Computers & Internet Logo
A
Anonymous Posted on Oct 14, 2013
G45t short circuit - Computers & Internet
1helpful
I have an Acer G45t/-g43t-am3 and as soon as I turn it on it has a constant beep .why is that?
Constant beep is an error code. It could be a code for bad ram, but it more than likely sounds like a video card error. Do you have anything on the screen?
How do I control CPU fan speed on an Acer G45T/G43T-AM3?
Some gamer or extreme motherboards have this feature, but I doubt ACER does. Try blowing out dust with canned air. This really works for me. I have an older machine, and I live in dusty Vegas so I know what you mean.
The other solution is to look for a bigger and quieter heatsink / fan.
TROUBLE CODE P 1613 IN WV PASSAT 99
P1102O2S Heating Circuit Bank 1 Sensor 1 Voltage Too Low/Air Leak
P1105O2S Heating Circuit Bank 1 Sensor 2 Short To Positive P1107O2S Heating Circuit Bank 2 Sensor 1 Short To Positive P1110O2S Heating Circuit Bank 2 Sensor 2 Short To Positive P1113O2S Sensor Heater Resistance Too High Bank 1 Sensor 1 P1115O2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 1
P1116O2S Sensor Heater Circuit Open Bank 1 Sensor 1
P1117O2S Sensor Heater Circuit Short To Ground Bank 1 Sensor 2
P1118O2S Sensor Heater Circuit Open Bank 1 Sensor 2
P1127Long Term Fuel Trim B1 System Too Rich
P1128Long Term Fuel Trim B1 System Too Lean
P1129Long Term Fuel Trim B2 System Too Rich
P1130Long Term Fuel Trim B2 System Too Lean
P1136Long Term Fuel Trim Add. Fuel B1 System Too Lean
P1137Long Term Fuel Trim Add. Fuel B1 System Too Rich
P1138Long Term Fuel Trim Add. Fuel B2 System Too Lean
P1139Long Term Fuel Trim Add. Fuel B2 System Too Rich
P1141Load Calculation Cross Check Range/Performance
P1144Mass Air Flow Sensor Open/Short To Ground.
P1145Mass Air Flow Sensor Short To Positive.
P1146Mass Air Flow Sensor Supply Voltage.
P1155Manifold Absolute Pressure Sensor Short To Positive.
P1156Manifold Absolute Pressure Sensor Open/Short To Ground. P1157Manifold Absolute Pressure Sensor Supply Voltage.
P1160Intake Air Temperature Sensor Short To Ground.
P1161Intake Air Temperature Sensor Open/Short To Positive. P1162Intake Air Temperature Sensor Short To Ground.
P1163Fuel Temperature Sensor Open/Short To Positive.
P1164Fuel Temperature Sensor Implausible Signal.
P1171Throttle Actuation Potentiometer Sign. 2 Range/Performance P1172Throttle Actuation Potentiometer Sign. 2 Signal Too Low P1173Throttle Actuation Potentiometer Sign. 2 Signal Too High P1176Rear O2S Correction
P1177O2 Correction Behind Catalyst B1 Limit Attained
P1196O2S Heater Circuit Bank 1 Sensor 1 Electrical Malfunction P1197O2S Heater Circuit Bank 2 Sensor 1 Electrical Malfunction P1198O2S Heater Circuit Bank 1 Sensor 2 Electrical Malfunction P1199O2S Heater Circuit Bank 2 Sensor 2 Electrical Malfunction P1213Injector Circuit Cylinder 1 Short To Positive
P1214Injector Circuit Cylinder 2 Short To Positive
P1215Injector Circuit Cylinder 3 Short To Positive
P1216Injector Circuit Cylinder 4 Short To Positive
P1217Injector Circuit Cylinder 5 Short To Positive
P1218Injector Circuit Cylinder 6 Short To Positive
P1225Injector Circuit Cylinder 1 Short To Ground
P1226Injector Circuit Cylinder 2 Short To Ground
P1227Injector Circuit Cylinder 3 Short To Ground
P1228Injector Circuit Cylinder 4 Short To Ground
P1229Injector Circuit Cylinder 5 Short To Ground
P1230Injector Circuit Cylinder 6 Short To Ground
P1237Injector Circuit Open Cylinder 1
