Question about GTO Mighty Mule Automatic Gate Opener For Single Swing Gates Up To 18 Ft Or 85
My Centurion R3 gate motor still opens and closes the gate but I can manually push the gate open or close. How do I fix?
Lift gate will not power down to closed when button on gate or remote is pushed. Lights do flash though.
There are switches on both ends of the course of the motor, if one fails it will only work on the side that´s ok. That´s why it opens but do not close.Check it out.
Oct 24, 2015 | Cars & Trucks
I bought a receiver to pair a Centurion D5 motor with thE Digidoor motor.How do i install the Receiver on a Digidoor motor?
Hi there Vusi.
You should have a manual open and close switch on the wall for your Digidoor. You need to find the two wires which control the open and close functions on the Digidoor Trace these back to the Digidoor motor connect these to the Comm and NO terminals. You also need to supply 12V power to the receiver This needs to be connected to the Possitive and Negative terminals on the receiver. These connections originate in the Digidoor motor housing and can be connected right there. Some Digidoor motors have connection terminals for additional remote receivers in the housing. Remember that the minimum connections needed are Positive, Common(Sometimes the common is also the negative supply so you can bridge the common and negative terminals on the receiver) and NO. Then pair the remote with the receiver as per the instructions in the receiver box. If you still cannot come right post pics of the PC boards of your receiver and Digidoor motor and I will identify the connections for you
Jan 05, 2015 | Televison & Video
Centurion gate motor
These gates have the ability to adjust opening, closing distances and speed. Your manual has the instruction. I would recommend a qualified technician make the adjustments as you have to get inside case(where high voltages are located).
Mar 12, 2014 | Televison & Video
YOU MUSt test the r.control see the photo atttached, when you hit any key the LED must be ON, and otherwise, you must open the keypads for clean from oxide, corrosion, etc. and clean the springs contacts battery, replace by new ones full charge type alkalynes. and test again.Of ocurse you can have problem too with the control motor.
God bless you
Nov 25, 2013 | Televison & Video
Trouble shooting Centurion D10 gate motor
look for a loose wire and faulty earth check for wires shorting out to earth
Jul 14, 2013 | Cars & Trucks
My gate is equipped with a D3 Centurion gate motor. When I push the button to open the gate, the motor turns in the opposite direction (close) and tends to close further. Then if I deactivate the gear box...
if you push the open button and it closes indicates that you have the wrong polarity connected to the motor
gate motors are DC so where the positive and negative wires are connected are critical for rotation direction of the motor
Jul 29, 2017 | Garden
I need to programme extra remotes to open and close my centurion gate motor
You can call the Technical Support Hotline at 0860-236-887 or you can e-mail at support@centsys.co.za.
Nov 01, 2010 | Sears Craftsman LiftMaster Chamberlain...
Sliding gate will not close
The photo eye sensor is defective of is out of its correct posistion!
Hope this was of help!
Dec 11, 2008 | Elite Sl 3000 Ul Sliding Gate Operator
GTO Mighty Mule Automatic Gate Opener For Single Swing Gates Up To 18 Ft Or 85 Logo
15 people viewed this question
Top GTO Home Security Experts
Tom Chichester
Mai Lor
Clinton Daley
Clinton Daley
Are you a GTO Home Security Expert? Answer questions, earn points and help others
