Simpson enviro 080
When my machine is filling, the water is spilling out the front where the washing detergent goes... how can I fix this please?
  • Sapph
    Sapph Oct 16, 2013
    To each of you who responded to my plight, I thank you so very much! I went through what each of you had said to do and can only surmise it was a blockage of soap powder, as when I put machine back together ready for a technician (I gave up) to come in and do it, it worked!!! Yay, I am so grateful... Again, I thank you so very much. Cheers... Sapph (",) P.S. Girls can do anything hehehe
  • 135 Answers
SOURCE: Diplomat 8512 Washing machine -
This is a problem with the pressure system usually caused by a build up of powder residue but can be caused by other blockages. Remove machine lid and locate pipe which is about 6mm in diameter. follow pipe down which will lead to pressure bottle. Clean out and replace and should be ok. If bottle is clear check pipes for other blockages and check preesure pipe for damage.
Posted on Nov 07, 2008
SOURCE: he2 leaking from detergent dispensor
We had the same problem, It was a pair of sock stuck behind the seal in the drum blocking the water inlet to the drum. Like others we managed to get our fingers between the metal of the drum and the rubber seal near the detergent dispensor to remove the sock.
Posted on Mar 01, 2008
Dissolu
  • 221 Answers
SOURCE: Lg tromm front loading washing machine has
Yes the system is cloghed. Pull the detergent drawer out and clean the drawers housing. try using some bleach. It allways helps.
BE ADVICED: after using bleach run quick wash cycle on without any load, it's just to get rid of all bleech remains and not to damage your clothes
Update me about your progress
Posted on Jul 25, 2009
  • 57 Answers
SOURCE: Washing Machine Keeps Filling with Water through Detergent dispen
This machine has a water valve that works on vaccuum from the tub. You will see a small clear hose that runs from the side of the tub up to this valve. This valve is adjustable to change the water level in the tub to desired setting on some machines, but if it goes bad, it will not shut off, thus overflowing the tub. Find this valve and replace it if adjustment does not work.
Posted on Oct 10, 2009
  • 69 Answers
SOURCE: machine will not stop filling with water
Does machine stop filling if you discnnect from power? If it does, the problem lies with timer/control unit, or fault in pressure switch/ tube. Check pressure tube (thin rubber pipe that goes from water level selctor switch to side of outer bowl) for holes- replace if faulty. You can test pressure switch by remove pressure tube from outer bowl and blowing thru tube- you should hear the water level switch click when you blow, and then click again when you release pressure.   If it keeps filling even with power off, you have a faulty inlet valve. If you remove top panel (3 screws along top rear-power off first!!), you will see the inlet valves- one for hot, one for cold. The valve is the thing the inlet hoses screw onto. New valves availble from any good spare parts supplier, relatively inexpensive part. Good luck!!
Posted on Mar 13, 2010
Testimonial: "Exactly pipointed the problem which is now fixed Thank you"
Simpson enviro 080 doesnt spin
water backing up in the machine indicates a blockage. Two places to look are the filter and the hoses. If it is a well used machine there is a possibility of clothing in the pump. Usually something small like a sock. Hope this helps.
Aug 08, 2015 | Simpson Washing Machines
Where does the washing detergent go in a Simpson eziset 550 washer
Bleach goes in the left hand side portal softener is put in top of agitator an washing powder I normally dissolve at start when machine filling before putting items in
Feb 23, 2015 | Simpson Washing Machines
Simpson Ezi Sensor Front Loader keeps pausing during washes, doesn't put through the detergent.
you might be putting the detergent in the wrong part of the dispenser,or you might have the hose on the wrong way,or the water valve has failed. Read up on your user manual to see what happens on this part of the cycle,does the w/m empty ,then try and bring in more water?? The main give away to this fault is,detergent still in the dispenser.Check all your filters on your inlet hose and water valves.
You have to ask yourself what has changed,cheers.
Aug 14, 2012 | Simpson Washing Machines
Timer turns off during cycle
Yes. The timer needs replaced. Either the motor inside is getting too weak to turn, or the gears are stripping out on it.
Apr 30, 2012 | Washing Machines
Don't know how use my front loader
CLICK HERE
Please download asap - as it is stored on my personal FTP site, and will be removed in 48 hours.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 24, 2009 | Washing Machines
Simpson enviro 080
there is probably something stuck in the filter. take the plastic cap off and clean it out. i had this problem and found a coin wedged in the filter part. once the coin was removed.......good as new!
Jan 05, 2009 | Washing Machines
Whirlpool front loader WF665/1 spilling water during cycle. Water is leaking from where the powder is deposited into the machine during the filling stage of the washing cycle. The machine will continue its...
that means that the water is leaking from the hows at the back of the detergent drawer.
This is not a difficult fix, however the washing machine must be taken apart to access the detergent hose and find the leak.
Always better to call a technician.
Nov 16, 2008 | LG WM2487H Front Load Washer
Water inlet not filling
check it has drained completely after the last cycle.
if that is ok, take top off and check continuity thro the inlet valve coils
Aug 21, 2008 | Bosch Classixx WFC 2465 Front Load Washer
LG Front Loading Washing Machine
Bleach goes in on a calculated time.Yes some one could have reversed lines.Actually the harness i believe.
Jun 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Water levels
Probably the nivauchamber is clogged of lime or something. Or you are overloading the machine
Jan 31, 2008 | Zanussi ZWC1300W Front Load Washer
Washing Machines Logo
20 people viewed this question
Top Washing Machines Experts
