Question about Refrigerators
Ice 2 inches thick in bottom of refrigerator
I have a Whirlpool refrigerator. There is a buildup of ice in the bottom part about 2 inches thick. It also freezes eggs if they are not in the carton. I have cleaned the coils but that was no help. The ice is also in the drawers. The ice is solid.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 77 Answers
The defrost drain is more than likely plugged. unplugg the fridge, take the back pannel of the freezer. remove as much ice as you can from the drain trough (putty knife works good). Once you can see where the drain spout is use hot water and a turkey baister to clear the ice from the drain. this will stop the build up of water(ice) in the bottom. as for the eggs i know it souns simple but turn the fridge down a half point per 24 hrs. use a thermometer in a glass of water to check the tmp. can safley run between 33f and 40f. Good luck.
Posted on Sep 26, 2007
Samsung fridge freezes milk and food
I would say it probably needs defrosted. Check for thick ice buildup, more then 1 inch. Remove gently as possible. May just need turned down a bit. Adjustment is inside refridgerator on side or above top shelf. Best of luck. Hope this has helped!
Apr 11, 2011 | Samsung RS2556 Side by Side Refrigerator
8 year old Whirlpool Gold refrigerator: Freezer icing up. Found ice on shelves and on the bottom under the vegetable hydrators. The shelves and drawers constantly have a humid film on them. Last week,...
for no frost type;cleaning of freezer cub underneat is a must...cloggged drain outlet buildup thick frost on your freezer cub..
.ie..for frost type;you must set your thermostat setting to normal,replace it with new one
Oct 20, 2010 | Whirlpool Gold White-on-White 21.9 cu. ft....
Ice buildup on bottom of freezer?
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Jun 03, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice build up on freezer door
your door gasket isnt set right call for warranty service
Jun 03, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
Water is dripping from freezer to shelves in fridge
first remove the floor and back wall of the freezer. remove the ice from the floor and drain pan careful not to damage the evaporator and drain pan. to the right of cener on the bottom of the drain pan is the drain hole. use a turkey baster and hot water to thaw the drain, you should hear water dripping into the drain pan when thawed. install a heat probe whirlpool part number 819043. or wrap a thick piece ( about the size of a pencil lead) of copper wire around the heater located under the evaporator. make it long enough to go about 2 inches into the drain. don't let the wire touch the sides of the drain hole or touch the bottom of the tube, this will prevent the drain from freezing. i recommend using the heat probe from whirlpool but the wire will work too. hope this helps.
Jan 26, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool refridgerator-model#ETICHMXKOO4-We have
There is ice buildup in the drain and maybe under the seperator. Remove the back panel in the freezer and the botom floor of the freezer and remove the ice. Be careful of the styrofoam ducts. Eric
Aug 10, 2009 | Whirlpool Refrigerators
I fixed the ice buildup in the bottom of the freezer (I hope) but
I just saw your post today and yes I believe the part should be in place. The problem with the ice is cause by several reasons and will give you a link shortly. Below is a photo of the freezer components and how they should be.
HOW TO FIX A DRAIN LEAK INSIDE YOUR REFRIGERATOR
If you should still need help but I almost think by now you have given up on us. Sorry I didn't see your post sooner Sea Breeze
appliancepartsoutheast@live.com
http://servicepartstec.blogspot.com/
http://appliancepartseast.blogspot.com/
http://appliancepartsse.blogspot.com/
Aug 05, 2009 | Jenn-Air JCD2389G Side by Side...
In the frezzer ice is forming under the floor and dripping down onto the floor of the refrigerator part under the veg drawers
May 05, 2009 | Kenmore Refrigerators
Bottom Freezer has ice built up
Possibly the defrost element is faulty, this is located behind a cover in the back of the freezer compartment and is attached to the fins of the evaporator. It also has a defrost limit thermostat which could also be the problem. I presume that the fan is working after you have defrosted the unit?
Mar 04, 2009 | LG LFX25971ST Bottom Freezer French Door...
Ice build up under the freezer drawer
drain is blocked. remove back panel inside freezer and melt the ice off at the bottom with a hairdryer then follow up with hot water till drain flows freely. if fault reoccurs, then you may have a fault with the defrost system
Jul 06, 2008 | Whirlpool GB2SHKXL Bottom Freezer...
Refrigerators Logo
298 people viewed this question
Top Refrigerators Experts
Marvin
Marvin
Gil Shultz