P1238Injector Circuit Open Cylinder 2
P1239Injector Circuit Open Cylinder 3
P1240Injector Circuit Open Cylinder 4
P1241Injector Circuit Open Cylinder 5
P1242Injector Circuit Open Cylinder 6
P1245Needle Lift Sensor Short To Ground
P1246Needle Lift Implausible Signal
P1247Needle Lift Sensor Open/Short To Positive
P1248Start Of Cold Start Injector Control Difference
P1251Start Of Cold Start Injector Short To Positive
P1252Start Of Cold Start Injector Open/Short To Ground
P1255Engine Coolant Temperature Sensor Short To Ground
P1256Engine Coolant Temperature Sensor Open/Short To Positive P1300Misfire Detected, Fuel Level Too Low
P1250Fuel Level Too Low P1325Cyl. 1 Knock Control Limit Attained
P1326Cyl. 2 Knock Control Limit Attained
P1327Cyl. 3 Knock Control Limit Attained
P1328Cyl. 4 Knock Control Limit Attained
P1329Cyl. 5 Knock Control Limit Attained
P1330Cyl. 6 Knock Control Limit Attained
P1336Engine Torque Adaption At Limit
P1337CMP Sensor Bank 1 Short To Ground
P1338CMP Sensor Bank 1 Open Circuit Or Short To Positive P1340CKP/CMP Sensor Signals Out Of Sequence
P1341Ignition Coil Output Stage 1 Short To Ground
P1343Ignition Coil Output Stage 2 Short To Ground
P1345Ignition Coil Output Stage 3 Short To Ground
P1354Modulating Piston Displacement Sensor Electrical Circuit Malfunction
P1386Internal Control Module Knock Control Error
P1387Control Unit Internal Altitude Sensor
P1391CMP Sensor Bank 2 Short To Ground
P1392CMP Sensor Bank 2 Open Circuit/Short To Positive
P1393Ignition Coil Power Output Stage 1 Malfunction
P1394Ignition Coil Power Output Stage 2 Malfunction
P1395Ignition Coil Power Output Stage 3 Malfunction
P1401EGR Valve Power Stage Short To Ground
P1402EGR Vacuum Regulator Solenoid Valve Short To Positive P1403EGR System Control Difference
P1407EGR Temperature Sensor Signal Too Low
P1408EGR Temperature Sensor Signal Too High
P1410Tank Ventilation Valve Circuit Short To B+ P1420Secondary Air Injection Control Module Electrical Malfunction P1421Secondary Air Injection Valve Circuit Short To Ground P1422Secondary Air Injection Valve Circuit Short To B+ P1424Secondary Air Injection System Bank 1 Leak Detected P1425Tank Ventilation Valve Short To Ground P1426Tank Ventilation Valve Open Circuit P1432Secondary Air Injection Valve Open P1433Secondary Air Injection Pump Relay Circuit Open P1434Secondary Air Injection Pump Relay Circuit Short To Positive P1435Secondary Air Injection Pump Relay Circuit Short To Ground P1436Secondary Air Injection Pump Relay Circuit Electrical Malfunction P1440EGR Valve Power Stage Open P1441EGR Vacuum Regulator Solenoid Valve Open/Short To Ground P1450Secondary Air Injection System Circuit Short To Positive P1451Secondary Air Injection Circuit Short To Ground P1452Secondary Air Injection System Circuit Open P1471EVAP Control System LDP Circuit Short to Positive P1472EVAP Control System LDP Circuit Short To Ground P1473EVAP Control System LDP Open Circuit P1475EVAP Control System LDP Malfunction/Signal Circuit Open P1476EVAP Control System LDP Malfunction/Insufficient Vacuum P1477EVAP Control System LDP Malfunction P1478EVAP Control System LDP Clamped Tube Detected P1500Fuel Pump Relay Electrical Circuit Malfunction P1501Fuel Pump Relay Circuit Short To Ground P1502Fuel Pump Relay Circuit Short To Positive P1505Closed Throttle Position Does Not Close/Open Circuit P1506Closed Throttle Position Switch Does Not Open./Short To Ground P1512Intake Manifold Changeover Valve Circuit Short To Positive