Question about Saws
Miter saw makes screeching noise when you release power switch
Kazong
  • 152 Answers
SOURCE: craftsman 10-in. sliding compound miter saw
there should be a safety latch on the right ..down by the base or at the back you should have to press down on the saw to release it.hope that helps..
Posted on Jan 13, 2008
jyackle5
  • 8197 Answers
SOURCE: Makita 10" Compound Miter Saw LS1040 manual?
Here you go.
This is the ls1040
http://www.makita.com/en-us/Assets/images/Products/LS1040/owners_manuals/LS1040.pdf
This is the ls1040f
http://www.makita.com/en-us/Assets/images/Products/LS1040F/owners_manuals/LS1040.pdf
Posted on Mar 12, 2009
protek480
  • 1714 Answers
SOURCE: Saw runs continuously
The on off switch has a contact that has probably fused together from making and breaking causing an arc. You may try giving it a good 'wrap' with the back of a screw driver to free it, or replace the switch.
Posted on Jul 15, 2009
  • 583 Answers
SOURCE: I bought a used dw708 miter saw. It makes an
i would think it is neccesary to strip it down, but obviously there are bearings gone allowing the shaft to move over and grind and screech,i think it will be all too obvious what you will need when she is stripped ,.
Posted on Aug 27, 2009
Testimonial: "Right on the money. The front bearing was mostly gone. Thank you."
airnailer
  • 109 Answers
SOURCE: bench pro
replace the inner switch.
Posted on Dec 02, 2009
Kobalt SM2505LW 10 sliding compound miter saw makes grinding noise and slow saw stop
a bearing ,brushes or brake broke more likely the brake mechanism if blade coasts
Jul 07, 2016 | Saws
Where can I order a replacement trigger switch
How to Install a Switch Kit on a DeWALT DW705 Miter Saw ...
? 12:35
https://www.youtube.com/watch?v=FJ1Wo2xufzI
May 15, 2013 - Uploaded by eReplacementParts.com
Get a replacement switch kit for your DeWALT DW705 miter saw ... kit on a DeWALT DW705 miter saw which replaces thetrigger switch (part ...
Miter Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/miter-saw.html
Shop the Tool Parts Direct inventory of miter saw replacement parts. A miter saw is designed to quickly make cuts at a variety of angles. Featuring a pivoting ..
Oct 23, 2015 | Saws
My hitachi miter saw started to buzz when plugged in. It's seems to work normal when trigger is pulled but starts to smoke when I release the trigger. Bushing poor good. I have no idea what is wrong?
have it investigated by an appliance repair shop
the system is this
plug in --no noise
pull trigger -- blade spins and makes running noise
release trigger and blade stops -- no noise
anything else indicates a serious problem with the unit especially if it is smoking.
May 20, 2015 | Saws
Power is going to the motor on my dewalt 12 mitre saw but the motor is not spinning
Does the saw make any noise? If not it could be an open circuit in the field coils
Feb 22, 2014 | Dewalt Heavy - Duty 12" Double - Bevel...
Where is the blade brake on the miter saw
The brake on electric motor driven tools is the field & armature. When running the switch provides power to both sides/poles of the field through the brushes and armature. When you release the switch half of the field is powered pulling the armature to a stop. If your bladed continues to spin when the switch is released, you need to replace the switch. The Ridgid part number for the proper switch is 503317000.
Mar 06, 2012 | Ridgid Reconditioned 12 In. Compound Miter...
I've been using dewalt miter saw dw715 for several years and it's been working great. I just moved and today I used the saw in the new place, on an uneven concrete tiled ground. After several cuts, I...
This is common IF the blade clamping nut becomes loose... the blade will free wheel on the arbor after the motor stops. It can tear up the arbor so investigate this possibility immediately.
Feb 19, 2010 | Dewalt DW715 Heavy Duty 12" Single -...
Aug 27, 2009 | Saws
Jul 15, 2009 | Hitachi C10FCE2 10" Compound Miter Saw
Makita LS1013 chop saw just started making a bad bearing noise and the elecric brake is not kicking in after the trigger is released.
You will have to check if it is a bearing going and the electric brake may not be getting any power to it now or it could be sticking.
Jan 23, 2009 | Makita 10" Miter Saw LS1030N
Saws Logo
69 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
