Question about Home
Aqualisa quartz a1
My blue light on the start button is constantly flashing so shower will not work. Any ideas thanks
3 Suggested Answers
peterrance19
  • 399 Answers
SOURCE: Aqualisa quartz shower. Knocking / dripping type
this is caused by the water pressure in the pipes check that all the pipes are secured firmly this should stop the problem a piece of rubber or foam placed behind the pump will also help
Posted on Nov 16, 2009
  • 349 Answers
SOURCE: Get a knocking noise from an Aqualisa Quartz 2
It may be a water hammering effect from pressure in your pipes. You may need to install a water hammer to stop this. you can put in line that will stop this.
Posted on May 05, 2010
Aqualisa showers led fault codes on temp control
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Dec 28, 2017 | Home
Where is thermostatic cartridge located in aqualisa quartz shower
watch this video as this should be of some help
https://www.youtube.com/watch?v=djUi3SB5-y8
Aug 28, 2017 | Home
Leak from the bottom of the shower unit
Use ptfe tape or some other kind sealent
Aug 22, 2017 | Water Heaters
My Aqualisa Quartz shower stopped working suddenly. Pump is on, but no water
can offer no information on this but to call a local plumber .sounds like you possibly need a new pump
Aug 01, 2016 | Home
Aqualisa quartz electric 8.5
This just happened to me this morning, you found a fix for it?
Sep 06, 2012 | Watches
6 yr old Aqualisa shower working perfectly well. But turned itself on last night. No light showing on dial/on switch. Wouldn't turn "off" for me. Ran for 15mins and then switched off!
Good Aternoon lrmulholland,
Do you know what model Aqualisa shower you have or are you able to take a photo of it for us? That would be very useful.
Kind Regards,
The Aqualisa Team
Sep 07, 2011 | Vacuums
The 'boost' button on my aqualisa digital shower won't switch off. It comes on when I press the shower on (without actually pressing the boost button) and when I press the boost button to try...
Good Morning drlesleyanne. The issue you describe will down to the PCB inside the push button controller. If this does not send the correct signal to the processor box it can cause the unit to 'fail safe' and this is why the unit needs a power reboot. The remedy to this is to replace the push button control itself and once installed should allow the shower to work correctly again. All our digital products have five year guarantees, so you can always call our Customer Service line on 01959 560010 and they will replace this for free.
Kind Regards,
The Aqualisa Team
Jul 29, 2011 | Home
Hello, my aqualisa shower is working intermittently, water starts and then goes down to a dribble, but not all the time. It is an aqualisa quartz.
If you are not getting any water through your shower it is possible that there is a restriction.
Please note that the air lock test is only neccessary if you're shower is the Pumped Digital Quartz or Quartz Thermo Mixer Shower and that you are on a Gravity Fed Water System (cold tank in loft).
The hose will appear fine from the outside,but the hose has an internal rubber liner which can become blocked/twisted.
To remedy this,unscrew the shower head from the hose anti-clockwise.Place the open end of the hose to it's lowest point (bath or tray).
Turn the water on.The water SHOULD come out in a straight line,if however the water comes out in a V-Shape the liner is twisted and the hose will need replacing.
Air Lock
If there is air in your pipework this will cause low flow and pulsing.To remedy this fault do the same above but run the water on FULL COLD for two minutes and then FULL HOT for three minutes.
If the water pulsates it is the air escaping.If it does this leave it until it corrects itself.
Hope that this info helps you,if it doesn't it sounds like you have a mechanical fault with the processor box.
Aug 24, 2010 | Kitchen Ranges
Dec 28, 2009 | Home
Aqualisa quartz shower. Knocking / dripping type noise coming from pump when powered but not turned on. Any ideas???
Nov 15, 2009 | Home
Home Logo
27 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
