Question about Refrigerators
I have a Maytag french door refrigerator Model is MFI2568AES Serial is 10039560JL. The refrigerator doors do not close properly because they are not aligned. The right side door has a bottom hinge closure or plastic shim that is clearly not on the left hand door. The left hand door is hanging 1/2 inch lower than the right so the top of the left hand door does not catch the slot at the top middle which moves the center seal into correct position. My manual says there is a right closure part but does not say anything about a left one. model MFI 2568AES12 and 13 manuals say there are washer style shims but they are not in the parts list. Please help.
  • Refrigerators Master
  • 842 Answers
Thank you for taking the time to explain this issue. I would need to see pictures of the part you have to compare to the diagram and determine your next move. I would with parts companies around the US and I can get you picture if you need them of how the unit was designed to work.
So either send me pictures of both door or I can send you snap shot of the parts list and pictures to assist you.
I have to ask, if the unit level and were the door removed at anytime prior to the current issue you have?
Thanks
Posted on Oct 15, 2013
Hv board needs to be replaced
Try www.searpartsdirect.com Or Give me your city and state I'll find you a local appliance parts supplier.
Oct 29, 2013 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator stainless steel french door bottom freezer...lights flashing and ice maker opening and closing/making sound
Im thinking maybe a power surge was felt by the refrigerator.
Try unplugging from wall for a couple minutes and then plugging it in again.
Hope this resets it...
Jul 23, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
Seal on door(s) seems to be bad. Can't keep doors closed properly. Does the seal have to be replaced? It isn't covered under the extended warranty.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Aug 31, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Icemaker wont make ice. Any ideas?
tempt in freezer not cold enough or water inlet is frozen . defrost it with a turkey baster and hot water .. this may be caused by the water valve not closing complety and if so replace the water valve .. mm
Aug 03, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag refrigerator
IF BOTH WATER AND ICE MAKER ARE NOT WORKING YOU MAIN NEED THE MAIN BOARD. THERE IS NO FUSE.
Apr 24, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
The ice trap door won't stop cycling open and closed and the control panel on the door is blinking all of the lights
Called maytag with model and serial number. This is a very common problem. They sent a new mother board free of charge within a couple of days. You will have to go to the back of the fridge to swap mother boards. It was pretty simple if you have a little patience. Maytag wanted to charge $200 for the service call but it took my husband about twenty minutes. Then you will need to reprogram with the code inside of the door. I was told that this happens alot if there is a power surge, so I now have the fridge on a surge protector. Haven't had a problem since. Hope this helps.
Nov 10, 2009 | Maytag MFI2568AES Stainless Steel Bottom...
Door Alarm
SOMETIMES THE DOOR MIGHT SEEM PROPERLY CLOSED BUT ITS NOT TRY RE ADJUSTING THEM AND SEE IF THAT WORKS ALSO THE DOOR CLOSED CONTACT CAN CAUSE THE BUZZER TO GO OFF FOR NO REASON.
GOOD LUCK.
MOHAMED
Aug 23, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
New just need manual
Try the following link:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=mfi2568&siteCd=MT_EN_US
Jul 28, 2008 | Maytag MFI2568AES Stainless Steel Bottom...
Refrigerators Logo
76 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
