Question about Computer, Chip, Cruise Control for Nissan 350Z
Cruise Control on my 350Z does not work. Light is on saying it is working. Cruise control
  • 31 Answers
Check for a vacuum hose , at the cruse valve ,may have come off
Posted on May 27, 2014
2 Suggested Answers
  • 176 Answers
SOURCE: 1996 Nissan pickup truck cruise
It could be an abs sensor, cruise controller, or a number of other things. If you're interesting in trouble shooting the issue yourself, I would be happy to further assist you if you can get the check engine light code and post it for me.
Some auto parts places will check your code for free.
Goodluck
Posted on Mar 27, 2011
CRUISE CONTROL WON'T WORK ON 2005 CHEVY TRAILBLAZER
check cruise control fuse and check the brake lights see if brake light working because the brake light switch will deactivate cruise control when brakes is applied.if brake lights dont work either fuse blowed or switch bad.if all is good have vechicle code scan because cruise control control by PCM and vechicle speed sensor and thottle actuator control motor.
Apr 17, 2013 | 2004 Chevrolet TrailBlazer
Crusie control does not work on 2011 gmc sierra 1500 and I've already replaced the switch?
If the switch is replaced,then it can be wiring issue or faulty cruise control board.But as the switch is replaced,get the voltage at the switch tested to confirm the switch is actually receiving voltage.If no voltage received at switch power supply wire then ,apply external 12 volt power to the cruise control switch wire and then see if cruise control comes ON.If yes,then you know wiring is issue.
On this case, to troubleshoot this problem, there are solved help links. Click the link directly and refer the details to solve this problem yourself, with help of diagrams: ------
Ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003 Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Nov 28, 2012 | GMC Cars & Trucks
On these case,to troubleshoot these problem,there are solved help links.Click the link directly and refer the details to solve these problem yourself,with help of diagrams:------
----------- Horn and Cruise control quit working?
Horn and Cruise control quit working on 2003 Jaguar S-Type? http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500 http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger? http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working? http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
These will help.
Thanks.
Nov 22, 2012 | 2003 Ford Expedition
I'm getting this code p0582 on Mar 19 2009 you sad you did not no what it was. Do you know now? there no more codes. Cruise Control Related Malfunction i tern on the Cruise Control. Light comes on I set...
P0582 is the Chrysler Diagnostic Trouble Code (Error Code) for:
Speed control vacuum or vent solenoid circuits open or shorted
If you do not have cruise control on your vehicle, you can ignore this code. If you do, you've probably noticed it is no longer working or only works intermittently. The code is saying it's an electrical problem to the servo.
Jun 24, 2010 | 2002 Dodge Intrepid
My cruise control won't work and my brake light is on. The car is a 1994 Toyota Camry. Thank you.
Your brakes warning light or your actual brake lights? If it is your warning light that can come Monday if you're park break is on or slightly on or the switch that says that it is on is faulty, in which case it may tell your cruise control to turn off. If your brake lights stay on there's something pul to you about your switch by the pedal as your cruise will not work when you hit the bricks and this will be perceived as you hitting the brakes. A break warning light will also, come on if your brake fluid is low.
Jun 07, 2010 | 1994 Toyota Camry
Cruise control no longer works. Cruise light comes
Make sure the cable from the cruise control motor to throtle is not broken or unattached.
Jul 08, 2009 | 2003 Chevrolet Impala
Cruise Control on 2 door Sport 4x4 with SOHC: Non-working cruise control. When turned on, cruise control does not engage, no dash light indication either.
look in your owner's manual for the location of the cruse control fuse it is different from other fuses usually much larger
May 21, 2009 | 1999 Ford Explorer
1991 Celica GTS Cruise Control Problem
You may have a faulty brake lamp switch at the brake pedal. If the brake lights come on (via a bad switch), the cruise will cut off.
Aug 18, 2008 | 1991 Toyota Celica
Computer, Chip, Cruise Control for Nissan 350Z Logo
101 people viewed this question
Top Nissan Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
George Agios
George Agios
Are you a Nissan Vehicle Part and Accessory Expert? Answer questions, earn points and help others
