Question about Samsung HCM4216W 42" Rear Projection Television
The colour on my samsung rear projector out of line how do i fix
Theres a picture but at the same time it is also showing shades of blue and yellow as if there are more then one picture.
how do i fix this problem???
can anyone help me asasp
Hi there i had the same problem with my 42inch tv and it was the convergence chip very easy to do and with instructions
Posted on Sep 22, 2009
    Sniper:
  • 85 Answers
Sounds like the convergence chip needs to be replaced. You need a good soldering gun and a steady hand. i believe the kits come with full detailed instructions on replacing the chip.
you can get the kit at www.tvrepairkits.com
Posted on May 17, 2009
Yellow Shading.
go into the menu for the color or brightness and contrast..try to change a bit at a time..
Jan 08, 2014 | Samsung LN52A550 LCD TV
Not showing entire image on screen
It's possible that your projector doesn't natively support your display resolution, but to know more it would be best if you could provide the following details:
Projector Model
PC Model
Windows Version
Windows Resolution/Refresh Rate
Display type (if laptop) cloned/extended, etc
Thanks!
Feb 18, 2008 | Sharp XR-10X Multimedia Projector
Colour has screwed up
Call Encompass Parts Distrubtion 1-800-638-3328 its either your DMD board 180.00 or Light Engine and they do not have any in stock Cost $1,056.00 Try UED 1-800-648-6657>
Dec 31, 2009 | Samsung HLN5065W 50" Rear Projection...
Picture is OK, but colors are off and there is a blue star background that shows on dark colors.
Hello, With most rear projections there is usually an alignment to do with the set up with your TV. This is so the red, blue and green projectors align together to give the correct colouring. This sounds to me what may be causing the outlining of the blue. This can also make it seem off colour. Look in the set up menu of the tv and see if you can find this alignment feature. Usually a cross will appear and you move a blue, red, and green cross with the arrows on your remote to align over the original white one. If this does not work, it may also mean that one of your projectors, that is the red, blue or green one may be failing causing the off colouring. Hopefully this alignment may fix it for you.
Oct 26, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
My sony grand wega gives a blue shade on the black background which is the problem
HI, Check the menu set up of the TV. There should be an alignment feature that aligns the blue, red, and green colour projectors. If the blue is out of alignment that is likely why you can see it on the dark backgrounds. The set up normally puts a white cross on the screen and you select each of these colours and then move the cross over the white on with the arrows on your remote. Once all are aligned correctly you shouldn't be able to distinguish between different colours and hopefully this should get rid of your blue shade.
Oct 25, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Yellow image produced by DP8200x
the light filter on the blue lcd is fried and needs to be replaced. it makes sure only blue light comes therough that lcd panel. when it's light is blocked from coming through, only the red and green lights can be seen, hence the yellowness (red light+green light=yellow light). it's common with lcd projectors. unfortunately, you can't buy that piece seperately. you need to buy the entire optical engine, which isn't cheap (almost $2000).
Jul 31, 2009 | ASK Proxima InFocus Projector lamp for...
Samsung rear project colour problem blue and yellow
Hi I am vortash sounds like you have a convergence problem and I am guessing you dont have the manual for this set .. there is one available free from http://www.safemanuals.com
this section here deals with the convergence but their are other things in the settings that can cause this so download your own full copy Regards Vortash e03fb99.jpg
Apr 24, 2009 | Akai PT5598HD 55" Rear Projection...
My tv has lost its colour, and its green or yellow sometimes.
Okay that means the other GUNS went out when i refer to guns I mean the other blue and red, they need to be replaced pretty costly but if you value that TV I'd do it.
Apr 22, 2009 | Samsung HCN4226W 42" Rear Projection...
Monitor display in blue shade
It may be due to the loose contact of the monitor signal cable
Contact the nearest Repairman
Let me know that your problem is solved and rate me as Fixya!
May 27, 2008 | SAMTRON 55V 15" CRT Monitor
Bright yellow
I can't imagine a setting that would cause this - It sound more like some sort of fault with the projector's blue LCD panel. (The image is created from a mix of red, green and blue light. If you loose the blue, everything will look yellow.)
Is it capable of showing any shades of blue?
Using any graphics or photo-editing software, create a solid blue image (R=0, G=0, B=255 in your colour settings) and if possible, display this full-screen. Is there any output from the projector at all when you do?
If not, it sounds like it need a professional repair.
Matt
Feb 26, 2008 | NEC VT676 Multimedia Projector
Samsung HCM4216W 42" Rear Projection Television Logo
414 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
