Question about Canon CLC 1140 Copier
I HAVE ERROR E354 ON CLC 1180 - Canon CLC 1140 Copier
Cogz
  • 1326 Answers
SOURCE: CLC 1180 with error E020 with sub 0124
Did you change the Magenta stater/ developer? A E020 code is saying that the toner desity is low. Try replasing the developer and run the ATDC for Megenta and see if that helps. You may have a problem with the developing ass'y it self. You may be able to take another colors dev. ass'y with the hopper open and see if the code goes away. The sub code 0124 means that it is the Magenta dev. ass'y
Posted on Feb 05, 2008
  • 168 Answers
SOURCE: canon clc 1180 error code 073-0003
this is an error for the transfer unit or its cleaning section not in proper place slide out the unit as far as it will go.. look inside to the lower left rear frame. there are 2 halfmoon gears sticking out reach in and turn both of those clockwise till they stop . slide unit back in close doors see if it resets good luck
Posted on Dec 29, 2008
  • 67 Answers
SOURCE: E020-00A3
your back up data is currupt, you need to change your p-sens-p value check your door spect for all default value. after that clean your sensors that is found below the black developing assy. take machine off unplug from outlet replug turn machine on DO A GRADUATION ADJUST that should solve the problem / if not unplug the the same sensors , then repeat the first prod.
Posted on Jan 10, 2009
  • 168 Answers
SOURCE: canon clc 1180 error code 071-0007
k you may have several problems you may take some canned air and blow out the connectors on the tx unit and the inside frame particularly the connectors on the lower right rear frame wall .. when you pull out the tx unit you may also want to turn the two cam gears on the lower left rear frame all the way clockwise then slide unit in
  • 153 Answers
SOURCE: E020 Error in CLC 1180 Copier
you have a drum/developer related error
Posted on Sep 28, 2009
Plz solve my clc 1180 error is e8040101 help me
Returned error from ftp server(no acces right to the folder)
Oct 08, 2014 | Canon CLC 1180 Copier
Service manual
Code error E 020, 0173
Jul 09, 2013 | Canon CLC 1180 Copier
Canon 1180 error code E005 200
Nov 26, 2012 | Canon CLC 1180 Copier
Error e020/04e0 for clc 1180
You need to Reset Code From Function_Clear_Err_OK. Check Dens_K in Display_Dens if it is to less i.e. bellow -2.5 Check Whether Black toner is present in hopper or replace Black developer
Oct 24, 2011 | Canon CLC 1180 Copier
Solution for canon 1180 clc error code E021 0401
Most Probably Your Black Color Developing asssembly is overloded with excess black toner and might not be rotating. Check it
Oct 15, 2011 | Canon CLC 1180 Copier
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
Sep 24, 2009 | Canon CLC 1180 Copier
Canon CLC 1140 Copier Logo
old marine
old marine
