Canon mx 886
Error message 5100
ohms
  • 1879 Answers
SOURCE: Error message on Canon MP160
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Posted on Nov 15, 2008
arjack
SOURCE: Error message: Service error 5100 on my new Canon MP160 Printer
Error Code.........Description
5000 ...................Home position error
5100 ...................Carriage control error
5200 ...................Head temperature sensor error
5400 ...................Printer temperature sensor error
5600 ...................No cartridge error
5C00 ...................Purging operation error
5200 ...................Scanner cartridge error
As a technician, I have worked on tons of printers. This particular error had stumped me for a while, but I finally found the cause. As others had pointed out before, it can have alot to do with some obstruction in the print path, the gears, or ink on the clear plastic encoder strip. You're on the right track - I found the the purge cap (the white sliding mechanism that the print head parks to when it's not in use) was not lubricated well enough from factory. If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display) Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on) Hope this helps some of you out.
good luck (^_^)
Posted on Jan 13, 2009
  • 153 Answers
SOURCE: Cannon mx 310 error 5100 Says chck printr with alarm light flashi
heres the problem from service manual: error 5100, a error occured in your encoder signal, it list 4 things in the serice manual.
carriage unit. carriage motor, logic board, timing **** film.
ok my first thing i would look at is the film that runs directly behind the print head i would think it is dirty. just turn on printer and get print head to the middle and turn off machine, gentle move print head to one side and gentle clean the film strip with a cloth with a little metho on it, move print head to other side and clean other part of ****.
i reckon that will fix your problem its a common problem they tend to get a bit of grease on the timming ****.
Canon Tech
Posted on Jun 01, 2009
Fixer here
  • 29 Answers
SOURCE: error message 5100
In this particular printer, this Error is described as Cartridge Home Position error. Try the steps that I am giving you:---- 1.Turn off and unplug the printer from the power supply.
2.Remove any paper.Buy a can of compressed air from an electronics shop or computer store. Use the compressed air (Not a vacuum!!!) to blast out any dust bunnies, paper particles and debris. (Don't do this with the cartridges removed as you're likely to fill the printhead with air!!)Use isopropyl alcohol and a cotton swab (Qtip) to clean the plastic strip that runs the length of the guide rail (the metal rail that the cartridge carriage moves along), it may be contaminated with ink and debris.Remove and reinsert the ink cartridges inside the cartridge carriage to ensure that they're connecting properly.
3.With the power off, carefully slide the print head (carriage) to the center of the guide rail. You should not have to force it! (There will be some light resistance but it should move quite easily by gently pushing on it with your finger.)
4.Close all the access doors, plug it back in, connect your USB cable and turn on the power.As it runs through the initialization, the printer should sense that the carriage is out of position and automatically move it back to where it should be.
Thank you, Have a nice day.
Posted on Sep 28, 2009
  • 2427 Answers
SOURCE: Canon PIXMA iP1000 - Service Error 5100
It means that the waste ink absorbers are filled and you will need to replace them and take the machine to a service center.. Well thats what Canon says,, then when you get there they say buy a new one..
Any way forget them try this..
1.) unplug machine (power cable from back of printer.
2.) hold the power button down and plug cable back in.the printer light will stay on ,,
3.) still holding power,, press the paper feed button.. light will change to orange
4.) press paper feed button again.. It will turn to green
5.) release power button and enjoy..
Depend on the the firmware skip step 4...
That will bypass canons firmware and reset the counters.. Print as you will now..
Posted on Mar 23, 2010
How to remove Error Message 5B00 from my Canon PIXMA MX420 Printer.
Not A GOOD printer engineer. This video tells you how to clear and reset that error.
How To Fix 5B00 Error On Canon MX Series Printers MX320
How To Fix 5B00 Error On Canon MX Series Printers (MX320 ...
? 1:39
https://www.youtube.com/watch?v=0waX_GF-h7U
Jul 26, 2012 - Uploaded by Internet-Ink
This video from Internet-ink.co.uk will instruct you on how to cancel the 5B00 error on the Canon MX series ...
How to Fix Error 5B00, Canon Pixma MX410, Solution - YouTube
? 1:57
https://www.youtube.com/watch?v=jLicZcZUmRY
May 5, 2017 - Uploaded by MJC
12:57. Canon Pixma MX420 Printer 5100 Error and Loading Ink - Duration: 5:57. Dustie Meads 228,823 views ...
