Hobart 42 in. AM14C-154 Free-standing Dishwasher
Problem for Hobart 42 in. AM14C-154 Free-standing Dishwasher
Hobart am14 water runs through it all the time
By recco122 on Apr 24, 2009
hobart am14 water runs through it all the time
Clarification Request
Posted by doobo67 on Aug 08, 2009
fill valve kit? or be more specific draining all the time ? what water tank> pump runs all time ? rinse all the time?
Posted by lolchuck on Jun 26, 2009
Hi, Your water inlet valve is stuck open located at the top right hand side needs to be cleaned or replaced.
Solution #1
posted on Aug 08, 2009
Not Rated)
paultech8226
Rank: Guru
Rating: 93%, 13 votes
I asume you are referring to water running from the rinse arms all the time.
You will need to check the fill/rinse solenoid. It may have debris holding it open, or is worn out. For the correct parts, have your machine ML number and look on www.hobartservice.com in the parts section. Use the ML to get your specific drawings and part numbers. Call 1-800-444-4764 to reach the nearest Hobart officeand ask for parts. There are quite a few variations of solenoids throughout the AM14 build span, but all have a repair kit if the body is not worn. Check the rubber end of the piston for wear. It comes in the kit.
Was this helpful?
Yes
No
Solution #2
posted on May 19, 2009
Not Rated)
bigg t
Rank: Guru
Rating: 86%, 595 votes
Sorry so late for they reply,the solenoid valve internal parts are worn.Is the model an am-14 or am-15?Let me know i can get you the hobart part #.i'm a hobart tech.The valve kit is cheap.
Was this helpful?
Yes
No
Solution #3
posted on May 09, 2009
Not Rated)
dhtech
Rank: Master
Rating: 85%, 5 votes
If water is running even with the machine turned off then your solenoid valve needs to be cleaned out or rebuilt. This valve is in the back top of the machine by the gauge.
Was this helpful?
Yes
No
Popular Solutions for Hobart 42 in. AM14C-154
Questions and Unsolved Problems for Hobart 42 in. AM14C-154
Do you recommend Hobart 42 in. AM14C-154 Free-standing Dishwasher?
Answer
Answer
not operational. starts beeping and reads 30. It does not reset
Answer
we would like someone to come out and service our washer. It is on a boat in Newport Harbor
Answer
amx-r q keeps filling and dosnt seem to come to temp, and few other problems please help
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Hobart 42 in. AM14C-154...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
