Question about LG Washing Machines
MY LG WFT6500 top loading washing machine Wash and Spin process red lights are blinking. Therefore, machine doesn t work. How do I reset my machine
    Master:
  • 492 Answers
Try unplugging it for a few hours and replug in.
Posted on Oct 15, 2013
4 Suggested Answers
  • 4088 Answers
SOURCE: I have a Hoover 550 MB Top Loader washing machine
Will the unit spin if you manually turn the timer dial to spin? If so, remove power, remove the clock motor from the timer, and inspect the clock and mating timer gearing for debris or damaged gear teeth. At the worst, replace the timer. You may be able to scrape or file the damaged teeth so that the timer will progress.
Posted on Oct 20, 2009
Testimonial: "That is great advice . Will try and see if your solution works . cheers"
SOURCE: LG Top load fuzzy logic washing machine DE problem.
I have the same problem. please let me know if yours got fixed
Posted on Dec 19, 2009
sonicboomele
  • 1557 Answers
SOURCE: The spin red light and 2 green wash lights in
its got a bad read sensor it needs to be cleaned its under the capstan drive motor take the part out and clean is ir readers
Posted on Dec 29, 2010
LG top loading washing machine spin not work n
Try test your lid switch. If the switch is inoperative, the machine will not spin or drain when it gets to that cycle on the timer
Sep 25, 2014 | Washing Machines
On my fuzzy logic 6.5 top load I keep getting a beep and the wash and spin indicators blinking simulatinously. What could be the reason for this, how can I fix this?
I had the same problem. I lost the magnet in the lid cover. So, I put a magnet as shown in the picture (blue and red color one). It working now!!!!
May 24, 2014 | LG WM-2077C Front Load Washer
Wash down
Since down comforters are very light in weight, they confuse energy efficient front loader washing machines in how much water to add. Therefore, very little water is used, which results in a semi-damp comforter at the end of a wash. Pre-soaking the comforter beforehand would help, however, now the comforter weighs a ton, and the machine will vibrate like crazy during a spin cycle. It may be better to have the comforter dry cleaned.
Apr 28, 2014 | LG WM1812C Front Load Washer
Amana washer lid lock wont quit blinking
Your washer lid lock button is locked and lid was not put down before it locked, which is why the light is flashing. Therefore, push the "START" button until you see the lid lock button is off (Approx 3 seconds). Once it is off, then you can put the lid down and push the start button again, which will lock the lid into place. The washer will NOT drain or wash or spin unless the lid itself is in the locked position. If you were able to get the lid down and locked and it still doesn't work, then you need a technician to replace a wiring harness. However, you mentioned that the lid lock button was flashing, therefore, it stands to reason that your lid is NOT locked down.
Apr 13, 2014 | Amana NTW4700YQ Top Load Washer NTW4700YQ
My washing machine fisher paykel mw511 stopped working and now only beeps and show red light on spin. But don't spin or wash clothes
Is this the same company that makes Fisher-Price Toys?
I thought so, well you get what you pay for! OK most machines have some Reset function process. Most work by unplugging the machine for 5-10 minutes (computer to reset) then plug it back in. You should get a prompt/ audio or text message (if there is a window) that alerts you that the machine is resetting itself. Then just follow by testing a Light load setting so you do not have to wait around a long time. IF...This does NOT work. THEN...My Friend...You have a BAD control board. Which is like a computer board. And those are EXPENSIVE! $200-$400. So then it becomes economics. How old is the machine 5+ yrs? Buy another Machine
Mar 15, 2014 | Washing Machines
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
The wash cycle does not complete as the washing machine cannot drain the water from the first wash. What's wrong?
check if you have set the option on for wash, rinse and spin. if you see only WASH light on, then it will stop without draingin water.
May 31, 2010 | LG WFT1071TP Top Load Washer
When I start my LG WM2101HW washer, the spin light
sounds like a clitch under warrenty would call them out so you dont void warwrnty
Dec 06, 2009 | Washing Machines
Beko wma 1715s
The Child lock is in the on mode lol.....
Press and hold the two buttons quick wash and anti crease or
pre wash and extra rinse for 4-5 seconds ...Note the pre wash blinking light will go off and your machine will be ready to use again. the pre-wash blinking light indicates that the child lock has been activated......
Jan 05, 2008 | LG WM1814CW Front Load Washer
Washing Machines Logo
258 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
