Question about Zanussi FJS1225W Front Load Washer
My indset washing machine
Could you tell me my soap powder draw wont come right out as i need to wash it as its cloged up and i really need to clean it
  • 209 Answers
Most soap drawers have a little springy thing you press to allow it to come out, this stops it getting pulled all the way out by mistake, pull the drawer out as far as it will go gently till it stops then look for something that will move on the top where the soap goes, try pressing it, sometimes it is a different colour, if you found this the drawer will slide out when you press this bit, if there is nothing that moves or nothing to press then give the drawer a little bit extra force ( a short sharp tug) and it should just slide out that last little bit, to put it back just line it up with the slides and push gently back into place, it shouldn't be forced too hard to do this, it should just slide back
Posted on Sep 25, 2007
SOURCE:
Where does soap powder go in amica AWB510LP
Top left hand draw pulls out, Right hand channel for washing powder
Jan 14, 2015 | Washing Machines
Softner is dispensed in Wash cycle
in the top of your soap draw compartment is a lever that switches the water jets over ( for instance on the main wash the jet arm is directed in the main wash compartment which will take away your main wash powder then it moves the jet are to the sofner compartment on the final rinse ) the jet arm somtimes jams and needs cleaning and the small holes above your draw compartments clog with lime build up the thing to do is take out your draw clean the inside at the top where the holes are and take the top off your machine there are two screws at the back top you will see the little ark on your soap draw it will have a return spring on it gently move it from side to side this will clear any obstuction make sure that it will spring back clean any line around the arm ( make sure you switch unplug your machine before you remove the top)
Nov 21, 2011 | Washing Machines
My washing machine won't use soap from the drawer
are you useing the right draw for main wash try putting on a wash and open the draw there should not be any water leaking if you do this and look in the compartment that you put the powder in and see if the water is going into the compartment that you use and see which compartment is filling thats the one to put the powder in
Nov 14, 2011 | Washing Machines
When the washing machine has finished the wash powder and conditioner is still untouched in the draw???
When the washing machine has finished the wash powder and conditioner is still untouched in the draw??? This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
May 02, 2011 | Washing Machines
The whashing comes out with white powder like stuff. Can I clean the drum and if so how ? is it flint that gathers some where?
Hello Sir Tommis,
I understand that you are having a problem with your washing machine. When you wash clothes they come out with a white powder like substance on them. This white powder substance is the powder laundry soap that you are using.
This is generally caused by adding to much soap and clothes to the washing machine. The soap is not getting dissolved and the clothes do not have enough room to agitate in the machine. Try to put 3/4 of the amount of clothes in the washer with the same amount of soap and see if the clothes come out with the same powder like substance on them.
The clothes that currently have the soap on them will have to be hand washed with a scrub brush in oder to get the material off of them as running them though the washer will not remove the soaked in soap.
Thank you for choosing FixYa.com
Justin
Mar 26, 2011 | Whirlpool 3.2 cu. ft. Washer
We just used a brandt washing machine for the first time. It worked alright but did not take washing powder and fabric conditioner. Could you tell me reason why please? Model type of w/machine is...
used a brandt washing machine for the first time. It worked alright but did not take washing powder and fabric conditioner This video will show you how to keep your soap draw clear and how to service the parts
Feb 12, 2011 | Brandt Washing Machines
Hotpoint wma46, my machine does't seem to be taking/emptying the condition during the cycle, i have taken the draw out and cleaned it but it still won't work properly any advice ??
Hotpoint wma46 This video will show you how to keep your soap draw clear and how to service the parts
Jul 08, 2009 | Hotpoint WMA46 Front Load Washer
When wash starts water pouring out drawer
take your soap draw out and seif it blocked sometimes the washing powder blocks the pipe to the drum you could also try and boil you kettle and poar in the soap draw
Jun 24, 2009 | Hotpoint Washing Machines
Soap not being used
We learned from our new Duet that when washing with Tide soap powder, there is an adjustment inside the pull out drawer where the soap powder goes. You will see a grey plastic slider that goes to the right for liquid soap & to the left for powder soap.
Moving this slider to the left corrected this problem - not using all of the soap powder needed - for us.
Good luck !
Marilyn in FL
Jan 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine wont take the soap powder and softener
It could be a water inlet valve that is at fault. Are the hot and cold supplies turned on? Try opening the powder draw very slightly when the machine is filling with water, if no water in powder draw, chances are that the inlet valve is at fault, situated on the inside of machine where the filler pipes connect. Unplug machine from power supply before checking the inlet valves with a resistance meter, making sure to disconnect wires from one terminal to avoid false readings. Tom.
Mar 07, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
