Question about Casio G-SHOCK 200M DW5600E1V Wrist Watch
Watch display is "frozen"
The display is locked-up displaying all 8s on each line, for all digits.
It is probably runied. Joe
Posted on Oct 03, 2007
SOURCE:
My Watch is showing military time but i want it to show in the 12 hr clock
To use 12- or 24-hour time for your watch, please follow the instructions below.
1. Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side.
2. Press the "Date Advance" button on the upper right side. This will reset the seconds.
3. Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
4. Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
5. Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
6. When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
http://www.fixya.com/support/t6812987-change_timex_wr30m_from_24_hour_12
How do change my timex wr30m from 24 hour to 12 hour display
Mar 21, 2018 | The Watches
How to set the time?
Timex Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right side
  • Press the "Date Advance" button on the upper right side. This will reset the seconds.
  • Press the "Change Mode" button on the lower left to set the hour. The hour will flash. Press the "Date Advance" button until the correct hour is displayed.
  • Press the "Change Mode" button again to set the correct 10s unit (first digit 1 or 0) for the minutes. Press the "Date Advance" button until the correct first digit of the minutes is displayed. Repeat this step to set the second digit of the minutes.
  • Repeat Steps 1 through 4 of this section to set the year, month, date and day and whether to use 12- or 24-hour time for your watch.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your settings.
  • Mar 13, 2011 | Timex Watches
    How do i change my timex wr30m from 24 hour to 12 hour display
    Hi cbrichw,
    Hope it helps.
    Thank you for using FixYa.
    Nov 13, 2010 | Timex 1440 Nylon watch
    Dont know hoe to set the coreect time and date
    Thank you for contacting FixYa.
    ANALOG
  • Locate the knob on the side.
  • Pull the knob out. The second hand should stop ticking.
  • Twist the knob clockwise until the correct time is displayed on the watch face.
  • Push the knob back in, and the the second hand will resume ticking.
  • Digital Watch
  • Press and hold the "Set" button for 2 seconds. The "Set" button is on the lower right sidePress the "Date Advance" button on the upper right side. This will reset the seconds.
  • When finished, press the "Set" button (on the lower right) to return to the current time view and lock in your setting.
  • Best regards. Jewel
    Sep 13, 2010 | Watches
    I have purchased some cheap wrist watches from Hong Kong. They are the rubberised type with a digital display but have no instruction as to how to alter them. Can you help please?
    mcdevito75 here, I'm figureing you have only one (1) button on your watches, some, even cheap digitals have two (2) buttons, one of which is ususlly for a light. Some have two (2) buttons, one says MODE the other says SET. For one button (1) digitals, This will usually say set, when you press this button you should see the display change, to month then press set agin to see date, press set again to go back to time of day. NOW!! look for a DIMPLE, an INDENTATION on the side of the watch fairly close to the other button, press this DIMPLE in with a tooth pick, pin or the point of a pen, this is your MODE, press once, see the display flash, now with the set button, set whatever display is flashing, press MODE again, set this next display, when all displays, Month, Day, Date and time of day, hour and minute are set, press MODE again to see steady display. when you press set now, you can see the corrected display, press the set button for each display you want to view until you come back to the time of day display. That"s it.
    Jul 18, 2010 | Watches
    Stopped working and all digital figures displayed!
    If the display is not dim the battery is probably OK. Try removing the battery, test it anyway, and after a minute or two replace it (I'd use a new one anyway) and see if the problem is cleared. Sometimes just power cycling will "reboot" the watch. If that doesn't do it I'm afraid it will need to visit a Breitling service center.
    Apr 15, 2010 | Breitling Aerospace 455 Wrist Watch
    Analogue hands don't correspode to digital clock
    Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used:
    1. Activate Crystal
    2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m).
    3. Push and hold (at least five seconds) the center crown
    4. Watch will beep and word (SYNCHRO) will appear in the display.
    5. Use the top + button to line up the minute hand right on the 12.
    6. Use the bottom – button to line up the hour hand right on the 12.
    7. When finished, press crown and you will go back to time.
    Jan 08, 2009 | Tissot T-Touch T33159851 Wrist Watch
    I have a Rado DiaStar watch (with digital display), and the hands are out of synch with the digital display. Is there a way of adjusting the hands independently of the display? or must it be sent back to...
    Hears how i do my watch, i have the same watch as you.Just make sure nothing is displayed on the clock face by turning the winder, ie NO digital time, NO daul time, NO alarm, NO stop watch etc, Pull out the winder(crown) and adjust the hands to the time you require by spinning the winder.(Gentley for mins and fast for hours) The digital clock will display wilst doing this, but not change the time.handy if you want to sync both clocks.Push the winder back in at the time to sync and the digital display will go out, then spin the winder again if you want to display the digital features. I hope this helps, please post if it does, Maurice Chevalier- Herts
    Nov 01, 2008 | Rado Diastar Anatom Jubile watch
    Casio G-SHOCK 200M DW5600E1V Wrist Watch Logo
    552 people viewed this question
    Top Casio Watches Experts
    Janelle Schoonover
    Janelle Schoonover
    Ekse
    k24674
    Are you a Casio Watch Expert? Answer questions, earn points and help others
