Question about Kitchen Ranges
I have no fitting instructions for a Smeg Imola kitchen tap
tborn6
  • 700 Answers
SOURCE: Replacing thermocouple on smeg oven
Look at the bottom of the oven and see if you can remove the panel, if its all one piece then take out broiler pan and look inside to see if you acan get to the pilot burner. Good Luck
Posted on Jan 11, 2009
  • 150 Answers
SOURCE: fitting monobloc kitchen diagram on pipe fittings
The tap should have 2 pipes about 6-10 inches long and almost the thickness of a maker pen {10mm or 15mm]
U will need either a 10-15 connection or a 15-15 connection either straight or elbowed according to routing need to main pipes [& these should also be 15mm
connections are fixed either with solder or have nuts on each end to tighten [compression] or are just push-on ["Speedfit"]
Ger back if u need more
Posted on May 02, 2009
  • 17 Answers
SOURCE: FITTING A BASIN
I am guessing you have the square one then. You need to fit your waste as normal, Send the waste through a hole in the surface you are placing the sink on and make your connections underneath. I use plumbers mait as a sealant when tightening the outlet. You then need to think about your taps. Since they are totally separate from the sink you can use what you want. Most people would use a monobloc riser though, secured to whatever surface you are laying the sink on.
You don't say how much you need to know about connections / plumbing etc. Please ask again if you are stuck with these.
Posted on Nov 14, 2009
  • 72 Answers
SOURCE: targa kitchen sink chrome mixer tap. circa 2002.
Contact the manufacturer and they will post a replacement which screws into the tap.
Posted on Dec 27, 2009
Magaiver
  • 707 Answers
SOURCE: lisbon monobloc kitchen taps just installed the
Put some cooking oil around the o-rings to sofen them up so they would seat around all fitting surfaces. Hope this helps.
Posted on Aug 12, 2010
Looking for a circuit diagram
It's usually und the console. A Google search on how to remove the console for your particular make will give you specific instructions.
Mar 07, 2015 | Smeg SUK92MFX5 Dual Fuel (Electric and...
Lots of water/condensate ends up on bottom of oven
I have the same problem with my new Smeg oven. I try to avoid using the oven at the moment because of the amount of condensation I have to mop up each time I use it, even the floor get wet!. Smeg have said they will replace it but I am now looking for an oven that will fit into the 'whole' the oven will leave in my newly renovated kitchen. I wish I had never ventured near to SMEG. I would never recomend Smeg to friends, quite the opposite.
Jan 19, 2010 | Smeg F170 Pyrolytic Stainless Steel...
Smeg suk91mfx shelves not fitting anymore on oven.
buy a pack of 2 oven shelf guards from lakeland 10.99. cut them in half and slide onto the ends of the 2 shelves. works perfectly.
Nov 18, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
I have a smeg A2-5 oven and have been told it requires a new heating element how easy are these to fit?
Well it is very easy.
First and all diconnect the power cord.
The element secured by two 1/4" screw in the oven.
you have to pull Range out and go, emove the back panel and remove the element wiring connector, and you are ready to replace it with the new one.
Should you need more details please feel free to contact me. I can provide you wiring diagram and instruction booklet.
nguyen@ite.net
Jun 09, 2009 | Smeg A2.5 Dual Fuel (Electric and Gas)...
Fitting ne hinges on a smeg 90 oven door
very easy unscrew screws on doors the one on inner glass attaches to hinges be careful when lifting off as door handle will come off took me 15 mins and i took it easy
Mar 25, 2009 | Smeg SUK91MFX5 Dual Fuel (Electric and...
SMEG Grill Element Screw Falls Out
there may have been a nut welded in the roof that has worked itself loose,or more likely you have stripped the thread.
try using a self-tapping screw to hold it in place
Dec 23, 2008 | Smeg A42-5 Dual Fuel (Electric and Gas)...
COOKER HOSE
It is illegal to fit a cooker to a gas connection unless you are a registered Gas Safe Engineer . You can find one in your area if you visit www.GasSafeRegister.co.uk
or ring freephone 0800 408 5500
Jun 09, 2008 | Smeg SUK91MFX5 Dual Fuel (Electric and...
Kitchen Ranges Logo
95 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
