Question about Bowflex Treadclimber Pistons 10580
Tc pistons are still good - Bowflex Treadclimber Pistons 10580
How to replace head gasket on a 05 scion tc 1.5L
If you are asking the question let a mechanic do it. The gasket is cheap but it involves a lot of work and some experiance. Look in a Chilton book for that model and you'll get an idea of whats necessary.
Oct 18, 2014 | 2005 Scion tC
How to turn up the psi
off the memory - on this particular model you have knob just before the valve and indicator, lift it up and turn clockwise to increase pressure and anticlockwise to decrease it.
Apr 04, 2014 | Airbrush-Depot Master Airbrush Model G23...
I recently got my 75 tc 185 out of storage and it is set up. Pulled off head and penetrating oil goes by piston. Any ideas on ho0w to free it. Thanks Randy
Pour break fluid in there let it set awhile, poor more in there, it will eat all the corrosion or rust from the rings and piston walls. Eventually freeing it up, hope this helps you.
May 29, 2011 | 1981 Suzuki TS 185
2004 TC 450 etremelly hard to fire it up when is cold....
Always shut off your fuel before shutting down the engine. shut off fuel a block before you kill the engine. this drains the carb bowl. when you do shut down, the suction from the piston going down doesn't foul the plugs. read it in a manual for an old 1967 bridgestone but it works great on my old harley.
Mar 16, 2011 | 2004 Husqvarna TC 450
Tc whont turn on the light wont turn off abs light wont turn off
Your ABS system has detected a fault in the system. When that happens, the TC is automatically turned off. You will have to have the ABS diagnosed and repaired before the TC will come on again.
Good luck.
Jan 17, 2011 | 2005 Hummer H2
Looking at a 2005 scion tc for 122000 miles for 7850. Is this a good price and will this car be reliable for years to come.
well depends on how it was driven, little old lady maybe, a young kid maybe not, need to ask where is the car fax
May 19, 2010 | 2005 Scion tC
THE TC light had a wrench beside it? And the TC light says the TC is off and the ABS light is now lit up. I tried pushing the button to turn the TC on and Off but this makes no difference
chances are there is a problem in the abs system, which also controls the traction control. have the car scanned for codes, which will give you a starting point for diagnosing. good luck!
Dec 22, 2009 | 2002 Pontiac Aztek
Need to replace the front brake pads on a 2006 scion tc coupe
front is as same as gm, 2 on caliper do not forget to press caliper pistons back into themselves, then just take pads out and replace then, install and start car and press on brake to bring pressure back into caliper
Jun 22, 2009 | 2006 Scion tC
Engine rattle when bike is under load
This sounds like a classic case of pre-ignition, aka detonation and engine knock. Change to premium gas and put in a set of spark plugs that are one heat range colder than stock. It is good that you are handling this before the engine destroys itself. Yes, destroys itself. That is what pre-ignition will do. Hot carbon deposits ignite the fuel before the spark plug does. This is hard on the rod, main bearings and piston. Beat on the top of a piston with a hammer. That is what your piston will quickly look like with pre-ignition.
Please rate this answer. Thanks
Apr 23, 2009 | 2004 Husqvarna TC 450
Bowflex Treadclimber Pistons 10580 Logo
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Glenn Mayer
Glenn Mayer
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
