Question about Bosch Dodge Ram Van 3.9 5.9 5.2 Alternator 99/ Dodge Pickup 99-00 3.9 5.2 5.9 8l
Need help!! 1999 Dodge Ram 5.2 has periodic miss in overdrive only! Please help? Have replaced all plugs,wires,d.cap,rotor button,coil,all injectors, TC,transmission lock up switch,throttle position sensor ( which helped it for about 1,000 miles, now the problem is back! ).
    Master:
  • 452 Answers
It sounds to me like its onthrottle position sensor some were but im not fully aware with this modle but u are on right track
Posted on Oct 15, 2013
Testimonial: "Thank you for caring enough to answer my call for help! Will get back with you...."
  • rbbutler Oct 18, 2013
    Took new sensor back and got another NEW one and it did not help @ all! We are stumped!!
Misfiring on the number 8 cylinder
check the compression,sounds as if it is a little lower than the other cylinders. check the engine vacuum to make sure it is 18-21 Hg at idle and the gauge is steady. low vacuum indicates worn rings or broken valve spring
Jun 20, 2012 | 1999 Dodge Ram
1999 dodge ram 1500 5.9 firing order diagram
Hello durtyt: My name is Roger and I will answer your question: Attached is a picture of the fire order for 5.9 Dodge Ram 1500. Should You need further help please just ask. Please rate the answer you received. Thank You for using Fix Ya. Rogerrogerf1_0.jpg
Dec 13, 2010 | 1999 Dodge Ram
I have a 1999 chevy suburban 5.7 Vortech witch is starting to drive me nuts. The spark plug wires, and all around the ignition coil is arching. With this said the distributor, cap, rotor, plugs, wires, and...
Assuming none of the wires are crossed, AND you replaced the cap rotor wires with quality replacements (meaning AC Delco) then you may have a bad coil. Remove coil from dist cap if HEI and look for any signs of arcing such as blackened areas.
Nov 09, 2010 | 1999 Chevrolet Suburban
Check engine light came on the computer said misfire on number 2 and number 7. I installed new plugs and wires. The check engine light went off, but it still seems to be missing and idling rough. When you...
replace the cap,and rotor,if this does not help,use a good fuel cleaner,like lucas,and heet together for cleaning and moister.You may have clogged injectors,also check the fuel filter,if there is not enough fuel pressure it will do this also.
Mar 26, 2010 | 1999 Dodge Ram
99 5.2 durango :pulled codes for multipe missfire cylinder #5-7
Aloha We have just replaced all of what you have replaced, plus water pump, fuel pump, pcv valve and 02 sensor. Took it to mechanic today we had misfire on 1,2,6,7. Mechanic said that the 99 dodge is known for bad computers, he checked ours and works great turns out that it was the coil. Ours was jumping 1/4 inch and had a orange/yellow spark. it is supposed to have a 1 inch spark and be blue. This has solved our problems after 527 dollars later.
Check the coil!
Feb 26, 2009 | 1999 Dodge Durango
1997 ram 1500 5.9 wont rev past 2000 rpm
well, the timing on your ram is computer controlled. is the truck in drive when this mis-fire occurs? or at idle? youve addressed part of your ignition w/the cap-rotor-plug wires. did you examine the old cap for carbon tracking? did you install the rotor properly? i know on my '97 ram the dist is feakin' buried in the engine it would be easy to rotate the rotor while installing/removing it so the timing mark is off. does your engine have the right plugs installed? your plug wires follow the correct firing order with your dist? you did not mention anything about your ignition coil. here is how to safely remove and check your ignition coil. disconnect battery-at the coil disconnect the lead wire (TOP) and primary (BOTTOM) from the coil. label your wires, or take a pic of your ign coil before you remove it so if you forget where the wires go, you have reference point. remove mounting screws and remove coil. clean coil to remove rust/dirt and wipe coil terminals off. inspect case for damage. with a multi-meter, check coil primary resistance by selecting ohm's and then place + and - leads on the pos/neg terminals on the coil, dodge used 2 brands of coils either a "diamond" or a "denso" primary resistance for the diamond mfr'd coil will be between 0.97-1.18 ohms. secondary resistance 11,300-15,300 ohms. Denso primary resistance 0.95-1.20 secondary resistance of 11,300-13,300 ohms. to measure secondary resistance place one of the leads to one the primary terminals and the other lead attatch to the large center terminal. compare your readings to the above values. if your readings are not within range of the above values, your problem is the ignition coil. other causes you may consider is faulty: speed sensor, throttle pos sensor/trans issues like bad pressure solenoid (actuates gear changes) a fault in your overdrive system. hope i have helped!
Feb 24, 2009 | 1997 Dodge Ram 1500 Club Cab
Bosch Dodge Ram Van 3.9 5.9 5.2 Alternator 99/ Dodge Pickup 99-00 3.9 5.2 5.9 8l Logo
50 people viewed this question
Top Bosch Electrical Supplies Experts
wadingriver
wadingriver
protojexxx
Level 1 Expert
Steven's...
Steven's...
Are you a Bosch Electrical Supply Expert? Answer questions, earn points and help others