SOLVED: My cannon printer mx420 has a error 5b00 how do i - Fixya
www.fixya.com/support/t22097789-cannon_printer_mx420_error_5b00_fix Dec 10, 2013 - Error 5B00 means that your ink absorber is full. you need to reset the counter protection and replace the ink absorber inside the printer. Visit the link below for instruction on how to reset the canon mp450 printer EEPROM http://pcmediks.blogspot.com/2010/09/how-to-reset-canon-mp450-printer.html. 5B00 printer error code, what is this?
24 Mar 2016
fix canon printer error 5b00 Questions & Answers (with Pictures)
12 Feb 2015
SOLVED: How to solve error code 5b00 on printer mg
18 Jun 2014
SOLVED: How to solve the error 5b00 on cannon ip 7240
5 Sep 2013
More results from www.fixya.com
How to get rid of the 5B00 error message on Canon printers ' en ...
www.en.rellenadodecartuchos.com/.../how-to-get-rid-of-5b00-error-message-on-cano... May 20, 2014 - The Canon printers are known to be one of the best printers on the market, recently with the adoption of the Continuous Ink System on several models, these Canon printers have more error message appearing. Today we are going to talk about the 5B00 error message and how to eliminate this error.
Canon Knowledge Base - LCD Error Messages - MX420
https://support.usa.canon.com/kb/index?page=content&id=ART109274 Please be advised that Canon shall not be liable for any malfunction or trouble caused by continuation of printing under the ink out condition. Note .... If the error is not resolved, connect the machine to the computer and align the Print Head on the printer driver. ... For example: 5B00, 6800, B200, 5700, etc. 5100 is displayed:.
How do you reset error 5b00 on mx420 - JustAnswer
https://www.justanswer.com > Computer Repair Questions > Printer Troubleshooting Jul 29, 2015 - The ink absorber is a series of pads/tanks, which catch drips from the printhead when parked, and is also used for maintenance tasks like cleaning and purging.Eventually this absorber fills up, and the printer shuts down operations, as continuing to operate it can result in ink overflowing the system, ... Error Message 5B00 from my Canon PIXMA MX420 Printer Google Search
Apr 21, 2018 | Canon Office Equipment & Supplies
What does 5100 code mean?
What is error code 5100 on the MP460? - Canon Community
community.usa.canon.com/t5/Personal.../What...code-5100.../103212
Jul 7, 2014 - Please remove foreign objects so that the print head holder can move: ... closet and hooked it up this morning, I was getting the 5100 message.
How to resolve error 5100 on an MX452 / MX459 - Canon
https://support.usa.canon.com/kb/index?page=content&id...
There are several reasons for error 5100 to appear. ... If the above recommendations donot help you resolve the error, the printer will need to be repaired.
How To Fix Canon Printer Error 5100 - YouTube
? 2:23
https://www.youtube.com/watch?v=rJQVwwRxPv4
Mar 14, 2013 - Uploaded by ITJungles
Learn how to fix the Canon printer error 5100, and have your printer running again. ... Reset error Canon ...
Jan 05, 2016 | Canon PIXMA MX340 Wireless Office...
When I turn on my MX 350 printer I get error message 5100. What do I do?
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mx_series/pixma_mx350#ServiceAndSupport
this is the link to your specific model and the support page for it on canon...
basically it will give you couple troubleshooting steps beyond that if all else fails call the maker...
hope this link helps out... i tried it and it does show the stuff to do...
Aug 07, 2010 | Canon Office Equipment & Supplies
Canon MX328
5100 is a carriage error, check the timing strip for contamination(plastic strip about 1/4" in width)
The unit is not homing, check for obstructions.
error 5100 :
1. clean **** strip film
2. clean **** strip film sensor (back of head carriage)(use contact cleaner)
3. fix purge unit
Apr 24, 2010 | Office Equipment & Supplies
Error 5100 on my canon mx 310.
the 5100 is the carriage error and can be caused by 4 different sensors. First off the "Timing Strip" that passes through the back of the Carriage Assembly can be contaminated with ink spots and this needs to be cleaned. Open the cover and use your flashlight to examine the timing strip as much as you can see. You really don't have much access to this strip unless you remove the covers,..and doing that is considerable work. The other items that can cause this error are the sensor inside the carriage unit, the drive motor for the carriage asm, and of course the main logic card. However, 99.6% of the time it is the Timing strip which is easitly contaminated with splattered ink.
Apr 02, 2010 | Canon PIXMA MX310 All-In-One Printer
51 people viewed this question
k24674
jasbo
jasbo
