Question about HP Officejet 4315v All-In-One InkJet Printer
My HP Officejet 4315 Printer won't turn on. I can see it powering up on the screen. At a certain point the screen black scan bar stops in full position of movement? I try disconnecting and reconnecting the printer. Nothing happens? My laptop reads, printer off line?
  • 93 Answers
SOURCE: Scan Problem with HP Officejet 6110 All-in-one
Once try to scan from the scanners and camera wizard to check the two way communication between the computer and the all-in-one.
  1. Verify that the all-in-one product power is turned on and the printer cable is properly connected.
  2. Click Start .
  3. Click Programs .
  4. Click Accessories .
  5. Click Imaging .
  6. From the Imaging application, click File , and then click Select Device .
  7. Select the HP all-in-one device from the TWAIN source list.
  8. Click File , and then Acquire Image . Imaging for Windows will scan from the all-in-one product using TWAIN software instead of the HP software.
If you are able to scan by performing the above steps then search for the file hpqscnvw.exe and try to scan from there.
If you are not able to scan even from the above steps, once refresh the USB cable and then try to scan again.
if you are able to scan from that file then try to scan from HP Director, if the issue persists then create a shortcut icon for that file and then try to scan else uninstall the software and reinstall.
Posted on Jun 19, 2008
rakeshpramod
  • 234 Answers
SOURCE: HP Officejet 6110 stops printing. Installation of updated software and drivers stops without any warning
Try a complete uninstall:
Unplug the USB cable from your PC.
Go to Control panel add or remove programs. and delete all the entries you see for HP.( If it promts a restart do not restart now)
Then open my computer> C:drive> Program files> and delete the HP Folder only (not Hewlett Packard)
Then Open C:drive> Program files> Common Files and then delete HP and Hewlett Packard folder.
Then Go to C:Drive> Windows> Temp and empty the temp folder as much as you can.
Then go to Recycle bin and empty recycle bin.
Then Insert the All-In-One CD and cancel the installation process.
Open the content of the CD> and open Util folder> Then CCC> Then click on Uninstall_L4 and follow the on screen process.
After all restart the computer.
And if possible download the latest printer driver from HP website and install the same
Let me Know if any problem
Good Luck
Posted on Sep 15, 2008
  • 214 Answers
SOURCE: HP C7280 won't print
Try reinstalling the software, first remove the previous installation Then confirm all is working through USB cable, the worry about wireless Inkypete
Posted on Apr 23, 2009
sfda410
  • 20 Answers
SOURCE: My HP Officejet 5610 All-in-One won't copy or scan any document
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
a7
Posted on May 27, 2009
  • 240 Answers
SOURCE: HP L7700 officejet printer leaves streaks on black
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Posted on Nov 28, 2009
Why do i get thick black line(stripe) when scanning and copying with the hp 4315
Sounds as if you have dirty drive path for the paper. Printers are bad about ink leaking (especially if not used often) and cleaning well involves some disassembly. The ink is very messy so wear rubber gloves. Clean around print cartridges, rollers, and also the glass for scans.
Jul 26, 2014 | HP OfficeJet 4315 All-In-One InkJet...
Do not have program for hp officjet 4300 all in one series i want to install the program in order to use printer to scan, fax, copier
before you click on the links below,first determine the flatform or system type of your operating system.you will be needing that in downloading the correct software.here's how to do it: -click on start (pearl button) -right-click on computer or my computer -go down to properties -look for the operating system and system type (32-bit or 64-bit)
now let's go on to the download page.check out the links below:
HP Officejet 4215 All-in-One Printer http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=351106&lc=en&cc=us&dlc=en&lang=en&cc=us
HP Officejet 4315 All-in-One Printer
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1138342&
step 1: select your operating system step 2: hit next step 3: click on driver and click on HP Officejet and PSC Full Feature Software and Driver or HP Photosmart Full Feature Software and Drivers note:if you want to use the scanning feature,always download the full feature software and driver step 4. Click the Download only button. step 5. When prompted, choose Open to start the download and run the software installer. step 6. Follow the on-screen instructions to start the installation process. step 7. Connect the USB cable between your HP all-in-one device and your PC when directed by on-screen instructions, and turn on your HP all-in-one device. step 8. Wait for additional on-screen installation instructions before using the all-in-one.
Jun 06, 2011 | HP Officejet 4215 All-in-One Color Photo...
HP Officejet 4315 will not scan with OCR using Vista OS - will scan image not text - %APPDATA%\HP\Digital Imaging\Data\Destination in registry OK - installed Vista tablet path for HP - uninstalled and...
Your problem always makes me wish you opeted for chat and I got lucky enough to be in line
So call (805) 452-2733 and I'll make your printer work on Vista
I'm up anyway but just don't wait all night LOL
Oct 06, 2010 | HP OfficeJet 4315 All-In-One InkJet...
My hp officejet 4315 all in one says Cartridge error.. I replaced the cartridge one week ago it is still full of ink I took it out and shook it.. And put it back in. I unplugged the machine and still...
I replaced both cartriges bought at cartrige world. Screen on printer says: "Cartridge Error". I reinstalled both cartridges and still get "cartridge error". I don't have a owners manual, Help!
Roger
Jul 11, 2010 | HP Officejet 4315 All-in-One Printer
How to run a scan HP officejet 4315
Good day Sir, to run scan Hp officejet 4315 follow the instructions below.
1. Load your originals print side down and top first in the center of the document feeder tray.
2. Press Scan. the Scan To menu appears on the display.
3. Press OK to select the default application to receive the scan, or use the arrow buttons to highlight a different applications, and then press OK.
4. To stop scanning press Cancel on the control panel.
Tip: To force the scan to be in black and white, press Start Black instead.
Have a nice day hope this will help you.
Jun 15, 2010 | HP Officejet 4315v All-In-One InkJet...
HP Officejet 4315 All-in-one prints color but not black ink. It stopped printing black all of a sudden. Please advize on what to do.
check the ink level of the black cart. and try to clean the cart copper contacts with the lint free cloth..
n try to print..
else try it with a another set of new cart..
Oct 29, 2009 | HP Officejet 4315 All-in-One Printer
My HP officejet 4300 series stopped printing and shows that it is offline. How do I get it back online?
To get back online of your printer, go to Control Panel and Select Printer & Faxes then OPEN.
A list of Printer is on the browser, point the printer with your mouse then right click on your Printer HP OfficeJet to select Printer Offline and click it to go back Printer Online. Good luck!
Aug 04, 2009 | HP Officejet 4315 All-in-One Printer
I would like to be able to scan with an HP OfficeJet 4315
Please click on following link and download the manual. in the manual page number 69 shows how to use the scan features,
http://h10032.www1.hp.com/ctg/Manual/c00644922.pdf
Regards,  raj_p5983
Jan 10, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Hello Joan,
Did your printer come with some utility software ? This software would allow you to scan and then change the document type to PDF.
Please contact me if you have any additional questions.
George
Sep 05, 2008 | HP Officejet 4315 All-in-One Printer
HP Officejet 4315v All-In-One InkJet Printer Logo
46 people viewed this question
Seeker5211
Seeker5211
