Question about Sharp AR-5316 Advanced Digital Imager Copier
Impresora xerox workcentre xe80 error e7 sub code 05
SOURCE: AR-5132 Error code E7 13
netoiyer les miroire de scanner et la bare blanve
Posted on Dec 19, 2008
  • 37 Answers
SOURCE: e7 sub 11
The problem is on the scanning unit try these steps:
STEP1: Press continuously CLEAR then INTERRUPT then ZERO then INTERRUPT
STEP2: The panel display will turn off it means that you are inside the simulation if not repeat again step1.
STEP3.Then type 14 then press the print button
Posted on Mar 01, 2009
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
Posted on Jun 06, 2009
  • 143 Answers
SOURCE: Sharp MX-2700N - Error Code - 'Call for Service E7 - 05'
E7 is only part of the code. It could be a hard drive problem, memory problem, laser problem, or a loose connection on one of the boards.
Posted on Aug 01, 2009
xptareq2000
  • 1447 Answers
SOURCE: E7-05 E7-06
Problem on your copier memory stick.
Solve:clean all surface with contact cleaner.
Mother Board clean with contact cleaner.Then solve your problem.if you are not fix your problem then replace memory.
Posted on Jan 23, 2010
What's your question? My Sharp photocopier AR-161 display E7. and can't make copies what is the problem?
Here is a list of error code meanings for your device. You need to find out the sub code should be E7-?? To find the root cause. Sharp AR 161 Error Codes Trouble Codes
E7
E7 03 LSU trouble
E7 04 CCD white level trouble
E7 05 CCD black level trouble
Sep 25, 2015 | Sharp Office Equipment & Supplies
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
Problema con mi impresora codigo u2
Codigo de estado U2 / Sub Codigo 01 AVERIA DE LA MEMORIA
La PWB principal detectó una avería de la memoria
Codigo de estado U2 / Sub Codigo 02 AVERIA DE LA MEMORIA
La PWB (Placa de circuito impresa) principal detectó un error de acceso
Procedimiento para ambos casos
Realice el procedimiento de anulacion del codigo de estado U2:
  • Introduzca el código de diagnóstico 16.
  • Pulse Impresión.
Si todavia existe el problema , substituya la PWB principal.
Aug 20, 2011 | Xerox WorkCentre XD100 All-In-One Laser...
My xerox worcentre 103f shows the errors e7 - 15 where can I get a list with the code
The error code e7-15 is a copy lamp problem. There is a list of error codes for the Workcentre 100 series at this link.
http://www.partsdrop.com/pages/XD100inf.html
Jun 10, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I HAVE ERROR CODE H4
Give this a try, should resolve your code.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Aug 05, 2008 | Xerox WorkCentre XE80 Laser Printer
XEROX WORKCENTRE XE80 DISPLAYS AN H3 CODE
Try this procedure.
Jul 17, 2008 | Xerox Office Equipment & Supplies
Sharp AR-5316 Advanced Digital Imager Copier Logo
20 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
