that first
Posted on Apr 24, 2009
My hayward sand filter pool guage is registering 0 although the pool seems to be running fine. Guage was just replaced last summer.
  • Those spring type gauges break constantly, most likely broken again, they cost a couple bucks extra but liquid filled are much more durable, just don't forget to remove if you live where it freezes.
May 24, 2014 | Hayward SAND FILTER, PRO SERIES
What does the LP code mean?
low pressure ,MEAN low water pressure going to the unit or low pressure refrigerant is heat pump correct ?
Jun 09, 2013 | Hayward Pool Products Hayward Heat Pro -...
Hayward heatpro hp21002
bad start up capacitor replace whole pump
Mar 02, 2012 | Hayward Pool & Spa
Pool pump turns off after 1/2 hour or so but I can turn on manually after it sits for a while. Timer is working fine. Hayward Super II around 5 yrs old. Do I need to replace this motor? This problem just...
Your pump is protected by a thermal device that shuts it off when over heated. Are you running 110 or 220? In my experience, your pump will run cooler on 220 ... consider coverting if appropriate.
Aug 28, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
Brought a used hayward pool. no instructions on how to set up the pool. help
Here is a copy of the users manual for these pool filters. It has detailed pictures that should help you get the filter up and running in no time!
http://www.backyardcitypools.com/images/hayward/swim-clear-manual.pdf
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
Jul 02, 2010 | Hayward Pro Series 18" Above Ground Pool...
Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward HeatPro Heat Pump for pool won't turn on
Power to the unit but not the display + mice = bad board probably. Service call required...
May 27, 2009 | Hayward 116k BTU HeatPro Digital Heat Pump...
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
