Question about Garden
Where do the fuel lines go on a Walbro wt 891 carburetor
2 Suggested Answers
  • 124 Answers
SOURCE: what is the walbro chain saw carburetor adjustment for a
There is no set adjustment on any chain saw. If it were that simple there would be no need for adjustments. The problem is that most equipment manufactured in the past 10 years can not be adjusted by the user. Carburetors are now equipped with either adjustment limiters which limit the adjustment to less than half a turn or with adjustment screws that require a special tool to make the adjustment. More than likely you will have to take it to an authorized dealer for those adjustments.
If you do have an adjustable carburetor, then gently close both needles and open each on 1 full turn. This should allow the engine to start and the final adjustments can be made at that point. If it still will not start then open each needle 1/8 to 1/4 turn and try again. If this still does not work then most likely your carburetor needs a good cleaning and a rebuild kit.
Posted on Sep 13, 2009
What is the replacement number for a Walbro -wt-38B Carburator used on a stihl fs65avr trimmer?
WT-38B Carburetor
Part Number: WT-38B
Availability: Discontinued
This part is no longer available from the manufacturer.
I'
m sorry but these have been discontinued from the manufacturer.
Maybe you can find one on ebay or other used gear and parts store. http://www.ereplacementparts.com/Walbro
Jul 23, 2017 | Stihl Garden
Carburetor diagrams
I know of no diagram available for this. But if you have both lines out and visible you can just put them on the carb, fill the tank and prime it and see if fuel moves. If it does your done....if not....flip the lines and try again!
Jul 16, 2014 | Poulan Mvm200vs, Ppb430vs Vs2000bv Blower...
Weed Eater PE550 711431, new primer bulb will not pop back after second second push.
FIXED- No start Weed Eater with the symptom of the primer bulb collapsed, not filling nor returning to pop out after pressed.
Worked in model WT-3100 with Walbro carburetor WT-583 and has to work in many others. It happened after winter hibernation, even when left with no fuel to prevent formation of fuel deposits.
FIRST, mark/scribe the carburetor fuel outlet that has the hose towards the primer purge bulb as 'OUT' and the fuel inlet coming from the fuel tank 'IN'
The problem was a fine mesh metal screen strainer blocked by contaminants, inserted at place shown as number '3' in figure 7 at
----> www.drystacked.com/Walbro%20Carburetor%20Theory%2027Jun2010.pdf
That fine mesh was removed by prying its edges around with a sewing needle held by pliers.
It you cannot see light trough it holding it against a lamp, is blocked even if looks clean.
Removed, discarded, reassembled and started. Later ordered the part or kit but was able to use the machine immediately.
Writing this as am tired of seeing responses like 'may be this' or 'try that' or 'perhaps the other' by guessers.
Aug 07, 2013 | Poulan Garden
I have a walbro carberator that squits gas out of a little hole on the side near the top of the carb why?at the top why?
Probably the needle valve is sticking, letting the float bowl over flow. Remove the float bowl, and blow very low air pressure (less than 5 psi) through the fuel line. lift the float and see if the air blows past the needle and seat. If it does check the needle and seat. Sometimes a deteriorated fuel line will cause little bits of rubber to keep the needle valvefrom closing. If raising the float does shut off the air flow remove the float and check it.Brass floats on old carburetors can develop pin holes allowing fuel to enter the float causing it to drop. This keeps the float valve open. Some non metalic floats can become fuel soaking causing the same problem.
May 07, 2012 | Stihl Walbro Wt-160b Carburater For An...
Which fuel line "port/inlet" on the Walbro wt-380 goes to the fuel tank? It's on a Craftsman 25cc Gas "Weed Wacker" Line Trimmer purchased in 2002. It has Walbro WT-380 carburetor with external primer...
Usually the line with the filter on it that comes from the tank goes to carb. inlet first which is most likely close to the bottom side of the carb.nearest to the engine,then the outlet or return line on the carb.goes to the inlet side of the primer and the outlet side of the primer goes back to the tank. The primer draws fuel through the carb to the primer to the tank if its not? then correct the line connections until it does
Jun 25, 2010 | Craftsman 25cc Gas Line Trimmer
How to adjust the fuel flow in a Walbro carburetor
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner.Make surethe small screen is free of debris. (Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Dec 01, 2009 | McCulloch Garden
Garden Logo
61 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
