Question about Garden
Hilti te 75 reparatie tekening - Garden
  • 152 Answers
SOURCE: hilti te 10 switch problem
You may research your area for a Hilti service center / dealer or order your part directly from
www.hilti.com
or call (866) 445-8827
Good luck
Aduz
Posted on Mar 15, 2009
SOURCE: i need wiring schematics for hilti te 905 avr
Wiring schematics can be found by Hilti 1-800 number but they probally will not help you. The 905 is programed to shut down for service every 40 hours plus 10 warning. Then in my case I am stuck with a 200 dollar bill to send the tool from Winnipeg to Montreal for reprograming. Its a joke in my situation and its on me from Hilti, what a good name but what a scam.
Posted on Jun 09, 2009
  • 123 Answers
SOURCE: hilti te-72 hammer failure
Do not put it in hammer mode and try to unscrew the chuck! This will break the housing internally. To remove the chuck you will have to put a chisel in the chuck. Lock that chisel in a big vice. You will then have to put a pipe wrench on the chuck to unscrew it. It is regular threads but there will be loctite on it. Once that is off your will have a spring and two roller bearings to remove before you can slide the bell off. You will then have 8 5MM screws to remove. This will remove the chuck. You will then have a snap ring to remove. After that you can remove the whole cylinder assy. More then likely your connecting rod is broken.
Posted on Oct 09, 2009
  • 61 Answers
SOURCE: parts for my hilti te 76
If you send me an email i will send you the parts diagram. parts are available from me but I am in Gibraltar. but I can give you a quote if you like.
paul@wysehire.gi
www.wysehire.gi
Posted on Oct 11, 2009
ftw1952
  • 10319 Answers
SOURCE: Hilti TE 12. It will not hammer.
the rotory cam has been broken inside if not producing the hammer effect
Posted on Mar 11, 2010
How do you grease a hilti te 805?
Hilti TE 805 Instructions Use Manual not helpful at all
no time to take the tool all apart ..must be some external way
can you make anything out on the hilti te 805 drawings
save images as a pdf then you can magnify easily
Jun 16, 2016 | Hilti Drills
Broken clutch on Hilti TE-75?
The clutch mechanism needs replacement
Aug 25, 2017 | Drills
The "O" rings of my hilti te 75 are used , can somebody tell me how to replace them ?
that would be REALLY hard to do in this forum. You can get a breakdown from Hilti at www.hilti.com or call them at 1-800-879-8000.
Dec 24, 2012 | Drills
Reset service light on hilti te 706
I have one Hilti Mechie , TE 706 Avr, Now Red Light Only Blinking ,Mechine Not Working
Jun 12, 2012 | Hilti TE 70 Hammer Drill Performance...
My hilti te-75 drills but is not hammering or will not go into chisel mode whay coud be the problem with it
Have seen this problem with some 'none' HILTI bits which do not fit correctly into the SDS chuck.
Tends to be with larger drill bits which have a wider shank than the SDS connector, the wider shank hits the end of the drill nose which stops the end of the drill bit contacting with the internal hammer.
Solution is to purchase original bits from Hilti. If you have OEM bits and chisel it will be another problem. Hope this helps.
Feb 07, 2011 | Hilti TE 70 Hammer Drill Performance...
Will the bits from the te-c3x fit my te-17
Yes. New bits will fit old Hilti drills. Old Hilti bits do not fit the new (last 15 years) Hilti drills.
Apr 07, 2010 | Hammer Set Of 6 Hilti Te-c3x Drill Bits...
Mar 11, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti TE 10 drill. It doesn't seem to hold the
Probably a missing ball problem---contact Hilti website.
Feb 27, 2010 | Hilti Hammer Drill, 8.4 Lb 3 Mode, Te 16 C
Garden Logo
18 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
