Question about Cisco SPA504G IP Phone
Call forwarding Bottom of my phone screen reads 2:forwarded to 100. How do i get rid of this.
I forwarded my cell phone calls to my house phone. I cannot deactivate call forwarding. I have a Samsung S7
  • 1.From the home screen, tap Phone
  • 2.Tap More
  • 3.Tap Settings
  • 4.Tap More Settings
  • 5.Tap Call Forwarding
  • 6.Tap Always Forward
  • 7.Enter the number you would like your calls forwarded to and then tap Enable
  • 8.To disable call forwarding, swipe down from the top of the screen
  • 9.Tap the Call Forwarding notification
  • 10.Tap Always Forward
  • 11.Tap Disable
Samsung Galaxy S5 How to Setup Call Forwarding
Feb 11, 2017 | Samsung Cell Phones
How do i block a number on my alcatel one touch pixi 3
Block Calls & Messages:
  1. Open the apps drawer and launch "Contacts"
  2. Tap the name of the contact you want to block calls and messages from
  3. Tap "Edit" > "Menu" and enable "All calls to voicemail"
Unblock Calls & Messages:
  1. Launch "Contacts"
  2. Tap the contact you want to unblock
  4. Disable "All calls to voicemail"
Forward Calls (Unconditional):
  1. Tap "Phone" on the home screen
  2. Tap "Menu" > "Settings"
  3. Tap "Call settings" > "Call forwarding"
  4. Choose to "Always forward" and if necessary, enter the phone number to forward calls to
  5. Tap "Enable"
Forward Calls (Conditional Forwarding):
  1. Open the "Phone" app
  3. Go to "Call settings" and tap "Call forwarding"
  4. Select to forward calls "When busy", "When unanswered" or "When unreachable"
  5. Enter the phone number you want to forward calls to and tap "Update" or "Enable"
Turn Off Call Forwarding:
  1. Open "Phone" and tap "Menu"
  2. Tap "Settings" > "Call settings" > "Call forwarding"
  3. Select "Always forward", "When busy", "When unanswered" or "When unreachable"
  4. Tap "Disable"
Read more: http://cellphoneforums.net/general-cell-phone-forum/t381553-alcatel-onetouch-pixi-3-block-calls-messages%3B-forward-calls.html#ixzz4TXeusLlT
Dec 22, 2016 | Alcatel Cell Phones
How do you forward a message to another user.
If using like yahoo tap bottom right codner pf screen and select forward
Sep 11, 2014 | Samsung Galaxy S 4G Cell Phone
CANCEL DG ON MY AVAYA 9800
I am not sure why you would want to disable G on the phone. G specifies that you are part of a Hunt Group. To be taken off the hunt group, please contact your phone system administrator. The "D" stands for diverting (forwarding) calls, which means forward unconditional is enabled. To cancel all forwarding, Dial *00
Aug 18, 2014 | Avaya Lands Phones
Forwarding text messages
I'm assuming its with an IPhone? If so here is the best way to do it.
1. Open the text message you want to forward.
2. Tap on the Edit button.
3. Tap the message you are going to forward and you'll see a red checkbox appear on the left of it.
4. Tap the Forward button on the bottom right of your iPhone's screen.
5. Add the recipient of your forwarded message and tap Send.
I hope this helps
May 17, 2013 | Boost Mobile Kyocera Hydro Smartphone
Can I divert calls from this phone to another phone? Thanks MArk David
  • Figure out if your particular cell phone model has the option to forward incoming calls. You can do this by visiting your cell phone manufacturer's website or reading the manufacturer's manual that came along with the purchase.
  • Access the "Settings" menu on your cell phone and select "Phone Settings" menu.
  • Select the "Call Forwarding" option in the "Phone Settings menu. This option is usually found at the bottom of the "Phone Settings" menu. Selecting the "Call Forwarding" option gives you access to call-forwarding controls.
  • Switch on the "Call Forwarding" slider. The default position is off.
  • Insert the phone number you wish to forward your calls to in the "Forward To" field. This field most commonly lies below the "Call Forwarding" slider.
  • Exit the setup menu by pressing the home button. You may be asked to confirm/save the changed settings depending on your cell phone model.
  • Make a test phone call to the cell phone number on which you just enabled the call rerouting option. If the call is forwarded and received on the number you entered, it means that the "Call Forwarding" option has been activated.
  • Oct 08, 2010 | Panasonic Cell Phones
    It wont go in reverse it only goes forward, the steering works fine
    Hi
    The ESC on this truck comes with a reverse lock out. The reason is that when you're racing, race requirements are that no reverse can be used. Now you may have accidently turned this on. Go to the Traxxas web site and download the ESC manual and follow the instructions for reverse lock out.
    May 13, 2010 | Traxxas Stampede Monster Truck Rtrw/Xl 5
    How to forward an SMS from an iPhone 3G(S)
    For iPhones using firmware 3.0 or higher, forwarding of SMS messages is a built in feature. To forward a text message, simply
    1) view the SMS text message conversation containing the message you'd like to forward
    2) tap EDIT at the top of the screen
    3) check off the message(s) you'd like to forward
    4) tap FORWARD at the bottom right of the screen
    For those using older firmware, there is a third-party application for the iPhone, iSMS (or weiSMS), with which it is possible to send text messages to multiple individuals as well as forward text messages
    Hope this helps.....
    Mar 04, 2010 | Apple iPhone 3G
    Steps to forward inbox texts to email with white screen problem?
    First open your phone. Press upper right (-) key to get menu. Press joystick up 1 time to get Messaging. Press joystick center select button 1 time, then down 1 time for "Inbox" (or down 3 times for email). Press center select 1 time, joystick down 1time for Inbox, center select for first message. Press upper right (-) key for "More", then joystick down 2 times to get "Forward", press center select. Press upper left (-) key to "Continue", press joystick up 1 time to get "enter email addr." Press joystick center select button, and enter the email address you want to forward the message to. After you have typed in the email address, press upper left (-) key "OK" 2 times to "Send", if you normally enter a password, type it now, press upper left (-) key for "OK" and your message will be sent. Hope this helps. -Mike
    Nov 11, 2008 | Sony Ericsson Z525a Cellular Phone
    Call forwarding nec elite
    Usually there are codes for call forwarding and forwarding cancel. I always program up *8 for call forward and #8 for call forward cancel. On your phone try a few numbers. First try *1 make sure you are on a phone with a display. Read the display and see what it says. If it is not what you need hangup. Then try the next number *2. Remember the #_ is usually the cancel.
    Good Luck
    Jerry
    Sep 11, 2008 | NEC Electra Elite DTU 16D-2 Corded Phone
    Cisco SPA504G IP Phone Logo
    Top Cisco Computers & Internet Experts
    Gopi Venkatesan
    Gopi Venkatesan
    Prashant M
    Prashant M
    Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