P1515Intake Manifold Changeover Valve Circuit Short To Ground P1516Intake Manifold Changeover Valve Circuit Open P1519Intake Camshaft Control Bank 1 Malfunction P1522Intake Camshaft Control Bank 2 Malfunction P1537Fuel Cut-off Valve Incorrect Function P1538Fuel Cut-off Valve Open/Short To Ground P1539Clutch Pedal Switch Signal Fault P1540VSS Signal Too High P1541Fuel Pump Relay Circuit Open P1542Throttle Actuation Potentiometer Range/Performance P1543Throttle Actuation Potentiometer Signal Too Low P1544Throttle Actuation Potentiometer Signal Too High
P1545Throttle Position Control Malfunction P1546Wastegate Bypass Regulator Valve Short To Positive P1547Wastegate Bypass Regulator Valve Short To Ground P1548Wastegate Bypass Regulator Valve Open P1549Wastegate Bypass Regulator Valve Open/Short To Ground P1550Charge Pressure Control Difference P1555Charge Pressure Upper Limit Exceeded P1556Charge Pressure Negative Deviation P1557Charge Pressure Positive Deviation P1558Throttle Actuator Electrical Malfunction P1559Idle Speed Control Throttle Position Adaption Malfunction P1560Maximum Engine Speed Exceeded P1561Quantity Adjuster Control Difference P1562Quantity Adjuster Upper Stop Value P1563Quantity Adjuster Lower Stop Value P1564Idle Speed Control Throttle Position Low Voltage During Adaption P1565Idle Speed Control Throttle Position Lower Limit Not Obtained P1568Idle Speed Control Throttle Position Mechanical Malfunction P1569Switch For CCS Signal Faulty P1580Throttle Actuator B1 Malfunction P1582Idle Adaptation At Limit P1600Power Supply Terminal No. 15 Low Voltage P1602Power Supply Terminal No. 30 Low Voltage P1603Internal Control Module Self Check P1606Rough Road Spec. Engine Torque ABS-ECU Electrical Malfunction P1611MIL Call-Up Circuit/TCM Short To Ground P1612Engine Control Module Incorrect Coding
P1613MIL Call-Up Circuit Open/Short To Positive P1616Glow Plug Indicator Lamp Short To Positive P1617Glow Plug Indicator Lamp Open/Short To Ground P1618Glow Plug Relay Short To Positive P1619Glow Plug Relay Open/Short To Ground P1624MIL Request Signal Active P1626Data Bus Drive Missing Command From M/T P1630Accelerator Pedal Position Sensor 1 Signal Too Low P1631Accelerator Pedal Position Sensor 1 Signal Too High P1632Accelerator Pedal Position Sensor 1/2 Supply Voltage P1633Accelerator Pedal Position Sensor 2 Signal Too Low P1634Accelerator Pedal Position Sensor 2 Signal Too High P1639Accelerator Pedal Position Sensor 1/2 Range Performance P1640Internal Control Module (EEPROM) Error P1648CAN-Bus System Component Failure P1649Data Bus Powertrain Missing Message From Brake Controller P1676Drive By Wire MIL Circuit Electrical Malfunction P1677Drive By Wire MIL Circuit Short To Positive P1678Drive By Wire MIL Circuit Short To Ground P1679Drive By Wire MIL Circuit Open Circuit P1681Control Module Programming Not Finished P1686Control Unit Error, Programming Error P1690MIL Malfunction P1691MIL Open Circuit P1692MIL Short To Ground P1693MIL Short To Positive P1778Solenoid EV7 Electrical Malfunction P1780Engine Intervention Readable P1851Data Bus Drive Missing Command From ABS P1854Drive Train CAN-Bus Inoperative
Read more at: https://www.obd-codes.com/trouble_codes/volkswagen/
Copyright OBD-Codes.com
3helpful
I just need to figure out what the socket type this motherboard has for the processor so that I can find what processors I can upgrade my computer with. It's a g45t/g43t AM 3 V: 1.1 motherboard made by...
