Question about Bosch Washing Machines
Hi my Bosch washing machine stopped working today it's 5 years old model WAE18061au I'm not sure if maybe there is just a blockage because all the lights are working just the water is not coming through. Is there a trouble shooting manual? Thanks Rhiannon
    Master:
  • 492 Answers
Try resetting the power by unplugging for two hours and then try it again.
Posted on Oct 15, 2013
Noggin
  • 944 Answers
SOURCE: ge washing machine model wip4013srw how to fix the problem
Unidentified buzzing noise in top loader machines is often due to a jammed or seized drain pump, especially if the pump has its own motor - sometimes just opening the front of the pump (usually under a panel at the base of the front, possibly behind a small - 3-4 inch - panel to one side or other) will clear it. behind the pump cover will be a sealed plug or similar, usually needs a half turn to undo. small pieces of wood or plastic sometimes are the cause, and may be "floating" on the drum side of the drain pump so may not be visible immediately. Make sure the machine is unplugged and check with your fingers to see if the pump blades rotate freely - they will have some resistance, but should not feel like you are pressing against something solid. If you still have the manual for the machine, somewhere you would expect to find detailed instructions for a user to clear the pump - it is not usually a difficult or complicated job however some machines have a very different drain system. You may have a certain amount of water comes out over the floor - this is normal. On an optimistic note, many of these machines are still functioning after more than five years with no problems, so it is likely to be minor. If you suspect the electronic control to be the reason for the problem, it may just be that it will not continue a cycle without properly draining, even if the drum appears to be draining adequately - check the drain pump. The pulley attached with string is slightly unusual - perhaps this is as a result of an old bodged repair and needs to be resecured - without more detail or a photo this is hard to say. Best solution for that would be if you could find a similar machine, possibly in a second-hand shop and ask to look at the base to see if there is anything obviously different with your machine.
Posted on Feb 17, 2007
  • 1294 Answers
SOURCE: Hoover Nextra washing machine - water backing up
If this is a front loader see that u use only washing powder for FRONT LOADING MACHINES. Also possible your detergent drawer is clogged with old dry detergent. Pull out the drawer and clean with tooth brush. Things shd be fine.
Posted on Oct 08, 2007
Bob Gemmell
  • 209 Answers
SOURCE: Bosch WFD 2460 Washig Machine
Hi, It sounds like you have the two water pipes fitting on the wrong connectors on the back of the machine.
IE: The hot water pipe (RED connector) on the cold water inlet on the back of the machine (BLUE connector)
Is should be red to red and blue to blue.
Posted on Jan 03, 2008
  • 43 Answers
SOURCE: bosch exxcel 1200 express
need more info what point in the wash does it start to display the code
Posted on Nov 11, 2008
SOURCE: Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Posted on Mar 21, 2010
My Bosch WAE24367 washing machinet
check hose from the tub to the exit point you have a blockage
Jan 02, 2014 | Washing Machines
Can't get a Bosch MAXX 5 WAA24161GB to start. Changed fuse and socket, but machine still won't work?
hello, have you checked the glass fuse inside the washer make sure you use the same rated fuse the value will be on the end of the fuse hope it helps
regards
shaun
Mar 06, 2011 | Bosch Washing Machines
Bosch washing machine model WFF1401GB/01, 10 years old, motor was replaced 5 years ago (so motor is 5 years old now). Drum has stopped rotating, pump etc all OK. Carbon brushes replaced, drum did work for...
Check the motor control board for dry joints, poor contact, signs of excessive heat around plugs/pins
I would try new brushes again or thoroughly inspect whether they are contacting the commutator.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Mar 01, 2011 | Bosch Washing Machines
I have a Bosch Maxx 1000 Washing machine and it seems to be stopping just before spin dry and flashing end. Door won't open so I need to turn to spin or drain to complete cycle. Today the spin cycle...
this is because the water can't evacuate . check the pump trap filter and make sure there are no blockages. you will probably find water still i the machine when this happens. There might be a blockage up in the hose pipe before the pump. Good luck
Jan 22, 2011 | Bosch Washing Machines
MACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
May 31, 2010 | Bosch Classixx WFL 2066 Front Load Washer
I have a Bosch Exxcel 1400 S Express which blew
There is no internal fuse in the washer to replace.
If you have replaced the fuse, make sure that is is a good one.
If you are satisfied that you have power to the washer, then I'm afraid it sounds quite serious.
Trust this helps.
Dec 04, 2009 | Bosch Washing Machines
Bosch WFK 2401 Full of Cold Water!
put machine near an outside door let the empty hose lie outside that will drain the water out........then check the pump for a blockage ........
cheers
Jul 24, 2017 | Bosch WFK 2401
Washer stops prematurely with code 03
This was always caused by a blockage of the pump. The water isn't able to be pumped out so the sequence stops rather than continuing with the wrong water still in the machine.
Our solution was to manually drain, then open the pump area and remove the coins that always were the cause of the blockage. Wish we could get our (grown) kids to stop putting pants with full pockets in the machine!
Of course, I am looking at this site today because the machine no longer turns the drum. A repairman visit resulted in the diagnosis that the power control module AND primary motor are burned out and need replacing, at an estimated $800.
Aug 21, 2007 | Bosch WFK 2401
BOSCH WFF 200L
heater element may have gone, when you manually advance the settings you are skipping the heat cycle.
Jun 02, 2007 | Bosch Exxcel WFO 2465 Front Load Washer
Washing Machines Logo
65 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
