Question about NetGear WGU624 Router
WiFi not recognized on Compaq laptop
I have a compaq laptop and a home computer we used a wireless router on main computer and it was working fine till recently, the other day I turned the laptop on and the WiFi wasnt working or didnt even recognize the router from other room. Is it possible the WiFi card went out or Possible the Router is messed up? I have check all the software on my laptop and it seems fine just doesnt recognize router. HELP!
  • 4 more comments
  • vega07 Sep 28, 2007
    Okay I did that, it says computer does not have wireless network adapter installed, install wireless netwrok harddrive & verify correct driver installed.. I am working with a COMPAQ V600 Pesario Laptop computer.... I dont know what happen?
    HELP!
    I cant even get the Wireless Assistant to work the icon isnt there anymore and when I click it in the control panel nothing happens.....
  • Ashwin Thejaswi Nov 28, 2007
    Im facing the same problem with My compaq Presario V 6211 AU Laptop.
  • devendra074 Sep 11, 2008
    ya i have v 600 series laptop by compaq and the wifi is not been recgnised.don show the option of wlan..
    what to dooo
  • dreambig63 Jan 04, 2009
    i cant connect to my wireless router
  • Anonymous Mar 18, 2009
    my wireless is not recognised its not even in the divice manager did a system restore still nothing!!!! what the f####$ is going on?
  • Anonymous Apr 10, 2009
    i'm using compaq v6211AU laptop. my wifi is not recognized at all by the computer. I use vista home premium OEM. wifi does not show in the device manager and message shows install wifi adapter and drivers for it. how do i turn this on?
    sooraj
    tvm, kerala
    President:
  • 2,961 Answers
This can happen sometimes, just go to network connections in control panel, right click on the wireless icon and click dissable (or press the rellevant button on your notebook) Restart pc and then right click on the icon again and select enable. There should be an icon in your taskbar, right click and select view network connections, and then see if your router is listed and click connect.
Posted on Sep 25, 2007
SOURCE:
Hp compaq Presario CQ57 Notebook PC wireless button has a red light and wireless not working
Unplug the router for about 6 minutes. Don't just turn it off. Completely unplug it. Then plug it back in, with your computer on.
Apr 06, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Why won't laptop connect to wireless internet? Wifi is working, another computer in home is fine
are you at home or Starbuck? location matters.
so, the compaq must be setup correctly.
your router broadcasts the SSID name seen by you on all devices, see that on the Compaq (y/n)
then you must pick wep. or wpa, or wpa2 encyption mode.
as set in your router, we cant see inside you router only you can
then set the passphrase to what you router wants.
is this XP, windows
does the wifi chip look ok in device manager?
Is XP infected.? with malware as all are now.
never post about computers lacking what operating system you have, or answers will be wrong, even all answers.
Feb 12, 2018 | Compaq Presario CQ62-215DX Laptop
My Compaq Presario M2000 wifi light is "On", but
While logged into the router, Turn on "broadcast ssid" or tell your computer exactly what the SSID is. One form of security is to set the router not to tell other computers in wifi range what the ssid is.
Nov 08, 2011 | Compaq Presario M2000 Notebook
I have a compaq laptop which i've had for a year or so. My laptop connects fine with every other internet broadband but not our new home one, and every other laptop in the house connects to this internet...
Compaq Presario V6000T now retired at HP (zero support)
ok its old. 12 long years old [email protected]!!
first learn that old laptops do not have modern wifi chips.
like other PCs have, a fact.
the answer is Encryption modes.
WEP , WPA or WPA2.
in my home we have WPA2 ONLY AT THE ROUTER.
for security reasons and no old laptop works with WPA2
then learn other homes running old gear, routers.
have WEP on only
and most new PC have that disabled, or gone now.
WEP is net secure now at all so is gone.
now lets answer you in more basic forum
why not learn to setup the PC and your router the correct way.
if your PC only does WEP/WPA (look does it?)
then
in the router, turn that on. if using wep turn it on, and know that you homes router can be hacked easy.
if you have WPA, turn that on, and use only that if the PC can not use WPA2. use WPA for sure, at LEAST.
turn off TKIP (use AES mode) too,.
im reading your PC spec now.
what wifi?
it has 802.11b/g
in most cases we must find out what wifi chip is there.
and what OS you run, you never said windows what?
then get the newest driver for that wifi chip.
some are not available.
finding the chip true name is not easy.
I can but I have powerful scanners.
the cure is , use the unsafe protocol
or upgrade the driver,
or buy wifi dongle USB (new) and use it. easy and cheap.
use WPA2 only. if wise.
next time post what OS you have
nobody can match working drivers lacking that key fact
is this stinking XP the DEAD OS? or vista? it too is now dead.
Jan 10, 2018 | HP Compaq Presario V6000T Notebook
My compaq presario cq60 wont connect to my wireless router but other devices in my home have connected fine
Check if the router has any restrictions, if not, try uninstalling any wireless program on the compaq and using the windows connection.
Be sure you are selecting the right encryption.
Kind regards
Mar 05, 2011 | Compaq Presario CQ60-212US Notebook
The wireless cannot be detected any more. It used to work just fine. Button setting the wireless on does not recognize it.
is the wireless on? all laptops have a wifi on/off button, did you install any programs lately?
i installed object dock, and after awhile, it killed my wifi till i un installed it.
Oct 31, 2009 | Microsoft HP Compaq Presario F553US...
Need help with Wifi Connection with COMPAQ EVO N610C LAPTOP
First you will need a router which will enable you to create a wireless network for your internet connection. I recommend, if you're purchasing online, to use Tigerdirect. Then you would need a USB wireless adapter for your laptop which will enable it to communicate with the wireless router and establish an internet connection.
Below are some links for the most affordable and best rated products you need.
USB wireless adapter.
Wireless router
Oct 05, 2009 | Compaq Evo N610C Notebook
I just purchased this system used, but only a few months old. I currently have Linksys wireless router and the AT&T module (plugs in the side of the computer at times). My other laptop works fine on the...
Trying cloning the mac address some isp's have started blocking home networks by requiring only one mac address the option to clone it should be in your routers wireless settings.
Dec 17, 2008 | HP Compaq Presario v3000z Notebook
Problem with connection of networking and VOIP.
Go to your Run program on the computer that your are having connection problems with. Type cmd.exe in the box. When your DOS page appears, type in ipconfig/ release. Be sure to use a space between the / and the word release. After it releases, type in ipconfig/ renew, using the space as well. Close out of your DOS. Recheck your internet connection. Before you recheck it though, make sure that your computer's wireless password, if you are using any, are the same as your wireless router's password. Hope this helps.
Sep 07, 2008 | Compaq Presario Notebook
Wifi problem in compaq presario c762nr notebook
Your network profile is damage create a new one, once the profile get corrupted it will never allow to connect to any outside networks due to security measure.
Hothawk
Jul 23, 2008 | Compaq Presario Notebook
NetGear WGU624 Router Logo
940 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
