Question about Refrigerators
Kitchenaid KSCS5251 On the inside top of my refrigerator there are controls for temperature for the freezer and refrigerator. what does "Holiday Mode" in the do?
SOURCE: MZD 2766GE refrigerator: freezer side is cold but refrigerator side gradually warms after a week and then freezer side warms.
fan won't start by itself.
Posted on Aug 10, 2008
aborcass
  • 2651 Answers
SOURCE: Amana 18 Top freezer Refrigerator-leaking water in refrigerator
the middle insulation hasbecome water logged, forma faulty defrost tube, so, every time trhe unit defrost, 2 maybe 3 times a day it will spill water inti the vents, andin to the refrig, the only correct way to fix is to have the enitre center drain block replaced, part not that expensive but labor to install may be, ohter then nussincence, not really affecting machines workings
Posted on Jan 11, 2009
  • 10 Answers
SOURCE: Kitchenaid KSRA25IL Freezer working Fine - Refrigerator not
I had a similar problem where the refrigerator side was not cooling well but I could feel very little air coming through the vent in the top left corner.I blew hot air from a blow driver into the vent for about 1 minute which melted ice that was hanging from the bottom of the vent cover.Cold air started blowing harder thru the vent and cured the problem.
Posted on Feb 16, 2009
aborcass
  • 2651 Answers
SOURCE: power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Posted on Mar 08, 2009
SOURCE: Touch Temperature Controls not working
Unplugging and replugging worked great! (We left it unplugged for about one minute. The motor started up almost instantly but we still had no numbers on display. I discovered that after replugging, you need to touch one of the up or down arrows for the display to reappear. What a lifesaver this was! Thanks so much.
Posted on Aug 01, 2009
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
Sep 19, 2017 | KitchenAid Refrigerators
Too cold
Refrigerators and freezers have a thermostat control inside the refrigerator compartment. It is normally some type of dial with numbers and a graphic indicating warmer or colder.
Place a thermometer inside the cold box. Wait one hour and record the temperature. Adjust the thermostat one or two numbers warmer, then wait 12 hours and record the temperature.
The interior temperature for a refrigerator must be below 40F for food safety. A good range is 35-38F.
Jul 26, 2012 | KitchenAid KBFS25EVMS Stainless Steel...
Kitchenaid KBFL25ETSS00 bottom freezer refrigerator not cooling properly in the refrigerator nor the freezer. I hear the refrigerator running, but don't know if it is just the fan. It was working fine,...
You mean the temps are getting warmer? Look inside the rear of your freezer and back wall and tell me if you see snow or a layir of frost building. If so pull everything and unplug and do a manual defrost a hair drier will speed things up.Sounds like we need to use the tech sheet here but Kitchenaid will not allow me to publish here. So Skater125 you need to click here and I will send it to you only, Thanks, Sea Breeze
Sep 17, 2011 | Whirlpool ET1FHTXM Top Freezer...
What is holiday mode? is
In Holiday Mode, the freezer will not automatically defrost as often in order to conserve energy. I believe some models doesn't turn on the lights when this mode is activated.
Nov 23, 2010 | KitchenAid KSSP48QMS Side by Side...
Freezer Freezes Refrigerator Barely gets cold
Hello there:
Here is a few things to check to make sure the referigerator is working properly.
The first thing to check is the overall internal refrigerator temperature (see the Appliance Accessories section for a refrigerator/freezer thermometer). The proper temperature should be between 35 and 42 degrees. Here are some things to try: If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly. If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf. If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan. The refrigerator never cycles off The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system,
Apr 14, 2010 | KitchenAid Architect 24.5 Cu. Ft....
The freezer is not cold enough but i don't see a temperature control inside. Does the one in the fridge also control the freezer?
Correct. The fridge works 100% off the freezer anyways. So they installed the sensor right between the freezer and fridge if you look inside you can see it.
Whirlpool refrigerator repair orange county, ca
Feb 06, 2010 | Whirlpool ER6AHKXPQ Top Freezer...
Kitchenaid Refrigerator dripping water
i have a kitchenaid top / bottom refrigerator water drips in top part only not freezer. what is my problem?
Dec 31, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Food defrosted in freezer--turned to coldest setting--there is some cold air coming in but seems only small amount-refrigerator is only "cool"-fan seems to be working
I believe part number W10135899 Defrost Control Board is defective. The board is located inside the fresh food section and behind the control panel. Near the temperature controls. Look at the rear wall of the freezer. If a layer of ice is forming on the rear wall of your freezer then it also is forming behind the rear panel of the freezer and restricting air flow. The Defrost Control Board is the most likely reason then there are 2 more things to have a look at. That is the defrost heater and the defrost thermostat. Would not be a bad time to manually defrost your freezer so you can bring temperatures down and replace the part. Unplug refrigerator, remove the rear panel inside back of freezer and defrost the evaporator coils with a hair dryer Or you can leave a bucket of hat water setting inside the freezer compartment with door shut for a while. Let me know what you find, again most like problem is the Defrost Control Board, Thanks, Sea Breeze
Sep 20, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Over temperature reset button keeps ringing and blinking
I called the KitchenAid customer support number. Found out that control goes off when the temperature of the fridge is above 48 degrees (i.e., over a few days, the food would be spoiling). This is not the case for ours, since everything seems to be working fine. They said there is probably something malfunctioning with that button/control, and there is no manual turn-off mechanism. We have to call someone to come and fix it.
Jan 29, 2009 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
