Question about Nokia Asha 306 Nv - Red
I can't open the contacts"operational failed"
Invalid Web Settings and Operation Failed
You need to contact your mobile carrier to resolve this issue. They are the only ones who can help.
Jan 08, 2014 | Nokia 5310 Xpressmusi
Zillions cash register won't open
Try pushing the drawer in just slightly as you operate the open register key and see if the latch releases. If this fails then you will need to contact a repair shop and have it fixed..
Dec 18, 2013 | Summit Products Zillionz Talking Cash...
On the 2003 lincoln navigator, my drivers side running board doesn't deploy when the drivers door is opened. The interior light and the radio doesn't recognize that the door is open, hence the light...
It is most likely that the door switch in the pillar near the door catch is not making proper contact when the door is opened and therefore not triggering the functions that operate when the door is opened. It is quite common for these switches to become intermittent. To check, try operating the switch plunger by hand, with the door open, to see if the functions operate. If OK, then remove switch and clean contact points with some fine emery paper or other suitable abrasive such as an ink eraser. When reinstalling, ensure there is a good contact between the switch body and the door pillar. If the cleaning process fails to correct the problem then the switch should be replaced.
Sep 29, 2010 | 2003 Lincoln Navigator
My nokia 7210 supernova is showing operation failed plz help
Remove the battery and keep aside, remove the memory off. Now replace battery and see if the phone reboots , if not there can be a software issue and you might have to contact Nokia care to reinstall.
Sep 28, 2010 | Nokia 7210
Operation failed
You may have installed the application on your memory card and it has problems or your phone has contacted a virus.
Contact your phone engineer.
Apr 03, 2010 | Sony Ericsson K800i Cellular Phone
Sony ericsson w595 operation failed inbox
i have the same problem, the exact same thing happened. ive just been looking for solutions and i have just reset my settings ... now i am waiting for the results as to whether i can open my messages again! okay so it has reset my theme and colours and everything but... it works! and it doesnt delete any data.. finally! :)
Sep 29, 2009 | Cell Phones
Game and application operation failed
i could not open my game and application, it will display operation failed, and then i try to reformat it, but it is not work. please help my problem.
games and applications are not open, if try to open that shown operation failed! how to solve this problem? please help vaen okay
Sep 21, 2008 | Sony Ericsson K800i Cellular Phone
Operation failed
same as our problem mine too,operation failed and then when i trying to open the inbox ,drafts ,sendt items,it's say operation failed,,my phone its totally broken? k850i sony ericson my phone unit. help me pls!!
Jul 10, 2008 | Sony Ericsson K800i Cellular Phone
Operation failed
In make/receive/search time your mobile consume more power.
in that time the phone not get the needed power, so it switch off.
  1. Sol. Refix your sim and battery
  2. check your battery contacts to phone, it may loose contact, clean using a rubber on both battery and phone contact
  3. Check your sim contacts also
  4. Check your battery status, go to sony ericsson authorised dealer for check it used original battery some time you will get a duplicate battery,
Jan 17, 2008 | Sony Ericsson K800i Cellular Phone
Sync fails with "too many open databases"
This is what I did to fix that error:
Hard-reset your Palm to erase all data (that usually involves pushing the small "reset" button on the back, then pressing the "power on" button until the device boots, and then pressing "up" to confirm the hard-reset)
After that, sync your palm. The sync software will ask if you want to use your existing profile or create a new one. Create a new one. Then the program will offer to sync your Outlook profile with your Palm. Click on "ok", and a message asking you to accept to sync your Outlook data with more than one profile will pop-up. Click on OK, again... and that's it!
Sep 07, 2005 | Palm Tungsten T3 Handheld
Nokia Asha 306 Nv - Red Logo
97 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
