Question about Jumbo RC JUMBO HELICOPTER
Control problems wl toys v912 heli - Jumbo RC JUMBO HELICOPTER
My wl v912 transmitter will not switch to mode 2
Mode exchange: hold on the switch button and turn on the power switch "at the same time". Did you try this?
You can change rom modes 1, 2, 3 and 4.
Feb 11, 2015 | WL Toys WLToys V913 Large 4 Channel 27" RC...
Helicopter swerves right at speed
Hang it from a sting attached to the rotor shaft and see if it hangs level. It sounds to me like it is off balance.
Mar 07, 2014 | WL Toys WL V912 MAX 4CH FP RC Helicopter...
My v913 does not respond to left turns. mode 2
i think it has something to do with the signal to heli from transmitter
Jan 15, 2014 | WL Toys WL V913 Sky Dancer 4CH FP...
Can you bind the Heli max Helis to a D6i transmitter
Yes, you need to buy an AnyLink transmetter that will plug in the trainer plug of your tranmitter.
I put a web link to Tactic anylink products that can be order from internet from online hobbyshop, look in the Where to buy tab on anylink website. Have fun :-)
Dec 09, 2013 | Heli-Max MD-530 Flybarless EP Tx-R...
My S107G is fully charged, I turn on and off transmitter on different frequencies, turn the heli on and off according to my instruction manuel, but the lights on the heli are on,the circuit board red led...
I have similar problem with my LS-208 heli.
Helicopter leds are blinking red/green, front white led is on, and tail leds are blinking too.
Remote controller red led is on as should be but helicopter doesn't respond to controller at all.
I followed instructions above with no success.
Anyone has a suggestion?
Regards, Yaron.
Jun 12, 2012 | SYMA Toys industrial New Syma S107 Radio...
9053 bottom blades
Have the same problem with my S107 heli. I determined it's in the speed control hooked to the gyro control. This control feature helps keep heli
from turning in flight caused from tork. The lower blades are the ones
that speed up slow down to keep heli orientated. I'm replacing the control board.
Dec 16, 2011 | xheli 9053 Outdoor Volitation Metal...
When i connect the S107 to the PC the red light wont go off. What could be the problem?
its ok dont worry just plug it in.
when you unplug the heli if the red light gets brighter its not done. when its as bright as when not plugged in its done.
or simply leave it an hour it will still work
Nov 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
I have a s 107 and it will not go forward or backwards. everything else seems to work fine.
This has happened to two of mine, fairly common problem if you keep hitting things with your back rotor.
Solution 1: Replace the tail assembly
Solution 2: Remove the canopy and put a small weight in the nose which will serve to drag your heli forward. No backward flight but it works better than a heli that just hovers.
Mar 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
My syma s 107 copter transmitter dont connect5 to helis.controller light blinks
Try setting the heli down on a table and with the transmitter behind the heli, turn the throttle up until the blades start spinning. If that doesn't work, then I don't know how to help you.
Oct 03, 2010 | SYMA Toys industrial New Syma S107 Radio...
Havoc heli flight problems
Make sure the blades and rotors are free of debris. I had the same problem then noticed hair had gotten wrapped around the blades. Once you remove the hair or thread or string or whatever it should fly fine
Jan 05, 2009 | Air Hogs Havoc Heli Helicopters
Jumbo RC JUMBO HELICOPTER Logo
41 people viewed this question
Top Jumbo Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Jumbo Toy Expert? Answer questions, earn points and help others