The socket type of ACER G45T/G43T - AM3 V1.1 motherboard is LGA 775. Here are the compatible processors you can use for this motherboard :
Intel Pentium 4 (2.60 - 3.80 GHz)
Intel Celeron D (2.53 - 3.60 GHz )
Intel Pentium 4 Extreme Edition
(3.20 - 3.73 GHz)
Intel Pentium D (2.66 - 3.60 GHz)
Pentium Extreme Edition
(3.20 - 3.73 GHz)
Pentium Dual-Core (1.40 - 3.33 GHz)
Intel Core 2 Duo (1.60 - 3.33 GHz)
Intel Core 2 Extreme (2.66 - 3.20 GHz)
Intel Core 2 Quad (2.33 - 3.00 GHz)
Intel Xeon (1.86-3.40 GHz)
Intel Celeron (1.60 - 2.40 GHz)
16helpful
2answers
Looking for motherboard manual for G45T/G43T-AM3
Motherboard Manual for EliteGroup G45T-M2 (Version 1.0A),
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=912&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
Scroll to the bottom of the page to the heading - Manual for G45T-M2 (V1.0) Click on the country nearest you.
Motherboard Manual for EliteGroup G43T-M3 ver1.0
http://www.ecsusa.com/ECSWebSite/Downloads/ProductsDetail_Download.aspx?detailid=965&DetailName=New&DetailDesc=&CategoryID=1&MenuID=6&LanID=9
(What's with the AM3 listed? The G45 is an Intel motherboard chipset, as well as the G43)
4helpful
3answers
Light on clocks indicates eobd light and bike will not start help
To display what is wrong: turn off the ignition, press and hold the "A" button and turn the ignition back on. Than release the "A" button. The main display now shows "EFI", and the smaller display shows the error code.
Inputs
1.1 Throtlle Position Sensor (TPS) short-circuit to battery +
1.2 Throtlle Position Sensor (TPS) short-circuit to ground
2.1 Oil pressure sensor short-circuit to battery +
2.2 Oil pressure sensor short-circuit to ground
3.1 Oil temperature sensor short-circuit to battery +
3.2 Oil temperature sensor short-circuit to ground
4.1 Air temperature sensor short-circuit to battery +
4.2 Air temperature sensor short-circuit to ground
5.1 Battery HI
5.2 Battery LO
7.1 Fuel sensor short-circuit to battery +
7.2 Fuel sensor short-circuit to ground
Outputs 10.1 Horizontal cylinder coil short-circuit to battery +
10.2 Horizontal cylinder coil short-circuit to ground
11.1 Vertical cylinder coil short-circuit to battery +
11.2 Vertical cylinder coil short-circuit to ground
12.1 Injector 1 short-circuit to battery +
12.2 Injector 1 short-circuit to ground
13.1 Injector 2 short-circuit to battery +
13.2 Injector 2 short-circuit to ground
16.0 Fuel pump relay open circuit
19.1 Starter solenoid short-circuit to battery +
19.2 Starter solenoid short-circuit to ground
21.1 Stepper motor short-circuit to battery +
21.2 Stepper motor short-circuit to ground
21.3 Stepper motor open circuit
Functions 30.0 Generic ECU error
34.0 Signal panel (sensor discovery)
36.0 Speed (sensor discovery)
37.0 Immobilizer (key / transponder not found)
37.1 Immobilizer (antenna discovery)
37.2 Immobilizer (instrument panel serial driver)
37.3 Immobilizer (serial cable disconnected)
37.5 Immobilizer (key not acknowledged)
37.6 Immobilizer (immo virgin - ECU progr.)
38.0 Can line
Grand Canyon Tech
Grand Canyon Tech
