Question about Garden
Frozen won't budge
My Poulan Pro lawn tractor will not move. It has locked up. This has happened before, lubricant was sprayed and after rocking it , finally started to move. This time no such luck. Can you give me an idea as to what to do? Thank You, Gwen Jones
  • gwendy101 Apr 26, 2009
    No, it isn't the first time the mower was used this year.
  • Benelatus May 11, 2010
    Hallo,
    Is this the first time this year you've tried to use the motor?
    Sniper:
  • 109 Answers
On lawn tractors, usually on the right rear wheel, there is a brake for the transmission, if the brake seizes up, the mower will not move...the size nut on the brake adjust is 1/2 inch, all it takes is about 1/2 turn on the nut and the brake should release the disk
Posted on Apr 25, 2009
How to get off pallet
Rock the mower back and forth, pull the lever out it will release the transmission. Sometimes they can be difficult.
Jun 01, 2014 | Poulan Pro PB175A46 Automatic Transmission...
Transmission Locked up on Poulan Pro 18 hp
Is this a riding lawn tractor with a snow blower attachment? If so, I would inspect drive belt underneath unit to see if it slipped off and is locked up. If belts look ok, try pulling hydro release to see if you can push unit. If not your problem sounds internal.
I’m happy to assist further over the phone at https://www.6ya.com/expert/layne_0fccff498c319c32
Feb 18, 2014 | Poulan Garden
Throttle mechanism will not move.
Try 'break free' or any kind of penetrating spray around the throttle. Give it 15 min to soak in and try it again. Make sure you are pushing/tapping on the moving part and not the stationary piece. Should be another linage from there to the actual carb. Check that it is free and moving easily. Cable problems usually are inside the cabel,rust etc that binds the cable but you should be able to move the actuator w/a pliers with the cable unattached. Good luck
Apr 22, 2013 | Poulan Pro " Pro" Self Propelled Mower
My poulan pro lawn tractor won't start. when i turn the key it click's 1 time can you help ?
Have you checked the battery terminal connections? Is the battery charged fully? Are you sitting on the seat when you try to crank the mower? Could be any of the above but most likely battery connection or the battery is discharged or old.
Aug 20, 2012 | Poulan Pro Lawn Tractor 2006 and Newer...
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
Lawn mower blades won't budge, even w/ 1/2' drive impact wrench
Hi, warm the nuts up with a heat gun or oxy torch then try the impact gun while they are hot, regards Phil.
May 31, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
Garden Logo
170 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
