Question about Maytag MBR2556KES / MBL2556KES
Smoke from underneath fridge - Maytag MBR2556KES / MBL2556KES
  • 1 more comment
  • billandshelb Oct 15, 2013
    I unplugged the refrigerator and cleaned up all the lint etc on the coils underneath. I checked the terminals to the compressor connection and they look ok. I plugged it back in and the refrigerator is keeping things cool, however the freezer is not. The parts that were sizzling/smoking were white and looked to be ceramic. Only the ones on the left (when facing the fridge) sizzled. Would this have something to do with a circuit that would control delivering cold air to the freezer?
  • Gere knutson Oct 15, 2013
    Hi, You posted " The parts that were sizzling/smoking were white and looked to be ceramic." Where is this you car talking about? Is this located in the freezer or back by the compressor? Can you send me a picture to this email address kidlmo@msn.com so I can help you easier. This model appear to have a relay package to it, so what ceramic parts are you referring too? Please get back to me when possible Thanks
    I can send you a picture later today. They can be seen when removing the lower grill on the front of the fridge. The parts are between the floor and the bottom of the freezer, where all the dust collects. There are 4 of them, one in each quadrant of the metal tubing. I have not looked close enough to them yet to see if there are any wires going to them or not, or if they are just there to dissipate heat from the rail. Could the metal tubing have gotten hot enough itself to ignite "dust bunnies"?
  • Maytag Master
  • 842 Answers
HI,
Unplug your fridge, inspect the relay package mount to the compressor, this may be where you have an issue. If shorted inspect the terminals on the compressor first before ordering any parts, as if damaged terminals are present, a new compressor is needed.
I hope this helps, good luck.
Posted on Oct 15, 2013
Testimonial: "That was a good start, however still have not figured this one out. I added this comment above. I unplugged the refrigerator and cleaned up all the lint etc on the coils underneath. I checked the terminals to the compressor connection and they look ok. I plugged it back in and the refrigerator is keeping things cool, however the freezer is not. The parts that were sizzling/smoking were white and looked to be ceramic. Only the ones on the left (when facing the fridge) sizzled. Would this have something to do with a circuit that would control delivering cold air to the freezer?"
Smoke came from under fridge
When you let the smoke out of the wires, they don't work as well afterward! Sounds like a short and what was burning was wire insulation. The main components are the compressor and the fans.
Look for misshapen wires as that will be the best indicator of what has overheated.
Jan 03, 2015 | Refrigerators
Condensation water build up inside refrigerator
The tray underneath your fridge is probably clogged, and overflowing. There is an evap tray underneath, and if it does not get adequate airflow, it will overflow, and leak out.
Clean the bottom front vents, and underneath the fridge to ensure adequate airflow.
Mar 31, 2014 | Sub-Zero Refrigerators
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
When we open the freezer door, a lot of steam/smoke comes out. A lesser amount comes out when the fridge door is opened.
If the fridge is working and keeping things cold and frozen, you don't have a refridgerant leak that is producing vapor that might appear as steam or smoke.
The steam/smoke is actually water vapor being made visable due to the temperature difference between the freezer/fridge temperatures and the air temp in the room (or garage) the appliance is in.
It's nothing to worry about and is normally more likely to happen when the outside or house air temp is very warm (Summer months) and when the air is humid.
What's happening is the very cold and cool air is hitting and mixing with the much warmer and much more dense air (humid air contains microscopic water particles) when you open the doors, and is instantly being cooled. Thus it appears as thou the fridge is steaming or smoking.
Have a great day an hope this explains the situation. Best regards.
Jul 30, 2009 | GE Refrigerators
Buzzing sound clicks on and off from underneath fridge
that would be your relay going bad it will stop the fridge all together change it to a 3 and 1 relay
Apr 15, 2009 | Admiral 26 cu. ft. Side-By-Side...
My fridge started smoking
Sounds like your compressor burnt up on you. Replace the fridge all together. YOu do not want to take the risk of it catching fire
Feb 12, 2009 | Refrigerators
Not cooling after smoke damage
Assuming that the motor is running, my best guess would be that the condenser (a large grid of thin piping) was covered in soot, and should be THOUROUGHLY cleaned, preferably with compressed air.... The condenser will either be underneath the unit, behind a small panel in the front bottom of the unit, or at the back behind a cover at the bottom of the fridge which runs the whoile width. Make sure the fan at the back near the compressor is also running....if the condenser fan is not running when the compressor is running, it won't cool. If the condenser is excessively dirty, it won't cool!
Jun 26, 2007 | Frigidaire PLHS269ZC Side by Side...
Maytag MBR2556KES / MBL2556KES Logo
42 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
